Old Wed 25 April 2018, 11:53
jeep534
Just call me: archie
prichard, wv
Dave
way to go, Progress
I would route a 10 inch square and measure it
Happy Hunting
archie
Old Fri 27 April 2018, 07:44
IamDave
Just call me: Davey
Ball Ground, GA
Yes. Good idea. I am going to do that next. Then check the accuracy. Got to go climb a little this weekend with the sun showing up. Thanks.
Old Fri 27 April 2018, 11:47
jeep534
prichard, wv
next i would route a ten inch circle those should be really telling
archie
Old Fri 27 April 2018, 11:51
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
No, to get gantry square you must cut square as big as is possible. On bigger one you find errors more easylly.
Old Fri 27 April 2018, 17:28
IamDave
Just call me: Davey
Ball Ground, GA
Okay I used a 49 x 48 x 3/4 piece mdf for a temporary spoil board. . I squared the front with the gantry using a 1/4 inch endmill.. Then setup a cut file to square it all the way around to 48x48 it traveled 3 sided with slight removal on 1 corner. I ended up with a 48 x 47 7/8 square. Found 1 high spot on the bed on one side. Cut a 12x12 square. cut fine the piece was just under 12 inches square. Next time I allow offset 1/8 inch. Setup to cut 48 x 48 x 1 inch piece of Extira. (About the same as mdf)) Both motor on x axis sheared the allen key and started turning free. I used titebond on them when I tightened. I will remove and add keyed shafts and gears.
Old Sat 28 April 2018, 01:32
ifffff
Parnu
Estonia
Thumb rule on cnc build is what joint is suspicious, that will one day make problems.
http://www.mechmate.com/forums/showthread.php?t=5626. Good is that it came out on testing, not by ruining some expensive material.
Old Sat 28 April 2018, 17:13
IamDave
Just call me: Davey
Ball Ground, GA
I know. I read, and read. I knew that people had, had problems. I got over excited to see it moving.
Old Tue 01 May 2018, 06:04
I moved you to MechMates Already Cutting!
So you say your table stripped both x axis set screws?
Make sure the hole on the gear truly matches the shaft size.
Also make sure your springs are not too tight and creating to much resistance.
Old Tue 01 May 2018, 06:29
IamDave
Just call me: Davey
Ball Ground, GA
Thanks. I am working to get the geared motors now. I am sure, once I get my motors geared and tuned correctly, all will be well. I am just happy as heck I was able to get this far, with as little experience at building I have.
Old Tue 01 May 2018, 08:20
IamDave
Just call me: Davey
Ball Ground, GA
What I am going to do to fix my allen screw problem, is drill slightly into the shaft on the square, a small hole. I am going to use longer allen set srews to prevent slippage. Note to self: Next time buy the stepper motors, and gears with keyed shafts.
Old Tue 01 May 2018, 12:29
ifffff
Parnu
Estonia
It wont work. You may try fix screw on round side. How tight are gears on shaft? Can you install them with bare hands? If they are too loose you may try fix them with glue. Loctite 648 for example.
Old Tue 01 May 2018, 22:07
IamDave
Just call me: Davey
Ball Ground, GA
The gears are pretty snug on the shaft. I was able to get one side off easy. The other one I used a brass punch and put the shaft in the vise to beat it out. It had a groove made around it. I used Loctite on them when I put them on.
I was probably moving to hard, and fast against 1 inch material with the smaller router.
But it didn't break the bit...
Old Wed 02 May 2018, 01:11
ifffff
Parnu
Estonia
Dont use beating and steppers in one sentence. It does not end well. Use puller.
Old Wed 02 May 2018, 06:25
IamDave
Just call me: Davey
Ball Ground, GA
Ha! No it might not. I did not have small pullers.
Old Thu 03 May 2018, 08:03
IamDave
Just call me: Davey
Ball Ground, GA
Is there anyone on here, that cuts 1" and 1.25" Extira on a regular basis, with a MechMate? I cut between 100-300 sheets a year. Just wondering.
Old Wed 09 May 2018, 15:25
IamDave
Just call me: Davey
Ball Ground, GA
Okay 2 -3 days of learning. Apparently during the motor deal, I damaged one of the drives through feedback without blowing a fuse. Support is great there. They are going to look at it and repair. The drives tech manual has a good flowchart and easy to follow.
