Old Thu 21 March 2019, 17:34
lukebarber
Just call me: Luke
Miami
Spindle Frequency?
I bought and installed a new 1.5hp water-cooled spindle with an inverter to run it. Inverter is esv112n02yxb . Now whenever I switch the spindle on, it triggers my limit switches (in Mach3) and I can only reset it when the spindle is not running. Would adding a line reactor to the inverter help? Spindle and limit switch wiring is all shielded and properly grounded.
I'm virtually at a standstill. Any help?
Old Sat 23 March 2019, 05:51
What breakout board are you using ? is it optoisolated?
If it is isolated I would first try to connect the PC to the mains with small line filter.
also check if everything is properly grounded , if the vfd has internal emc filter try disconnecting it , this was known to make me problems with control techniques vdf
Old Sat 23 March 2019, 19:36
I had to put the VFD on a separate earth to
the computer and machine.
Hope this helps.
Variable Frequency Drives VFD's for spindles Gerald_D 702. Power Supplies 14 Tue 24 March 2009 14:48
Delta Variable Frequency Drive VFDB series - (for the spindle motor) Gerald_D 701. Motor Drives 8 Tue 25 November 2008 11:08
