Old Tue 10 October 2017, 07:49
Yeah, there's some not super helpful info around, like http://wiki.linuxcnc.org/cgi-bin/wik...d_Limit_Switch but first you need to be comfortable with editing the config files.
I'm not near my MM at the moment to pull the files, but for me, the standard MM limit sensors are configured for homing, as is a Z zero plate.
My process after firing up the machine, using keyboard shortcuts is:
"X" - "Home" - "Y" - "Home" which starts the machine zeroing off the switches on both
axis. That's done once to set the machine zero. Then for each workpiece:
Jog to the 0,0 reference point on the work, and bring the tool about an inch above. Place the zeroing plate on top of the piece. "X" - "End" - "0" - "Enter" "Y" - "End" - "0" - "Enter" "Z" - "Home" - "End" "0" "." "2" "5" "Enter" - Since the zero plate is 1/4" thick.
If you're getting a persistent alarm, I would expect that either the machine zero is not set, or the machine limits are too small. Have you homed each axis before you start?
Old Tue 10 October 2017, 19:06
Thanks Brad.
I had to give up after 2 days.
Went back to Mach to get a couple of jobs done.
Will try again later today.
I cannot get it to reference, persistent 'exceed soft limits' alarm.
It also locked up, would not jog.
I knew it would not be an easy job to get it to work
but I didn't think it would be this hard.
I suppose a Degree in computer programming would help.
Pages of documentation but no idiots guide.
Oh well, on with the war.
Old Wed 11 October 2017, 02:07
It works
References.
Reversed Scale, Home velocity and Switch polarity.
G30.1 set.
A big relief.
Brad, can you please explain what I should type please.
Is it exactly as you have typed on 3 separate lines?
Old Wed 11 October 2017, 02:19
Brad, another question.
I have a laser crosshair I use with Mach to set the G54.
If I jog the cross over the 0,0 position can I type in the X and Y offset values in the lines of code you supplied and would that set the work zero position ?
I hope this helps others in the future.
Thanks for your time.
Old Wed 11 October 2017, 20:05
Yes, "X" means the X key on the keyboard - same for all the others. And yes, if you have the cross hair over your 0,0 then "X" "End" <offset> "Enter" and "Y" "End" <offset> "Enter" sets up your work zero position.
Glad you are making progress
Old Thu 12 October 2017, 03:43
Thanks again Brad.
I ran a program today.
No problem until the end.
There was a ' Finished with no percent' error.
The % was there though, no big deal.
Now the big problem came when I tried to run op2.
I touched off in Z, save the offset.
'Exceed limit' error.
I could not do an MDI input as it was not referenced.
Z referenced ok but the x went the wrong direction.
Turned it off and back on, same result.
The only way out was to turn off, change the sign of home speed and turn back on again.
Then I had to do this.
3. So if you're lost, what should you do
Having trouble getting 0,0,0 where you want it for your gcode Start by getting rid of all the sources of offsets
Move to the machine origin. MDI G53 G0 X0Y0Z0 (A0B0C0)
Clear the G92 coordinate offset. MDI G92.1
Use the G54 coordinate system. MDI G54
Set the G54 coordinate system to be identical to the machine coordinate system. MDI G10 L2 P1 X0Y0Z0 (A0B0C0)
Turn off tool offsets. MDI G49
Turn on Relative coordinate display from the menu
now, you should be at machine origin (0,0,0), and the relative coordinate system should be the same as the machine coordinate system. You can now set your origin on the material.
I then could set another tool.
The same thing happened for op3.
A bit sick to say the least.
What am I missing ?
Old Thu 12 October 2017, 04:09
Start of program.
G21 G40 G49 G64 P0.03 M6 T1
G17
M7
G0Z25.000
G0X0.000Y0.000S8000M3
End.
G0Z5.000
G0Z25.000
G0X0.000Y0.000
M2
OK or is there something missing ?
