Old Sun 28 October 2018, 10:09
sphericos
Just call me: David
Suffolk
Chinese Spindle Issue
This is just a heads up to anyone else who comes across this problem. My 3kw air cooled Chinese spindle has run reliably for 3 years until a couple of days ago when in the middle of a rush job it stopped spinning. It was making noise and varying the frequency would alter the noise but the spindle was only making feeble efforts to turn. I was all set to order a new spindle but delivery was going to be about 10 days for a reasonably priced one. I had checked all my wiring for continuity but as a last resort I dismantled the connector on the spindle. It turned out one of the wires had worked loose as they only use screw terminals.
Old Sun 04 November 2018, 07:35
digger
Just call me: Milosh #113
Toronto
Just to add my comment. I changed the connector and found that grounding pin is not connected at all - 3kw air cooled spindle.
Milosh
Chinese 4Kw Air Cooled Spindle Dimension Surfcnc 50. Toolheads 6 Wed 05 February 2014 18:05
Update on new Chinese Water cooled Spindle waynec 50. Toolheads 84 Sun 01 January 2012 21:31
Chinese 300Hz spindle BartDeckers 50. Toolheads 6 Thu 29 December 2011 13:41
Chinese 2.2kw Spindle and Mach3 Radishworks 50. Toolheads 14 Tue 11 January 2011 09:53
