Thread Tools |
I have acquired an Spencer Vortex Blower Model # VB- 22G-U. 220V
I need help with the wiring, I have 9 & 3 together, 8 & 2,together, 7 & 1 together, 5 & 6together P and P are loose. Can anyone assist with correct wiring? |
What are you hooking it to? Single or 3 phase, 110 or 220?
I was looking to use it for another vacuum system. I have single phase, so I would have to use a converter. It is already wired for 220 3 phase, but the two wires labeled "P" I don't understand.
if it is 3 phase motor and you have a single phase supply you will need an inverter that is capable of single phase input. Depending on the size of the motor will determine the price of the VFD.
That is correct. I have an inverter, but the P/P was confusing me. may be a pilot lamp. thought it might be some kind of a fuse. wasn't sure.
Actually, according to the diagram on page 3 of that PDF, P/P is labelled "Thermal Protector" and appears to be a Normally Closed thermal protection device inside the motor, which presumably goes open if the motor overheats. It is shown wired into the contactor hold in loop along with the Stop switch. The pilot lamp is simply in parallel with the coil of the contactor.
So P/P should normally complete a circuit, and if it opens, you should have the motor stop. |
I think Brad has found the right solution.
Thanks guys, that helps a lot.
| peerless blower | alan254 | The Market Place | 0 | Thu 14 March 2013 07:36 |
| Blower Power | javeria | 55. Dust Management | 14 | Mon 27 June 2011 21:20 |
| Blower impeller design & comparisons | vishnu | 55. Dust Management | 30 | Sun 08 November 2009 10:25 |
| Blower Question | MetalHead | 55. Dust Management | 3 | Thu 13 August 2009 12:12 |
