Old Wed 21 September 2022, 16:49
bmusson
Just call me: Brent
Altadena
Exclamation Stepper moves in random directions (forward or backwards)
When running G-code (or jogging) the stepper will either move in the correct direction or in the opposite direction, randomly. I've replaced the Gecko drive and the wires to it (some looked pretty cooked). I even replaced the entire PC that I use to run the G-code; I made a clone as a spare, when I set up the machine.
Before and after all the attempts at repair, the malfunction happens exactly the same, without the slightest change. I don't know what to try next.
Old Thu 22 September 2022, 09:12
Mcmoo
Just call me: McMoo
Norfolk
Is it just on one axis?
If you swap either the motor, or driver with another one does it keep doing it on the same one, or on the swapped one?
HELP! Motors "lock" when going reverse/backwards (negative)! Jannes20 Archives 2 Tue 28 April 2015 21:53
Starting out to actually cut something - cutters, speeds, depths, directions, etc. Richards General - MM Operating 22 Tue 09 July 2013 04:02
Inspired to go forward - Maine framerman Introduce yourself and start planning 11 Sun 13 January 2013 07:28
Moves at different speeds for different directions - feed rates incorrectly defined Kobus_Joubert Troubleshooting 16 Sun 22 March 2009 06:16
Random pictures at the top of each page. liaoh75 Archives 2 Fri 22 August 2008 09:06
