Old Fri 18 January 2008, 12:38
JR,
I know you have heard it a lot lately about free time, but your work is "craftsmanship" of the highest level and I am often envious of your accomplishment.
The MM you are building is a work of art and the attention to detail makes it even more fun to watch & learn. Additionally, working on the machine - or anything - in the shop is the best hobby and mental therapy I have ever had. ...The hands work, the mind wanders, the finished product is perfect. Nice job!
On a machine note - the bearing post hold down for the Y-car...did you turn the shaft or did you buy pressfit shaft material for the bearing?
I am actually contemplating purchasing a really nice post and Cam follower bearing with the appropriate shoulder bolt for a substitute if I can't get any lathe time in during the next few weeks.
Old Sat 19 January 2008, 11:55
revved_up
Just call me: Craig
Hartland, MI
Originally Posted by J.R. Hatcher View Post
For sale: extra parts (I was making 2 machines but now I'm going to wait).
I have a extra completed Y car, all welded and ready to go. I also have an extra Z w/ everything except the guide wheels and rack. And more. I'll post pictures if anyone is interested.
Gerald if this is breaking the rules of the forum, please delete it.
Have you sold these yet or changed your mind? I would be interested in your parts.
Old Sat 19 January 2008, 12:56
Craig, sorry they were gone the first day
Old Sat 19 January 2008, 17:30
At last, she is wired. I will do a move and cut test sunday.
Old Sat 19 January 2008, 18:46
Sorry Sean just realized there is a question on the table.
I used 3/4" cold roll steel. The shaft was just a little smaller than the bearing so I chucked it up in the lathe used the knurling tool and it became a nice press fit.
Old Sat 19 January 2008, 20:30
J.R.,
Very nice !!
Lots of room in that box. Wondering what your future plans might be.
Old Sat 19 January 2008, 21:46
An old trick, in the absence of knurling, is a lot of center punch marks with Loctite.
Old Sat 19 January 2008, 22:09
JR,
U still got a plenty of space in ur cabinet, how about the fifth and sixth axis
Ur electronics are gonna run really cool with all that space.
RGDS
Irfan
Old Sat 19 January 2008, 22:22
I am a little nervous of the heat transmission through the wooden box - time will tell. Summer is still a long way off for you guys - don't forget to check inside the box on a hot day.
Old Wed 23 January 2008, 22:27
I tried to setup the software today and discovered I have no 5 volt output from the power supply. I'll pull it tomorrow and trouble shoot. So no cuts today
Old Wed 23 January 2008, 22:28
Looks like you really wanted it. Go to bed!
Old Thu 24 January 2008, 12:53
I think the question is "Looks finished, but does it move?" I can now answer that with a positive YES.
1 small problem so far, the e-stop is activating on its own with no button pushed. When it does ............. it stops. Any ideas? There is no pattern, when you click reset it may stay for 10 seconds or minutes.
Old Thu 24 January 2008, 12:57
JR.
Check the PMDX wires that feed the Estop contact on the board.
Excess electrical noise could be causing this. Check the cable routing and see if a little more separation helps. Additionally, in the Mach control setup pages there is a setting that helps Bounce/debounce the signal inputs to the board. I know you can adjust the standard inputs, I'm not sure about the Estop input.
Also, check for an intermittent ground connection on the estop loop that goes to the PMDX.
That's all I can think of at the moment.
BTW - CONGRATULATIONS! That's a HUGE step and kudo's to you! Well done.
Old Thu 24 January 2008, 13:19
It MOVES!!
but then it e-stops
JR, Sean is sending you in the right direction. There is interference which could be a bear to track down. . . . . .
Too few grounds, or too many grounds (both can be culprits). Easy to start checking for too many - disconnect some to see if the problem goes away.
Shielded cables must be grounded one end only (not both ends)
PMDX must not be grounded.
Try plugging computer into same, or different, circuit to the control box.
Shorten E-stop cables by disconnecting some buttons.
Check E-stop wires not inside the same shield as mains wires (E-stop buttons must have two separately shielded cables.
Old Thu 24 January 2008, 15:31
It air cut almost to the end of the roadrunner file before the e-stop kicked in It jogs over 8' in 5 sec. including ramping up and down, it's fast.
