Old Mon 07 March 2016, 08:48
ola16
Just call me: ola
Dorion
Bosch Colt with VS ON/OFF Control
On my 3 axis cnc I have a Bosch Colt VS router which currently is controlled manually with an ON/OFF switch. I would like to have Mach3 tuning the router ON/OFF but not sure how to achieve this; perhaps with a relay or another BOB?
I was looking at the Super-PID but that’s an expensive solution
The only BOB I have now installed is shown here:
http://www.automationtechnologiesinc...ional-breakout
Any ideas?
Old Mon 07 March 2016, 09:31
Welcome to the MechMate ola.
We primarily focus on the construction and use of the MechMate router.
A better place to ask your question is probably a forum dedicated to whatever control software you are currently using.
Good Luck!!
Darren
Old Mon 07 March 2016, 11:58
CPAC_CNC
Just call me: CPAC
Groton
I'm going to respond assuming the you are asking about a MM.
Yes, you probably want to drive a relay with a low voltage coil from an available BOB output. Or a SSR as discussed in one of the last threads in this sub-forum.
I'm a newbie here myself and think if a question is 100% applicable to a MM build then answering or discussing it can only further the knowledge and experience in the forum.
That said I don't know of any forum where asking questions that have already been answered is received well. It comes across as asking others to do work for you that you have taken no time to attempt yourself.
Old Mon 07 March 2016, 12:42
ola16
Just call me: ola
Dorion
Thank you both for your time
I understand this a MM forum however I thought a typical wiring question will be applicable to both MM and other machines
I don’t think my question is answered already, I did see a similar question posted but it was not with a C10 BOB
Finally I apologize, I’m not the type to create problems. Forums are a wonderful way to share knowledge and I respect people who use their time to help others for free
Old Mon 07 March 2016, 12:48
Ola,
The question you ask is a normal solution for the MM.
You can use the spindle (on/off) toggle on the Mach 3 software to turn a remote relay on/off.
Depending on the break out board on your particular CNC machine. You may have to purchase a few items to properly switch the size relay (current capacity) needed to operate your router.
The Mach 3 manual has a very detailed section to assist you in understanding spindle and relay control.
Good luck
Old Mon 07 March 2016, 19:25
http://www.mechmate.com/forums/showthread.php?t=5131
Ola, This is what I did.
There is a link to a site on post 14.
You should be able to do it.
Old Mon 07 March 2016, 19:39
ola16
Just call me: ola
Dorion
Thanks Al for the info, much appreciated
Routers - Porter Cable, Bosch, Makita, Milwaukee, Etc - and mounting them fabrica 50. Toolheads 109 Sat 28 September 2013 04:26
Bosch GWS 7-125 Professional Grinder Skate Modification Surfcnc Rails & Rollers 3 Fri 06 September 2013 11:42
Some alternatives to Bosch grinders for skate dmoore Rails & Rollers 17 Mon 22 March 2010 04:47
Bosch GMF 1400CE Router gixi 50. Toolheads 5 Sun 12 July 2009 06:03
