#211
Congratulations on getting it moving! I'm still dreaming about that day.
#212
CONGRATULATIONS bubba!!!! I'm really happy for you. Feels good doesn't it?
#213
Go Sean!
#214
Congratulations Sean!! Pretty soon Gerald is going to need to add a section on the forum for showing off projects completed with the working MechMates.
#215
Sean,
Congratulations. Hope to see some more of your great pictures and your first cut. ![]() |
#216
Good going Sean!!
#217
Congratulations Sean!!! As a fellow NCSA alum, the "build" has been interesting and looking forward to seeing the "performance". "Break a leg" !!!
#218
Yaaaaaaaaahooooooo, we're cutting MDF baby!
Proof is in the pudding guys and gals.
We have officially cut the Roadrunner.tap file and the first part of the MechMate logo file. There seems to be an issue with the License copy of Mach3 I purchased, and is only allowing me to cut 100 lines of code. Tech Support is working on getting me a new license number. Anyway...here's the pics! |
#219
Thanks for all the kind words everyone. But the congrats go to Gerald. This machine is easy to make, use and set up. Heck, I have already tried to break it and have successfully failed!
Now it's time to pack it up and move to it's new home in Bay #4 of my plant...about a 600 FT move, then the squaring / leveling process begins. Sean |
#220
So, it's blue and it cuts wood, but does it have the logo? Swop you a serial number for the logo!
![]() Well done! Actually didn't expect anything less... ![]() When you have more time on it, would like to hear your impressions vis-à-vis the Multicam that you have some experience with. |
#221
thanks for the pictures Sean.
That looks GREAT !!!! The excitement is too much for me, so I took a day of vacation to work on the beast. ![]() |
#222
Its alive, and its almost No 5 - well done Sean
#223
Sean, remenber on Oct 7th in your post #1 you said you calculated a bill of $6818.32? So how many cents were you off?
#224
Stefan,
It was close, but I was under budget! 6482.00. I guess I have a few dollars left over to buy some new router bits now! Of course, I will use all the 300 or so dollars left in the budget to put limits on the machine. So, the original number is a real budget for me using 5 geckos, 5 motors, new computer, Mach3, a couple of grinders and lots of time. Sean |
#225
Sean, with the risk of you disappearing now that you no longer need us
I'll be in Orlando mid next month, if you are open for a tour and a chat, I would love to stop by and see the Mechmate. I can bring a Haitian bottle of rhum to celebrate! Let me know and I'll send you a PM. Stefan |
#226
disappear. Never, I have to start on machine #2 now for my brother. Same 5x10 with spindle, vac holdown and dust collection. No indexer on his. He cuts only plastic sheet.
Your welcome to stop by. Just pm me the dates. Next month is busy, but I am sure we can fit it all in. Sean |
#227
update.
I ordered the proximity sensors, relays, wiring tonight from factorymation. I also sent the plot files for all the logos off to my sign shop. I should be properly logo'D tomorrow. I ran some cutting tests today. Statistics. 25khz 203 geckos 7.2 sg motors 20t pinions. Average cutting speed max@ 150 ipm 45khz @ 190ipm. Performance at 5 ipm really smooth and slow. So far, so good ![]() if I feel I really need more speed, I'll change to larger pinions. But for now, I am really pleased with the cut chips on the mdf and birch core ply with the 1/2" end mill. Last edited by smreish; Sun 17 February 2008 at 19:24.. |
#228
J.R. and I were routinely cutting mdf at 120ipm with a 1/4in downcut spiral (solid carbide). We got a pretty good cut at 240 also.
#229
Marc
Did you cut through 3/4" mdf in one pass or multiple passes? If multiple passes, at what depth per pass were those cuts? Paul |
#230
My experience with my MechMate was using 1/2" carbide bits and cutting MDF or Ply in the 90 to 120 ipm routinely. The 1/4" bit does let me cut faster. But, as all cutting tools know, it's about the chip, not the speed! Typically, I used 2 passes on my other table due to the vacuum hold down didn't like that much side force. 1 was easy to do, but I often sacrificed tool life due to the heat generated by cutting that much MDF in one pass.
Mr. Richards had written as nice thread earlier in the year on "tearing paper" sounds.... Last edited by smreish; Mon 18 February 2008 at 07:13.. |
#231
We cut usually in 2-3 passes. We were just learning and wanted to minimize side forces using minimal clamps.
We cut some 1/2in. CPVC (the solid not the expanded stuff) pretty much in one pass just to experiment. Got a fair amount of chatter. Didn't have enough clamps on it and pulled it out from under two clamps resulting in a broken bit. The only bit we broke but we learned what we could and couldn't do. |
#232
Interesting. Thanks for the reply.
Paul |
#233
All done, logo's and all!
Leko came by the shop tonight to help me tune the drives, do some squaring of the machine and take a few photos. As you can see, it's official. MechMate Blue with pretty white logo's!
Thanks Gerald! I can't wait to start machine #2 and build a bonified Mamba to match this one! May I have a number please? |
#234
There you go! Number 5 is yours!
#235
Well, I found out a few things tonight.
1) I realized how fast you can really drive the machine before you de-rail the gantry....it's about 210ipm with a 1/2" double flute carbide dull bit ![]() 2) How quickly this is going to get to work....2 units of MDF ordered and ready for cutting on Thursday - about 88 sheets. 3) How really well the machine sets up. I did the "squaring" sheet cut, flip and check as in the Gerald tutorial - I was dead on parallel and square first try. NO shims necessary! I was truly flabbergasted that I built this baby this square. Less than a .020 change between 0,0 and 0,48. |
#236
Sean, I would still like to hear your comment on this animal compared to the Multicams you have some experience with. |
#237
You can count on it. I actually will visit my old 4896 multicam next week and take photo's as a reference to post with results. Additionally, the other machine we had here the shop, A 4896 Warthog will be in the pros/cons review as well. I will post a nice summary and "shoot off" in the next couple of weeks once I have run a few units of product through the tool bit ![]() |
#238
Looking forward to it, but don't rush.
#239
Sean,
Congratulations. Looks great!!! |
#240
Congratulations Sean. There was a time when I considered going after that #5 number.
![]() I think I'm going to stay under 210 ipm, thanks for the warning. |
| The second MM was easy, but the building's electrics were noisy #28 - Orlando, FL | smreish | MechMates already cutting | 58 | Sat 26 September 2020 18:36 |
| Corner finder | Rad Racer | General - MM Operating | 2 | Tue 28 May 2013 11:19 |
| Problems working the end of some Ballscrews | coinhunter | Miscellaneous / General / Whatever / Catchall | 5 | Thu 21 July 2011 15:06 |
| Working Out The Table Plan | dakmonf | Introduce yourself and start planning | 32 | Wed 30 June 2010 12:59 |
| Corner finder and cam clamps | Rad Racer | The Show Room | 9 | Sun 19 April 2009 10:06 |
