Old Sat 06 June 2020, 06:33
xraydude
Just call me: Ted #131
New Orleans, LA
1/8" end mill suggestions
Hello, all. I am looking for a decent end mill in the 3mm to 4mm diameter range. 1/8" is fine, too. Needs to have a CEL of at least 22mm. Metric or Imperial shank. 2 flute upcut would be preferred, but as long as it can work 22mm hardwoods at reasonably fast feed I'll try anything. I'm nesting parts in some fairly expensive woods, and it is killing me to use my standard 1/4" mills since I could nest a little tighter and squeak out a few more with a smaller mill.
Thanks!
Ted
Old Sun 19 July 2020, 05:00
Andrew_standen
Just call me: Andrew #109
Dorset
Depending on thick the timber is I use 2 flute fish tail cutters, I buy from Poland but they are made in the USA. 3mm dia on 3.0mm shank 25mm doc.
Take it easy, I cut Black walnut 1mm pass, 20mm thick, result is almost polished.
I use the 1/16" cutters on 16mm plywood with great results.
Just got to take the depth of cut easy.
Also sold by https://cnc-plus.de/en/End-Mills-266...Bits-2978.html
33 3,00 25,00 38,00 3,00 F-30-0103-30-XL
kind regards
Andrew
Old Sun 19 July 2020, 05:22
WFY
Just call me: Buzz #60
Pembroke, Ontario
Router bits
Here is a link to a US company. https://www.centuriontools.com
We have been using their 5mm compression bits and they good for about 36-38 sheets of 5/8" melamine cabinet parts.
Old Wed 22 July 2020, 17:36
xraydude
New Orleans, LA
Thanks for the suggestions guys!
Ted
Profile cutting with cnc mill? esadaddy Profiled (laser cut) & bent steel plate 6 Sat 27 September 2014 20:23
Wide Mouth Mechmate - Suggestions Don_Kellogg General - MM Build 7 Mon 07 May 2012 14:58
Mechmate with turn mill ? jek General - MM Build 3 Thu 23 February 2012 11:32
Mill mat Johannescnc The Market Place 3 Wed 05 May 2010 07:55
Suggestions needed/ laser cut parts ddoggett Introduce yourself and start planning 1 Thu 05 November 2009 06:05
