Old Sat 12 January 2008, 16:07
...still waiting...got the rails done & mounted. Placed the gantry & y-car on the machine. Cool seeing everything together. Boy, it seems bigger in person than it does in the pictures
Old Sat 12 January 2008, 16:47
...and yes, I know I have to trim the rails to length. This is a good example of the overhang needed for the skate to adequately clear the "usable" portion of the rail.
Old Sat 12 January 2008, 18:34
Sean,
Nice looking "beast".
I agree with your "bigger in person" comment. The pictures also don't do it justice.
I guess that's why we are building one.
Old Sat 12 January 2008, 18:55
She's beautiful Sean. You're moving along smartly. Congrats.
Old Sun 13 January 2008, 18:16
cncb
Just call me: Brian
Connecticut
Sean, thats a nice looking blue beast. Its already looking like it wants to make chips fly.
Old Sun 13 January 2008, 19:18
...spent most of the afternoon making end stops, stop brackets, proximity switch holes and cutting down Rack Rail.
- now, if those darn contractions on the end of the phone line would just hold off a couple more days I could get this all assembled!
Old Sun 13 January 2008, 20:44
I think you're going to set the record for the fastest build. I can't believe how fast it's coming together for you. AND you're doing beautiful work.
Old Sun 13 January 2008, 21:01
Doug,
Thanks for the kind words. Heck, I would have been done by now if I didn't have to do my real job all day
I ordered from McMaster friday a 12mm washer and shim kit for the Vee Rollers. On initial set up, it looks like I need about 1.2mm per bearing to get the spacing just right to center up on the rail. Any one else want to share how much space they ended up with between the Vee and rail centerline on both the X and Y axis?
Gerald - do you have a torque spec for the preload on the bearing or do you just "that feel's about right" tighten it up?
Old Sun 13 January 2008, 21:12
Sean,
I'll be happy to measure mine but I don't understand what you mean by "space between the Vee and rail centerline." Can you rephrase it?
Old Sun 13 January 2008, 22:56
Sean, the bolt does not affect the pre-load on the bearing (does not affect the clearance between the balls and raceway)
Old Mon 14 January 2008, 05:20
Sean that's a good looking machine. congrats are in order.
Old Mon 14 January 2008, 05:30
Doug - how much room do you have between the bearing and the end plates?
1 washer, 2 washer, a full jam nut? Just curious. All of my bearings ended up about 1/8" off the plate to adequately mate with the rails. I haven't taken the rails back off the machine yet and painted, thus I will have a chance to reset it all again here very shortly.
Gerald, Thanks for the pre-load answer. It appeared as if there was no affect from tightening the center race fully, or loosely, but I thought I would check.
JR - thanks, getting there...slowly but surely.
Old Mon 14 January 2008, 06:20
The actual amount of space, whether 1/8" or 1mm is a moot point - it depends on many variables. The main point is that there is space and not a foul.
Old Mon 14 January 2008, 10:36
Thanks Gerald. All rolling fine here!
Old Wed 16 January 2008, 15:23
A little motor mounting we go!
Today was mount the motors to the x and y axis day.
*please note, I already know I need to get shorter set screws for the pinions* I know that Gerald's keen eye will miss nothing.
The springs work REALLY well. Once to motors are engaged, there is not a millimeter to be moved - nice
Old Wed 16 January 2008, 17:46
Looking good Sean !!!!!
It's not a race because quality is more important, but your way ahead of my progress. And, it's looking like top notch workmanship.
Old Wed 16 January 2008, 20:06
gmessler
Just call me: Greg #15
Chicago IL
Hey Sean,
Your machine is really looking great! Thanks for the pics. How's the baby situation going????? Has the "stork" visited? Are congrats in order? Tell Tell I'm sure J.R. won't be too upset if you are too tied up.
J.R.
No smoke allowed.... and WAAAAY too much free time. Beautiful job on your "cable runs". You've kind of set the standard here in the States.
