Thread Tools |
Mounting mechanical limit/home switches
Is anyone willing to share photos of how they mounted mechanical switches.
Hello mark,
I think you mean the proximity switches for homing and limiting. If you check my post in "mechmates already cutting" from rischoof (its the upper one) I posted at 23 januari 2012 some detailed pictures how they are mounted. the height they are installed depending of the specific sensing distance from you chosen sensor. (in my case 4 mm sensing distance) so I installed the 2 mm above the target. then I have enough clearance to avoid collision. |
Thanks for your reply, I'll check it out.
Hello mark,
Did you found the information? The proximity switches have fine size of threadM8*1 or M12*1. They get delivered with two nuts. So you have to drill the hole 8 or 12 mm and use the two nuts to clamp the sensor. By this way of installing the height of the sensor can be easily adjusted |
| Limit Switches - optical / mechanical / proximity | Gerald_D | 70. Control Systems | 333 | Sun 24 January 2016 15:32 |
| Using limit/home switches to autosquare the gantry | Alan_c | 70. Control Systems | 64 | Mon 28 February 2011 09:37 |
| Home switches? | giggler | 70. Control Systems | 4 | Sun 26 September 2010 17:17 |
| Limit / Home switches - Mechanical or Proxy? | fabrica | 70. Control Systems | 44 | Thu 21 June 2007 01:07 |
| What's the difference between Home and Limit switches? | Marc Shlaes | 70. Control Systems | 6 | Tue 19 June 2007 07:46 |
