Old Sat 27 October 2018, 18:48
David Bryant
Just call me: David #99
Western Australia
Added Fourth Axis
Hi
I dusted off the Mech Mate, It was desperately in need of some maintenance as I would not oil any of it while cutting fiberglass as the risk of contaminating the work was so great.
I have put a small rotary axis off the end of the table, Many years ago I built it longer than the standard 2.4m sheet so I could do things like this. This puts the rotary axis down the Y axis so a "B axis". My screen layout on Mach 3 has 4 DRO's labelled X Y Z 4 I worked out that 4 is A by default, ie a rotary on the X axis. Does anyone know how to change this to read B axis?
I initially tested with it being A then realised it is actually a B axis. Are (cheap / free) wizards available for gear cutting on B axis?
Any suggestions on how to set tool to zero on centre of rotary axis?
David
Old Sun 28 October 2018, 03:38
David Bryant
Western Australia
Thanks for the hint search turned up
https://www.youtube.com/watch?v=3e94UGi_F5g
with the link to MachScreen
I then edited 1024.set and got the OEM Zero B and DRO B installed on my first page.
wont say how long it took...
Old Wed 24 July 2019, 05:03
David Bryant
Western Australia
Storm with lightning and now the computer wont start..
So I went for the old back up.. it boots but no output to monitor
I am thinking of ditching the parallel port and BOB switching to a cheap USB to stepper driver from Bitsensor.com
BSMCE04U-PP
Has anyone used this on a Mechmate?
Any heads up on getting it going in English?
David
Old Wed 24 July 2019, 05:41
Hi David
Hope you are having some good times on that fast boat of yours.
A solution to the "no parallel port problem" that works perfectly is the UC100.
I have no experience with the board you name but it primarily looks like a USB breakout device (could be wrong).
The UC100 allows you to still access cheap parallel port breakout boards (or use your existing one).
Additionally, the motion controller that is built-in will provide far superior pulsing as it offboards that from the PC.
The UC100 and laptop solution worked very well on a surfboard shaping machine I helped build, ran for many years daily using that combination.
The downside is that the specifications are lower than something like a smooth stepper. It is unlikely you would be pushing the machine fast enough to come anywhere near these limits.
When spending your money it pays to remember that the device is much more than a USB break out device.
Surf CNC
Motors turning! (under EMC) - Perth, Western Australia shaper Construction started, but not cutting yet 25 Thu 14 November 2024 05:30
The incredible cheap build is building boats #31 - Western Washington, USA lumberjack_jeff MechMates already cutting 93 Thu 22 September 2011 22:17
New Build Planning Stages/Pricing - Perth, Western Australia rwo Introduce yourself and start planning 21 Thu 13 May 2010 04:28
Hi from Troy ,VIC ,AUSTRALIA i plan on building a MechMate conceptz Introduce yourself and start planning 20 Mon 07 September 2009 02:33
Starting - Perth, Australia rhoads56 Construction started, but not cutting yet 10 Sun 28 September 2008 06:13