Old Thu 12 October 2017, 07:51
Hmm. I haven't seen that. For the "no percent", try making sure there is a blank line at the end of the file, after the percent. If there is no line ending, it may not be seeing the percent there.
The start and end of program look just fine. I assume that you ended up back at the home position after the first job. A couple of things that might trip you up:
When you are setting up the offsets ( with the "END" key ), what you are entering is where the tool is currently with respect to where you want it to be in the coordinate system. So if you have two jobs next to each other, 400mm apart on the X axis, and you setup the one closest to machine origin, run it, return to 0,0 and then use "X" "END" to adjust for the second job, you will enter -400 since the tool is currently at that position in the new coordinate system you are setting up. If you enter 400, and you are within 400 of the machine limits, you would see an error. That's one possibility for confusion.
Also, from that same manual page:
5. Other reasons for nonzero coordinates at start
If you specified [TRAJ]POSITION_FILE, the contents of that file are read at startup and define initial axis positions.
To forget these values once, exit LinuxCNC and remove the file. To never store these values, remove the POSITION_FILE line from your inifile.
I suspect you do have this file configured, which is why power cycling doesn't solve your problem - it's saving and rereading the current settings.
Old Thu 12 October 2017, 20:41
I deleted the Traj file in the .ini file.
When I started the control it threw up an error and would not start.
I loaded the backup .ini then it started.
There is no 'Position' line in the Traj section to delete.
Old Thu 12 October 2017, 23:25
I must admit that I am totally lost, confused and sick with the toolsetting.
Same procedure as yesterday.
Op1 ok, looks as if putting in a blank line at the end worked.
Op 2 set the tool. Run, exceed limit error, run anyway.
Program runs then cuts out halfway through, exceed limit error
Clear all using the procedure from that manual page.
Reset g54, reset tool, run, exceed limit error.
Attached picture of the screen.
All looks ok and the machine is in the correct position.
Must be Friday the 13th part 365 again.
Old Fri 13 October 2017, 09:30
So, what are your machine limits? Which limit was exceeded? Z? I'm guessing that because of the red box at the lower limit of the Z axis on the display, and because you were apparently happy with how it was running until halfway through, and because you say the machine is in the correct position.
If it was Z, then we need to figure out why you aren't getting the right touchoff settings on your second piece. Is your gcode indexed to the top or bottom of your piece?
Here's how I would approach it. Let's assume a 50mm high workpiece, an overcut into the spoil board of 1mm, and jogging clearance of 10mm above the piece.
If it's indexed to the top of the piece, then the touchoff is at 0mm, top of piece at 0mm, jogs at 10mm, the bottom of the piece is at -50mm, overcut is at -51mm, and the Z limits need to be at least -51mm to +10mm.
If it's indexed to the bottom of the piece, then the touchoff on the spoilboard next to the piece is at 0mm, or the touchoff to the top of the piece is at +50mm. Top of piece at 50mm, Jogs at 60mm, bottom at 0mm, overcut at -1mm, Z limits must be at least -1mm to +60mm.
Of course, if it's not Z yelling at you, ignore all of that.
Sorry if I confused yesterday on the Traj file; I was just trying to explain why it did not reset on reboot.
Old Fri 13 October 2017, 19:51
Hello Brad.
Limits are X 1200mm, Y 700mm and Z 150mm.
All set as minus in the .ini file.
It was the X axis that alarmed.
I can run the first tool, the problem occurs when the second tool is set and run.
Ok, its 8a.m. I turn on the computer, load the control, power up the control box and press the orange button, motors engage.
Reference all home.
Jog the tool to job datum in X and Y. Press touch off X and Y(G54 now set)
Jog the tool in Z until it touches the job, press touch off Z.
Jog up in Z, load the Op1 program and run.
Program complete.
Change tool. Jog the tool in Z until it touches the job, press touch off Z.
Jog up in Z, load the Op2 program and run.
Alarm message, 'exceed limit in z , run anyway?'
I say yes and carry on.
