Old Tue 28 March 2017, 14:46
firechief
Just call me: Tim
Battle Creek
Starting to get stuff mounted... it is hard to make the stepper noise with your mouth, but you know I tried. Got the rails painted as well.
Old Tue 28 March 2017, 14:52
firechief
Just call me: Tim
Battle Creek
Every thing is level and rolling smooth. Still got the Z to do. Looking at water cooled spindle, alone with a cooler and pump set on the Y cart. This making the run short and the system will be right in you face to keep your eye on. It will have a water movement indicator and temp read out as well. What do you think Pros or Cons
firechief
Old Tue 28 March 2017, 15:36
Kornerking
Just call me: Pete #127
Big Falls, Mn
Looking awesome.
Now get a move on.
Old Wed 29 March 2017, 04:05
racedirector
Just call me: Bruce #122
New South Wales
Wow, that looks so nice! Well done, you'll be cutting in no time at all.
Old Wed 29 March 2017, 07:32
hflwaterski
Just call me: Herb #126
Genesee, WI
That's one serious heat sink! Looking very sharp! You're in the home stretch now.
Old Wed 29 March 2017, 09:07
firechief
Just call me: Tim
Battle Creek
Thanks for all the comments on my build. Hope to be cutting soon. Then the learning curve with mach4 and v carve pro.
Any and all help is welcome.
Old Wed 29 March 2017, 09:12
firechief
Just call me: Tim
Battle Creek
The stepper drivers are mounted to that on the inside, I cut out the side of the box to the size of the heat sink less 3/8" all around to seal and bolt it on. The drivers are bolt on to the heat sink on the inside. I can add a fan if needed on the out side of the control box, this keeping all the heat on the out side.
Old Wed 29 March 2017, 09:17
firechief
Just call me: Tim
Battle Creek
Thanks, Not sure how long it will take to get all the movements dialed in. When mach4 calls for 1" of movement the spindle moves 1" on all axes, also getting the spindle square to the table and so on.
Again thanks for looking
firechief
Old Thu 27 April 2017, 21:31
IamDave
Just call me: Davey
Ball Ground, GA
That is a good looking build. Very nice work.
Old Thu 11 May 2017, 18:01
MarkRH
Just call me: Mark
Maryland
Get any movement yet Tim? looked like you were moving right along
Old Tue 16 May 2017, 10:10
firechief
Just call me: Tim
Battle Creek
Water Cooling
I got the water cooler setup along with the radiator and 3 fans. The water pump and fans startup with Mach4 calls for the spindle to start. work great so far.
As you can almost see the water flow indicator on the Z slide just after it come out of the spindle, to make sure it has water movement. The temp is showing there in front of the fans.
Let me know what you think?
Old Tue 16 May 2017, 10:39
firechief
Just call me: Tim
Battle Creek
It is alive
I got the thing moving... I even crashed it one or two time
I got V carve pro 8.5 and Fusion 360. There is a lot to learn the curve is just about strait up. I fly cut the table, that was way cool the first time. I had to do it three time to get the spindle sq to the table and the steps adjusted right.
I have been cutting some small parts and made a base for a LED edge lite sign. The last pic show me making a vac boot for it out of wood (this will be from HDPE when done). This boot will let the z go to Home 0 and the hard stop.... if needed.
Maybe I can get stickers for it so I can get a number as well.
Let me know what you think.
firechief
Old Tue 16 May 2017, 19:18
timberlinemd
Just call me: Steve #66
Arizona
Looks good! Just needs logo for a number.
Old Wed 17 May 2017, 18:30
hflwaterski
Genesee, WI
Awesome job Tim! Looks like a great job. Now let's see some projects and maybe even a video.
Old Wed 05 December 2018, 05:20
Firechief I have moved your thread since you are now cutting.
Old Fri 14 December 2018, 11:53
Andrew_standen
Just call me: Andrew #109
Dorset
Excellent job, Well Done.
Making Progress Huge Control Panel! - New South Wales AUS southernduckie Construction started, but not cutting yet 46 Sat 15 December 2012 02:28
Progress on Control Panel - Redwood City CA USA oliver2257 Construction started, but not cutting yet 9 Wed 18 January 2012 00:53
Interesting Control Panel Post at Hackaday domino11 Human Interface Devices (HID's) 0 Fri 23 December 2011 09:45
Aluminum Airplane Control Panel on a Mechmate! Jayson The Show Room 9 Tue 21 July 2009 04:51
USB joystick and control panel James Webster 70. Control Systems 4 Wed 28 February 2007 00:25
