Thread Tools |
Anyone ever built a 5 axis router
Not sure where to put this so if it is in the wrong area, please excuse.
I have been looking at a lot of 5 axis CNC router builds and was wondering if anyone here has put the two additional axis on a MechMate. I did a search for 5 axis and nothing came up. I can see where some have discussed a four axis machine. I was particularly looking to have the 4th and 5th axis mounted to the Z axis slide. I did not want to have some added device mounted to the table or elsewhere. Just wanted to see what might have been done by those building (have built) MechMates Dan |
Some of us have built 4th axis (rotary) and at one point talk of a 5 axis but I'm not sure if anyone has posted anything recently. I suggest taking a look through the builds.
I think there's a 5 axis machine here somewhere, but it's a plasma cutter.
Build and add a trunion and you have your 5 axis machine however the software to program one is extremely expensive. That is most likely the reason you have not seen one. A multi-positional head creates some dynamic forces that I think would require some engineering to the current model design.
4axis yes - 5....I found that it was cheaper and easier to buy a used Funac or other Robotarm for the same use.
I tried it, and like the other posters said,
The problem is the high cost of software, Getting Delcam or mastercam to program a custom Kinematic post processor is very expensive. definitley not hobby grade |
| Built laser using buildlog.net | sailfl | General - MM Build | 8 | Tue 19 December 2017 19:08 |
| And another MM will be built in Belgium | bramvh | Introduce yourself and start planning | 9 | Fri 15 April 2016 15:01 |
| 5 axis mechmate router? | bluek20 | Introduce yourself and start planning | 11 | Fri 06 May 2011 17:43 |
| "Weak" z-axis won't plunge cutter - router turned off | javeria | Troubleshooting | 30 | Sat 14 November 2009 08:10 |
| Two MM's being built in Delavan, WI and McHenry, IL | Delamination | Construction started, but not cutting yet | 34 | Mon 19 January 2009 08:32 |