Old Sat 19 May 2018, 08:47
IamDave
Just call me: Davey
Ball Ground, GA
If anyone is using the PMDX134 board, and experience problems, that do not make sense. Replace the 25 pin ribbon cable. Maybe it will solve your problems, as it did mine.
I believe this, to also be the reason the slaved motors on my X Axis acted strange and as so caused the pinion gear to come loose. Now everything fine.
Old Sun 20 May 2018, 21:02
Glad to hear that you isolated your issue! That is a strange problem for sure. So you are planning to continue with direct drive now that you fixed them?
Old Sun 20 May 2018, 23:10
IamDave
Just call me: Davey
Ball Ground, GA
No sir. I think I want to go with geared steppers now. I also am going to add the smooth stepper. (Because that fast movement, back to zero scares the ^v^ out of me.).
Old Tue 07 August 2018, 19:23
wiifm
Just call me: Dennis
Cairns
Thanks for this tip. Saved me from pulling my hair out.
Old Fri 19 October 2018, 08:07
IamDave
Just call me: Davey
Ball Ground, GA
Here is a video from Oriental Motors, concerning cooling fans over
electrical components. Some might find useful.
https://www.orientalmotor.com/coolin...6-b0ca66b72420
Old Wed 21 November 2018, 18:41
IamDave
Just call me: Davey
Ball Ground, GA
2.2 Kw Spindle Finally
Just got a 2.2 kw water cooled spindle and vfd for an upgrade. The Porter Cable worked fine for plywood and long curves. We'll see how it goes.
Happy Turkey Day to all tomorrow.
Old Wed 21 November 2018, 19:36
Installed one of them not long ago.
Bit of a trial but it is working now.
Make sure you use shielded cable.
Have fun.
Old Sat 24 November 2018, 13:49
ifffff
Parnu
Estonia
And put that VFD on separate grounded metal box. It generates huge amount RF noise. If i open my VFD (of course when spindle is running) enclosure door, then computer keyboard what is about 50cm of VFD stops working.
Old Tue 27 November 2018, 14:04
IamDave
Just call me: Davey
Ball Ground, GA
Thank you for the pointers Al and Ivo. I ordered robotics grade cable for the VFD to motor, and I am going to mount the VFD in a panel.
Old Tue 05 March 2019, 07:16
IamDave
Just call me: Davey
Ball Ground, GA
Mike, hope all is well your way. I see the tornado damage, around you is terrible.
Old Fri 07 June 2019, 18:23
IamDave
Just call me: Davey
Ball Ground, GA
2.2kw spindleupdate
The spindle, I got online works well. It has out performed the 7518 Porter Cable significantly. A little hassle learning to solder the connection, to the motor, and wire the VFD, but not a large learning curve. Now less dust and noise, has made a big difference over the last few months cutting.
Old Sat 08 June 2019, 19:38
+1 on the spindle.
I installed one last year, very happy with it.
Old Fri 08 November 2019, 17:17
IamDave
Just call me: Davey
Ball Ground, GA
Updating Control Panel
Installing a new control panel, I got from Mike.
Purchased a set of Drill Hog Bits off ebay, to drill the holes.
So far so good. Looks way better than the 12x16x8 I had on it.
Old Tue 12 November 2019, 06:26
xraydude
Just call me: Ted #131
New Orleans, LA
Looking good, Davey. I have the same enclosure from Mike. I went with some massive heat sinks and internal fans, with no intake or exhaust ports, but I think I may have to add ports for fresh air. Im able to keep the driver temps below 50C with everything buttoned up, but it will drop by 13C if I crack the door. Just not getting quite enough thermal transfer through the enclosue walls. Did you put any filtration on the intake side?
Ted
Ball Screw For Sale Francois The Market Place 1 Tue 07 February 2012 00:25
Ball screws Richards Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 1 Sun 28 August 2011 08:31
hobbed or ground rack? southernduckie Rails & Rollers 11 Thu 26 May 2011 09:36
Stepper motors giving trouble - Motors burnt while serving as ground for elec. fault Daya Troubleshooting 45 Mon 21 April 2008 02:05
Round shafts & ball slide blocks versus V-rails & V-wheels joepardy Rails & Rollers 28 Fri 07 December 2007 13:41