It MOVES!!
but then it e-stops
Cables are shielded at 1 end only.
Breakout board only grounded by power supply.
E-stop has it's own shielded wire.
Old Thu 24 January 2008, 15:54
CONGRATS J.R.!!!!!!!! I'm happy for you Bud.
You might consider disconnecting your e-stop circuit from the terminal strip and replace it with a 2 or 3 inch loop of wire so that the circuit is completed and the system will still run. Then cut for a while and see if it will quit on you. At least that way, maybe you can narrow the problem down to either the cable circuit or the control box.
Old Thu 24 January 2008, 17:36
Thanks everyone it was only the debounce setting of 0, set it to 1000 as per Sean and the mach3 forum and it runs perfect.
Ran the roadrunner file 6 or 7 times without any problems whatsoever.
Thanks Doug, it IS music to your ears ............ really
Old Thu 24 January 2008, 17:50
Confession time. The power supply problem last nite was operator error. Wired the 5 volt DC backwards - to + and + to -, didn't seem to hurt anything
Old Thu 24 January 2008, 18:51
Now we're talking. I am glad it was a quick fix! Funny thing about that debounce setting. I often have to debounce all my proximity switches when programming to detect a vehicle on the track. Its really a guess sometimes. I am joyous for you and full of envy that I'm not done yet! Have a great night listening to the sounds of music. P
Old Thu 24 January 2008, 19:00
That was then... What about now? Cutting? Pictures?
Old Thu 24 January 2008, 22:13
Way to go J.R. !!!!
It really is fun watching everyone's progress.
Agree with Marc, more pictures please.
Old Thu 24 January 2008, 23:34
gmessler
Just call me: Greg #15
Chicago IL
Great job J.R......Looks like you might have to take #0000004
Old Fri 25 January 2008, 00:20
Roadkill_321
Just call me: John #7
Wiseton, Saskatchewan
J.R. your work is an inspiration to me. I hope to have a MechMate 1/2 that nice when I am done.
John
Old Fri 25 January 2008, 06:03
I have plans for a video release later today, maybe a pod-cast or a sim-u-cast ............ just joking about the last part, don't even know what they are. If I can figure it out ..... You-tube, I have never uploaded there before.
Old Fri 25 January 2008, 06:11
Greg S/N 0000004 or S/N 0000005 are both easy to say. I just have a hard time with tthhhuuu....rrreee.
Doug I hope you know I'm just having fun with this, and there is no substance to it at all, I'm as proud of your machine as I am of mine....well almost.....
Gerald get your stick pin ready!!!!!!!
Old Fri 25 January 2008, 07:13
Congrats J.R., hopefully you will all start seeing more progress on my machine soon, been gathering bits of steel and other sundry stuff.
All you guys are just making me put more pressure on myself
Old Fri 25 January 2008, 07:54
J. R.
Congratulations and I am eager to see more photos and videos. What do you plan to cut?
Old Fri 25 January 2008, 12:09
I know you are just kidding around JR and I've been enjoying it. However, I wish it wasn't a joke because I'd be more than happy to swap machines with you so you could have SN#00003 and I could have your masterpiece!!!
Old Fri 25 January 2008, 23:02
Nils the first cut was the surfacing of the table. It took 2 passes about .0025 each and now I have a flat table. I tried to upload the video to youtube ...didn't work. I'll try again Saturday.
Old Fri 25 January 2008, 23:31
So it does cut!
JR's rail grinding skate in a Lasered & Bent format for 4.5" grinders Gerald D Rails & Rollers 198 Mon 13 April 2015 20:59
Add one more CNC addict - North Carolina rodom Introduce yourself and start planning 0 Tue 01 December 2009 06:54
She makes dusty MOVES! - North Carolina, USA Jeffn11 Construction started, but not cutting yet 23 Sat 01 August 2009 20:36
Plasma burner started - Albemarle, North Carolina subman Construction started, but not cutting yet 8 Sat 27 September 2008 19:25
One more MechMate starting - North Carolina, USA Bernhard Construction started, but not cutting yet 5 Fri 28 December 2007 16:11
