Old Wed 30 January 2019, 01:42
iclazion
Just call me: Leonard
Pretoria
South Africa Nema 34, rack and pinions and bearings
Total R24000 Zar
-4 x Stepper motor Nema 34 WT86STH118-6004A 5.6A 8.7N-m(1232oz-in) 99mm
-4 x Stepper motor driver DQ860MA 7.8A 80V 256 micro-steps
-4 x Power supply : 350W 60V
-1 x Pc breakout board and cable + Extra set
-16 x W3X bearings
-4 x 2m module1 racks
-4 x Module1 22 teeth pinions
Contact me for more information or if you need more specifications or wiring diagrams?
Please note this is the last set, so first come first serve.
Kind Regards
Leonard v.d. Merwe
072 779 7237
[email protected]
Old Wed 30 January 2019, 02:37
iclazion
Pretoria
Some more information:
Stepper Motor Specifications:
Step Accuracy = ±5%
Temperature Rise = 80°C Max
Ambient temperature Range = -20°C—+50°
Insulation Resistance = 100MΩMin.500VC DC
Dielectric Strength = 500V AC 1 minute
Step Angle 1.8°
Rate Voltage 3.08V
Rate Current 5.6A
Phase Resistance 0.55Ω
Phase Inductance 5.5 mH
Holding Torque 1232 (OZ-IN)
Stepper Motor Driver:
High performance
Average current control, 2-phase sinusoidal output current drive
Supply voltage from 24VDC to 80VDC
Opto-isolated signal I/O
Overvoltage, under voltage, overcurrent, phase short circuit protection
14 channels subdivision and automatic idle-current reduction
8 channels output phase current setting
Offline command input terminal
Motor torque is related to speed, but not related to step/revolution
High start speed
High holding torque under high speed
Input Voltage 24-80 VDC
Input Current < 6A
Output Current 2.8A ~ 7.8A
Consumption : 80W; Internal Insurance 10A
Working Temprature -10~45℃
Stocking temperature -40℃~70℃
Weight 500G
Old Mon 04 February 2019, 00:05
iclazion
Pretoria
Price from 04/02/2019 is R16000
Old Sun 11 October 2020, 15:09
WhiteKnight
Just call me: Roelof
Alberton
Is this still for sale?
Hi there, im also in SA, is this still for sale?
Newbie from South Africa Anscheepers Introduce yourself and start planning 9 Sun 04 March 2018 22:10
Hi my name is mohamed from south Africa mohamed Introduce yourself and start planning 6 Wed 25 June 2014 06:17
CNC IMPORT South Africa Kobus_Joubert The Market Place 5 Sun 27 June 2010 12:36
"High tech" Rack and pinions Nexengroup Pierre GRAND Archives 12 Fri 25 January 2008 06:17
Buying rack & pinions in South Africa JanJC Archives 1 Tue 16 October 2007 23:41