Greg J,
I can understand your excitement about your z-plate. I'm going to attempt to grind mine on the (ouch) table saw.....poor thing.....
Doug......pics......what's up
Starting Friday I'll FINALLY get the chance to work on my machine. Watching everybody's progress has been killing me.
Who would have ever believed one man could create such a stir around the world? It's great isn't it?
Old Wed 16 January 2008, 21:58
Yes Sean, I was looking at that set screw, but the rest of the neat job told me it was temporary.
But, it is worth discussing that screw a bit . . . .
- if it is too long, it could foul with the framework above it.
- a "common" problem is that the setscrews come loose. They have to be tightened down really hard with a new allen key. When the allen key starts to bend then the screw is tight.
- Loctite can be used on the screw and the shaft. (Loctite is loosened by heat)
When I unpacked my geared motors today, I saw for the first time that they only have one flat on the shaft. The direct motors have 2 flats 90 deg. apart. I am very tempted to touch a grinder to the motor shaft . . . .
Old Thu 17 January 2008, 05:14
Gerald
I too, may grind another flat on the shaft. At minimum, I ordered the knurl point set screws that "bite" a little better than the standard brad point. Additionally, I didn't feel comfortable with size of set screw the pinions came with 6-32, so I bored up and retapped to 10-32 for comfort.
Sounds like you made it to the bottom of the your care package?
FYI. I ground my rails to 1.25" and was able to still use without conflict the laser cut mounts from the pre-mamba files. I am using 20t pinions. What a great, configurable design!
Old Thu 17 January 2008, 06:19
Yes, I got to the bottom of the box, thanks.
The set-screws bite into the shaft whether knurled or not (shafts are softish non-magnetic steel) - unknurled screws should tighten down harder because less energy is used to gouge the knurl.
The bite marks make it difficult to remove the gear unless that bite is on the pre-made flat portion. This is probably the bigger reason to make the flat spot first - so that the reference round part of the shaft is not damaged by the screw.
I can see your motors hang below level with Mamba rails and older motor plates. Realise that the metric guys with 5/8" square [16mm] racks might not be so lucky to get it all to fit first time.
Old Thu 17 January 2008, 07:13
I do plan on changing to Mamba plates when I make the part run in the couple of weeks. Based on interest, I will most likely run 16-20 sets of parts and keep on the shelf for those in need later on.
Now - its time for baby - this time for real!
...running to car quickly. Sean
Old Thu 17 January 2008, 07:18
Sean,
Time for REAL Baby pictures!!!!
Old Thu 17 January 2008, 07:30
Just remembered that the Mamba motor plates have the same hole spacings. The mod was made on the plates to which motor plates are mounted. ie. gantry ends and y-car sides.
Old Thu 17 January 2008, 19:44
Leko
Just call me: Leko
Kaukapakapa
New Zealand
New baby, not blue!
Just heard from Sean, his new daughter has arrived!
All is well, pink & wiggly. He sounded very happy & tired.
Congratulations!
Old Thu 17 January 2008, 20:05
Congrats Sean,
Do post pictures of new "lady in your life"
RGDS
Irfan
Old Thu 17 January 2008, 20:33
Congrats Sean!!!! Daughters are great.
Old Thu 17 January 2008, 20:40
gmessler
Chicago IL
GO Sean !!!
Congratulations and best wishes.
Old Thu 17 January 2008, 21:49
Congratulations to you and your wife.
Old Thu 17 January 2008, 22:16
Roadkill_321
Just call me: John #7
Wiseton, Saskatchewan
Sean,
Congratulations and all the best to your new addition to the family!
John
Old Thu 17 January 2008, 23:48
Congrats Sean (and missus) thats great news.
Alan
The second MM was easy, but the building's electrics were noisy #28 - Orlando, FL smreish MechMates already cutting 58 Sat 26 September 2020 18:36
Corner finder Rad Racer General - MM Operating 2 Tue 28 May 2013 11:19
Corner finder and cam clamps Rad Racer The Show Room 9 Sun 19 April 2009 10:06