Program runs for a while then alarms, 'next line will exceed limit'
Program stopped.
Jog up in Z. Press Ref all home.
Z moves up ok.
X moves in the wrong direction. Press e stop, press power on.
Try to do a MDI but alarm, 'Cannot Mdi when not referenced'
Change X jog speed sign in .ini.
Ref all home.
If I then go through the whole procedure again to run op2, ALARM.
'Exceed limit in X'
Are my steps to set the G54 and the tools correct?
If not feel free to call me an idiot and please explain the error of my ways.
Old Sat 14 October 2017, 09:43
Okay, that's all really weird. Can you post or PM me your .ini file so I can go through it?
Old Sat 14 October 2017, 18:55
.hal file.
# Generated by stepconf 1.1 at Tue Oct 10 12:00:00 2017
# If you make changes to this file, they will be
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
addf parport.0.read base-thread
addf stepgen.make-pulses base-thread
addf parport.0.write base-thread
addf parport.0.reset base-thread
addf stepgen.capture-position servo-thread
addf motion-command-handler servo-thread
addf motion-controller servo-thread
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm <= motion.spindle-speed-out
net spindle-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-cmd-rps <= motion.spindle-speed-out-rps
net spindle-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-at-speed => motion.spindle-at-speed
net spindle-on <= motion.spindle-on
net probe-in => motion.probe-input
net xdir => parport.0.pin-01-out
net spindle-on => parport.0.pin-02-out
net zstep => parport.0.pin-03-out
setp parport.0.pin-03-out-reset 1
net xenable => parport.0.pin-04-out
net xenable => parport.0.pin-05-out
net zdir => parport.0.pin-06-out
net ydir => parport.0.pin-07-out
net ystep => parport.0.pin-14-out
setp parport.0.pin-14-out-reset 1
net xstep => parport.0.pin-16-out
setp parport.0.pin-16-out-reset 1
net xenable => parport.0.pin-17-out
net home-x <= parport.0.pin-10-in-not
net home-y <= parport.0.pin-11-in-not
net home-z <= parport.0.pin-12-in-not
net estop-ext <= parport.0.pin-13-in-not
net probe-in <= parport.0.pin-15-in
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 50000
setp stepgen.0.dirsetup 50000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
net home-x => axis.0.home-sw-in
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 50000
setp stepgen.1.dirsetup 50000
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
net home-y => axis.1.home-sw-in
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 50000
setp stepgen.2.dirsetup 50000
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
net home-z => axis.2.home-sw-in
net estop-out <= iocontrol.0.user-enable-out
net estop-ext => iocontrol.0.emc-enable-in
loadusr -W hal_manualtoolchange
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
Old Sat 14 October 2017, 18:59
.ini file
# Generated by stepconf 1.1 at Mon Oct 9 12:38:21 2017
[EMC]
MACHINE = my-mill
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 10.00
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 100.00
INTRO_TIME = 5
PROGRAM_PREFIX = /home/alan/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image
PROGRAM_EXTENSION = .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = my-mill.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 10.00
MAX_VELOCITY = 100.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = -0.25
MAX_ACCELERATION = 250.0
STEPGEN_MAXACCEL = 312.5
SCALE = 22.143
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -1200.
MAX_LIMIT = 0.0
HOME_OFFSET = -0.25
HOME_SEARCH_VEL = -10.
HOME_LATCH_VEL = 1.00000
HOME_SEQUENCE = 1
[AXIS_1]
TYPE = LINEAR
HOME = -0.25
SCALE = -22.143
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -700.
MAX_LIMIT = 0.0
HOME_OFFSET = -0.25
HOME_SEARCH_VEL = -10.0
HOME_SEQUENCE = 2
[AXIS_2]
TYPE = LINEAR
HOME = -0.25
MAX_VELOCITY = 41.666
MAX_ACCELERATION = 150.0
STEPGEN_MAXACCEL = 187.5
SCALE = -22.143
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -120.0
MAX_LIMIT = 0.00
HOME_OFFSET = -0.25
HOME_SEQUENCE = 0
Old Sun 15 October 2017, 11:55
Hmm. I'm fairly suspicious of those negative axis limits confusing things. I would have expected MIN_LIMIT = 0, MAXLIMIT = (1200, 700, 120), HOME_OFFSET = (1199.75, 699.75, 119.75)
Old Sun 15 October 2017, 19:20
I will change them and give it a try.
