#151
Thanks. I am planning to use high grade 3/8" bolts too. The thing im worrying about is that im using 3 X 1-1/2 X 1/4 (6.0#) channel for everything under the mainbeams. Cross bearers, legs, etc. Thats very heavy. Im wandering if I use an appropriate number of high grade 3/8" bolts that I'll be fine? What do you think?
I was thinking maybe I should use 1/2" but thats seems like overkill to me. 3/8" bolts are pretty big/ strong. Last edited by cvriv.charles; Fri 12 March 2010 at 00:06.. |
#152
3/8 will be fine, but if I do this again(and I will) I will be using all metric bolts. To many things you buy for this, like steppers or the wheels, all use metric bolts. It was a lot of switching back and fourth and it gets to confusing. Dennis By the way I think I have a reservoir you built. DarthBevis gave it to me. |
#153
![]() Anyways thanks for the advice ![]() Last edited by cvriv.charles; Fri 12 March 2010 at 01:40.. |
| And another MM will be built in Belgium | bramvh | Introduce yourself and start planning | 9 | Fri 15 April 2016 15:01 |
| Hi guys. | Kurt Rose | Introduce yourself and start planning | 4 | Sat 13 February 2010 16:41 |
| Before I buy could you guys please check my purchase | Regnar | 702. Power Supplies | 2 | Mon 18 January 2010 22:31 |
| heres some guys could use some help from Art | revved_up | Miscellaneous / General / Whatever / Catchall | 0 | Tue 24 March 2009 10:52 |
| What are the limitations of a MechMate compared to the $50 000 machines? | Gerald_D | General - MM Build | 19 | Sat 14 March 2009 11:17 |
