Thread Tools |
Problem with stepper motor?
Hello everyone,
I'm currently building a gantry milling machine. For this I purchased 3 NEMA 23 stepper motors and a controller based on TB6560 on oyostepper. Now that I have all three motors connected, I noticed that one of the motors is behaving strangely: When starting slowly, it bounces back and forth before starting to run normally. However, which direction it turns is accidental. The other two engines run absolutely problem-free. I then swapped the motors and the control crosswise, but the behavior of the motor in question remains the same. I can therefore rule out a control error. A measurement of the resistance of the connected windings showed approx. 1.6 ohms for all motors. So the windings are apparently OK. The only way I can explain this is that the windings in the supposedly defective motor are somehow wired incorrectly. As I said, the engines are brand new. Has anyone ever had something similar? Thanks in advance |
ck the grubber screws on the shaft.
| Stepper motor & Driver from Oriental motor | steven29 | 701. Motor Drives | 17 | Sun 17 May 2015 12:20 |
| Stepper motor speed problem. | shikha829 | 70. Control Systems | 4 | Mon 19 September 2011 07:50 |
| Would you mind to help me to solve the problem for Keling stepper Motor Driver? | qangel1000 | Motors & their mountings | 6 | Sat 08 August 2009 00:42 |
| True Torque of a Servo motor for comparison to a Stepper motor, when used in a router | Mcyoda | Motors & their mountings | 3 | Tue 19 August 2008 01:50 |
| What does a stepper motor look like inside? (geared Oriental Motor) | Gerald D | Motors & their mountings | 0 | Sat 16 August 2008 09:29 |
