Old Fri 18 March 2016, 12:14
Cool! congrats.
Old Fri 18 March 2016, 18:11
hflwaterski
Just call me: Herb #126
Genesee, WI
Thanks Alan and Tom! Pretty good feeling but plenty to learn and do now.
Old Fri 18 March 2016, 21:45
Looks like you've met the requirements for a serial number.
Old Sat 19 March 2016, 08:02
hflwaterski
Genesee, WI
Well, I finally learned just enough of the CAM program to give it a go. You will see that I botched up my first attempt on the drilling operation because I was referencing the wrong surface. Luckily, only snapped an 1/8" bit rather than an expensive cutter. The g-code was setup to run off the top of the part and I referenced the temporary spoil board or the bottom of the part instead. It eventually dawned on me. In addition, I used a 5/8" piece of plywood instead of 1/2" material just to be safe. I'm sure my steps were too small and my feed speed was too slow too but hey, it ALMOST looks like I know what I'm doing. I'm happy enough at attempt #1.
First test run at making a dust boot.
Old Sat 19 March 2016, 08:49
This is when the serious stuff happens. The machine was the easy part he he
Old Tue 22 March 2016, 10:33
hflwaterski
Genesee, WI
I've cranked up the speed on the cam program based on the chip load formula. Does the speed look right on the video? I'll put another video out here on Thursday running an 1/8 bit, 2 flutes on the profile. I exceeded my weekly limit of space for videos so I can't put the other video up yet. For this video I'm using a 1/4" carbide bit, 2 flutes @ 18,000 rpm and a chip load of .015. According to the calc, I should be running at 540ipm. It would be great if it runs this fast on plywood all the time but would like another set of eyes on it to make sure I'm not moving too fast.
Cutting magnet pockets and the slot for the nut.
Old Tue 22 March 2016, 10:38
A lot plays into chip load that calculators do not take into account. Deflection, micrograin, humidity, machine rigidity, a perfect world, etc. Reduce your RPM and recalculate and start at 80% of the calculation for IPM. Get your speed to a comfortable margin to work within the constraints of the machine build to not have other issues. Biggest thing is listen for chatter and after the cut is done the bit should only be warm to cool and not hot.
Old Thu 24 March 2016, 10:18
hflwaterski
Genesee, WI
Thanks Pete. I'll definitely do that. Here is a video of it going full speed using the calculation. It just seems too fast for that bit. It's solid carbide, upcut, 1/8" cutting diameter, 1/4" shank, 2 flutes, 18,000 rpm, chipload 0.015 which equates to 540 ipm.
0.015 x 18000 x 2 = 540 ipm
I'll slow the rpm's down and reduce the chipload slightly and drop it down to 80% and see how it comes out.
Here is the cutting video.
Old Thu 24 March 2016, 11:40
Speed looks OK, you may still not have the correct acceleration settings though, it should not slow down like that when approaching a change in direction.
Old Thu 24 March 2016, 13:51
hflwaterski
Genesee, WI
I'll see if I can figure out how to change that in the CAM software. Thanks for catching that!
Old Thu 24 March 2016, 15:19
The running speed looks fine but you will burn up that bit with those slow downs. You are rubbing and not cutting then. I would also advise a ramp plunge instead of a straight plunge.
Old Thu 24 March 2016, 20:12
Congrats on your build!!! You get number 126 !!!
Old Thu 24 March 2016, 20:34
....I'll see if I can figure out how to change that in the CAM software...
It's actually simpler to adjust it in Mach3 ( if that's what you're using )....
Just go under the 'config" main menu tab, scroll down to "motor tuning"...and there you'll see the acceleration box you can change values.
MAKE sure you click "save axis settings" after any changes and...make sure you change all you axis independently on that setting profile page !
Advise...in myexperiance & opinion.....Slower accel make life simple on your beast....and maybe less impressive to see vs a quick change, but, on the long run, many parts will simply survive longer....with less maintenance & cost.
IE....gear rack & pinion for starters
All the best, R.
Old Thu 24 March 2016, 21:37
hflwaterski
Genesee, WI
I'm working on my first paid sign job. I'll post pics on it as I get things figured out.
Pete:
I did figure out how to get rid of the plunge on my cuts tonight. Thanks for the advice!
Mike:
Thanks for assigning me #126. I feel like I just got my diploma!
Robert:
Thanks for the tip! I'll give it a go on the motor tuning and see where I settle for acceleration.
Old Fri 25 March 2016, 01:13
Well done #126.
Happy dust to you.
Old Fri 25 March 2016, 05:48
Kornerking
Just call me: Pete #127
Big Falls, Mn
Congratulations. Paid jobs are great.
Guess I should get my logos on as well.
Old Fri 25 March 2016, 07:35
hflwaterski
Genesee, WI
Thanks Al and Pete! Get those logos on Pete. Graduation day awaits!
Old Fri 25 March 2016, 07:50
Congrats to #126
from #101.
Old Fri 25 March 2016, 11:40
hflwaterski
Genesee, WI
Thanks a bunch Darren! The 100+ club?
Old Fri 25 March 2016, 13:56
Congrats....wow 126 machines
Old Fri 25 March 2016, 14:14
now 127
Old Fri 25 March 2016, 14:43
Nikonauts
Just call me: Nikonauts
Johore
Old Fri 25 March 2016, 15:57
hflwaterski
Genesee, WI
Thanks Sean, Tom and Nikonauts!!! Sean don't you own like 30 of them?
Old Sun 27 March 2016, 16:12
Herb,
Interestingly enough, I don't have any of them anymore. #5 gone, all the others where built for other friends or University as a class project. I have enough experience building them now that I don't even refer to the instructions! Now, I just sit back and comment from the cheap seats.
....but I do plan on building a new one later this year if all goes well!
Old Sun 27 March 2016, 21:48
Builder's Log Update
Outstanding! Congratulations.
Here's the Update Builder's Log with your entry added.
Please let me know your cutting dimensions for the log.
Old Sun 27 March 2016, 22:32
hflwaterski
Genesee, WI
Sean:
I look forward to seeing a near perfect build with so much experience!
John:
The dimensions are 49"x97". Seems to be a common size after looking through the list again. Nothing special going on beyond that other than a spindle rather than a router.
Old Mon 28 March 2016, 07:58
Thanks for the information. I have updated your log entry.
Yours is a very impressive story. It took you awhile, but you stuck to it and finished...including earning a serial number.
Old Mon 28 March 2016, 12:57
hflwaterski
Genesee, WI
Thanks John! I'm very relieved to have it running. For the longest time, it was non-functional pile of steel taking up space but now it sits proudly like a showcase thanks to everyone on the forum. I'm privileged to have so much accessibility to the experienced builder's logs and immediate, helpful tips and I appreciate you updating the Builder's Log!
Old Mon 28 March 2016, 19:20
Now Let's See Some Work!
Old Tue 29 March 2016, 18:12
Andrew_standen
Just call me: Andrew #109
Dorset
Congratulations
from number 109
More progress, it cuts ! #109 - Hampshire, UK Andrew_standen MechMates already cutting 75 Thu 23 July 2020 14:23
First Cuts #108 - Willemstad,Netherlands parrulho MechMates already cutting 154 Sat 15 November 2014 13:14
Stickers on and cutting #77 - South Australia Quadro MechMates already cutting 66 Sat 29 September 2012 09:01
It has made the first cuts - Caussens, France Pierre GRAND MechMates already cutting 97 Tue 15 December 2009 11:26
My first cuts bbreaker The Show Room 2 Mon 23 June 2008 00:06
