Old Mon 11 September 2017, 12:24
Jrllee
Just call me: Jr
Ontario, NY
Need some MM plan info before spending $ for the plans
Gentlemen: I am new to this site and I am hoping someone can give me some insight as to the MM plan specs for guide rail extrusion sizes for the 3 axis as well as linear guide tyspecs before I Layout the cash for the plans. I would like a little more info before spending the money. I am currently considering the CNCrouter parts kit.
I am a custom cabinet shop dealing with kitchens, bathrooms, entertainment centers and hoping to get into fireplace mantels. I currently use eCabinets software which is only useable for Thermwood CNC machines which are out of my price range. So I am going to need to deal with new software that will enable me to generate a cutting file as well as realistic renderings for customer presentations. Fusion 360 and Aspire are being considered and any thoughts/input is appreciated.
Jr
Old Mon 11 September 2017, 17:00
There's a lot of information in the base table section
The MechMate is a welded steel design using standard structural shapes, and in the base design, V wheels, not linear guides. The rail for the V wheels is either custom ground by you, or bolted on. There are linear guide versions that folks have built, but that is not covered in the plans.
You will need to be comfortable with basic steel work, including cutting, welding, grinding, shimming; none of it is super difficult, but it isn't a bolting extrusions together kind of project. The benefit in the end is a heavy, stable device.
Old Wed 13 September 2017, 05:22
You want to see a MechMate in action doing cabinets look up Kornerking.
As far as the guides, the V rails work great. Don't fall into the thinking that you MUST have linear rails because the high cost machines do. That is one reason they have a high cost.
Old Fri 15 September 2017, 22:14
digger
Just call me: Milosh #113
Toronto
Check out Polyboard software. It is parametric and is able to generate dxf...
Milosh
Gettin a plan - Gresham, OR lintechnical Introduce yourself and start planning 4 Tue 14 March 2017 07:29
Workin a Plan - Lapeer MI USA Jasonmm92 Introduce yourself and start planning 29 Wed 28 December 2011 16:26
Staring to plan my first build erich Introduce yourself and start planning 3 Fri 30 April 2010 07:10
Plan Question Tim655 General - MM Build 20 Thu 25 March 2010 08:18
