Thread Tools |
Machmate Upgrade made
I have upgraded my machmate with new clearpath servos, and changed my software over to Acorn from centroid. This move has been the best move I made. It just works.. I will not go back to the old system mach 4, pmdx board, stepper driver and so no. We also build a Machmate with a plasma system on it. It has the same acorn system as my router.
If anyone would like more info please let me know. |
I would like to know more.
Ive been waffling between DMM servos and Clearpath. Going to use Acorn. Im just starting to gather steel and tools to start after reading here for over a year. What motors and gear reduction have you used? |
Clearpath approval
firechief
I’d like to chime in and express my approval for Clearpath servos. I’ve been using them on Mechmate 111 for many years now and could not be happier. They are Nema 23s and they push that big gantry around effortlessly. YES, NEMA 23s’… I keep two dial indicators attached to the machine to check for overshoot/undershoot, when the gantry returns. It always comes back to the ‘Zero’ position. Sometimes on a long tool path run, 45 minutes or so, it will return with a little error; generally less that .0005 each axis. I’m happy with that… The Clearpath servos on my Mechmate, the Clearpath servos on my 3-axis Bridgeport conversion, and the Clearpath HP servo on the Bridgeport spindle have never failed. They are more expensive that steppers, but since their failure rate is ‘ZERO’, I never have to trouble shoot control problems. I also have an Acorn controller on the shelf, but waiting for time to complete the upgrade. Can’t wait.. For those interested in the Clearpath or other servos, if you can afford it, get away from the hobby controls-stuff. You’ll never regret it. BillT |
hi Tim! i m interrested to know more about your upgraded mechmate.
Yannick. |
| Time for an Upgrade! #79 - Calgary Canada | HomeMadeCnc | MechMates already cutting | 174 | Mon 15 May 2017 17:55 |
| Upgrade Pictures | sailfl | Archives | 2 | Sun 08 February 2009 07:54 |
| Required Torque for possible upgrade ?? | boutzo869 | Archives | 4 | Wed 22 October 2008 09:04 |
| MachMate ïî ðóññêè - Krasnodar, Russia | Maxkor1973 | Construction started, but not cutting yet | 1 | Sat 14 June 2008 18:48 |
