Old Tue 28 March 2017, 12:31
st_indigo
Just call me: Philip.X.Diaz #123
Los Angeles, CA
Tilting Plywood Cart
Hey MechMateys! I made a thing, and it is glorious.
I give you the Tilting Plywood Cart! Made from 0.71 Baltic Birch (or 18mm if you prefer). Uses just over half a sheet. Four 3" swivel lock casters let you roll it any which way. 1/8x1 steel bar has a notch that locks the cart in the horizontal position, then you just pull the cord to release. The center of gravity of the sheet is over the pivot point so it won't slam down when you tilt it.
I'll type up some instructions to go along with the construction photos and plans, and post at a later date. For now, here are some photos of the completed cart.
Images Below - Admin
Old Tue 28 March 2017, 21:21
timberlinemd
Just call me: Steve #66
Arizona
I don't see the photos?
Old Tue 28 March 2017, 21:50
st_indigo
Los Angeles, CA
Strange.. I can see them just fine.
Is anyone else having trouble seeing the photos? If nobody but me can see them it's probably a privacy setting in google photos I need to change.
Old Tue 28 March 2017, 21:53
digger
Just call me: Milosh #113
Toronto
I don't see them as well.
Old Tue 28 March 2017, 22:04
No. I cant see any photos.
Old Tue 28 March 2017, 22:19
st_indigo
Los Angeles, CA
Okay.. let's try this again with Flickr instead of Google:
Old Wed 29 March 2017, 00:43
Yes, that works
Old Wed 29 March 2017, 18:43
st_indigo
Los Angeles, CA
48x96 sheet layout for 0.70" plywood attached
pockets are milled 0.35" deep
Old Thu 30 March 2017, 00:04
Thanks for the PDF.
I will keep it for future use.
Old Fri 28 April 2017, 00:47
IamDave
Just call me: Davey
Ball Ground, GA
Excellent idea I use something similar to move extira sheets around. An old sheetrock lift I modified... Thanks
Looking for DXF files for Candy Cart CosmicNacho The Market Place 8 Mon 16 November 2015 15:17
19mm Plywood offcuts Kobus_Joubert The Market Place 8 Tue 29 March 2011 07:22
Plywood Wine Rack danilom The Show Room 6 Wed 23 March 2011 13:34
Scarf cutting file for plywood jehayes Miscellaneous / General / Whatever / Catchall 37 Thu 18 March 2010 09:57
Tilting or hide-away MM? limited floor space Mike94531 General - MM Build 49 Sat 13 March 2010 04:39