Wonder what that will do to the other settings.
Thanks.
Old Mon 16 October 2017, 01:18
Sorry Brad but that didn't work.
The axis overshot the switch and hit the hard stop.
Not to worry.
The good news is that I got it to work
I had a thought in the small hours.
Was it hanging on to an offset ?
So I put a G49 at the end of the program.
G0Z5.000
G0Z25.000
G49
G0X0.000Y0.000
M2
(Blank space after %)
Now it works.
I think the reason it was referencing in the wrong direction was the switch was sticking.
Must change it and see.
Thank you for your time and effort.
I might make a PDF about this and post it on here.
It might help someone in the future.
Old Tue 17 October 2017, 09:36
Hey, glad you got it sorted!
Old Wed 18 October 2017, 03:40
Well the final piece of this particular jigsaw
clicked into place today.
I got the touch plate to work.
So now I have the functions I had with Mach.
Its been a struggle though.
The reason why I changed?
Earlier on this year I thought the control board was faulty,
so I replaced it.
A few weeks ago I was having a similar problem, one axis was not moving.
Tried a new motherboard, same result.
The same thing happened on 3 different computers.
Also the driver would not load on 2 computers.
I proved it was not the control board by swapping motor wires.
Same with the parallel cable.
Must be something with the software.
I got round it for a while by using the A axis for the X.
I still have the driver board, maybe it was ok after all.
I had a look for alternative software.
Mach 4 does mot use the parallel port so a separate driver is required.
Also there has been a lot of discussion about how reliable it is.
There was another program but I did not like the look of it.
That left Linux.
New, supported and free.
Thats why.
Old Sat 21 October 2017, 03:45
Pdf
Here is the PDF, warts and all.
Hope it helps you.
Old Sat 21 October 2017, 06:30
Thanks, Al. You are and have always been an "exceptional friend" of the forum. Thanks again.
Old Sat 21 October 2017, 09:30
Thank you for taking this information to the next level.
Old Mon 23 October 2017, 02:49
Cheers John,
you've made my day.
Old Mon 23 October 2017, 06:59
Thank you as well Jack.
Wise words in your original post.
'EMC2 configuration can be a little more challenging than Mach3. I would suggest staying with Mach if that is where you are now. If you are into learning or doing a DIY (or have really strange things you want to do then EMC2 can be your toy.'
It was challenging and strange but I had to do it.
Its working well at the moment.
Old Tue 24 October 2017, 06:07
racedirector
Just call me: Bruce #122
New South Wales
Chiming in late on this one but your next step Al is getting Pathpilot to run your machine
Old Tue 24 October 2017, 07:06
Hi Bruce.
Where have you been ?
Whats a Pathpilot?
I just need a younger me
Old Thu 26 October 2017, 06:31
racedirector
New South Wales
Hey Al
Just been working too much and not doing enough with my machine
Pathpilot is Tormachs version of Linuxcnc, they use icon their machines. Think of LinuxCNC with a very pretty face. It runs my big red beast at the moment.
Old Sat 28 October 2017, 15:47
sphericos
Just call me: David
Suffolk
I use LinuxCNC and I never installed my limit switches. I have never needed them. I home the table every time I reboot the computer and providing the tables limits are set there is no reason it should crash into an end stop unless you miss steps somewhere.
Old Sun 05 November 2017, 00:06
On the subject of Pathpilot,
I came across these videos.
Not watched them all yet
but they look pretty comprehensive.
https://www.youtube.com/watch?v=K-Ty...ovJXhfDcX50Otd
