Old Sat 05 March 2016, 06:14
Kornerking
Just call me: Pete #127
Big Falls, Mn
It's all Darren's fault!! - Big Falls, Mn
I went to the shop at 5:30 am this morning and found this elf working away. Tony is wanting to get this done.
Wiring day..
Old Sat 05 March 2016, 16:59
Kornerking
Big Falls, Mn
Ready to wire it up.
Had a great day today. Control box is wired up. Motors are installed. Router bracket is installed, with a special adjustment feature. Cable chain is on.
Only booboo today was the gas shock got installed a little off and hung up on the spider. A little swearing and we got it fixed.
Tomorrow we start to run wires.
Here is a short video of the machine to this point. https://www.youtube.com/watch?v=ODlq7qKawy8
Old Sat 05 March 2016, 17:20
Awesome Pete. Is the gas shock installed with the big end at the top? If not it may fail prematurely.
Also, I noticed you were rolling machine with the motors engaged. Refrain from doing that after they are wired. I seem to remember someone saying they can act as generators and feed back into the controller.
Looking Awesome.
Old Sat 05 March 2016, 17:29
Kornerking
Big Falls, Mn
Thanks Darren.
Yes the shock has the big end up. Read the warnings on that.
If Tony has his way(he usually does) it will be cutting by our 1 month anniversary of starting to cut steel.
Old Sat 05 March 2016, 20:48
Awesome. Then the REAL fun begins.
Old Sun 06 March 2016, 03:46
Now that is really flying along!
Old Sun 06 March 2016, 21:55
Kornerking
Big Falls, Mn
Well we got most of the wiring done today. Shut down early to enjoy the spring weather and play a little music.
Here's what i came up with. The Farm Boy Blues.
https://www.youtube.com/watch?v=GDrwULzaLTc
Old Mon 07 March 2016, 03:56
I hope there is/was something good in the glass...
Old Mon 07 March 2016, 06:13
Kornerking
Big Falls, Mn
Ayup. Some fruit of the vine. It had been a full week and felt good to kick back and relax with my Bride of 45 years. That was her playing. Not sure about the singing.
Well looks to be a short run now to movement. All of the groundings are attached. 2 motors to do final connections on, 1 estop box, then connect into the main box again. Getting excited.
Old Mon 07 March 2016, 20:08
Kornerking
Big Falls, Mn
Ready to roll.
Tony got the motors and estops wired up today. Just need to connect the leads to the geckos and it should move.
About time.
Old Tue 08 March 2016, 08:35
Kornerking
Big Falls, Mn
By George it moves....
YES!!!!!
First movement out of George this morning. All 4 motors moving with the jog command.
We need to calibrate the torque on the motors some more. Well maybe a bunch more.
27 days since we started cutting steel.
Here is a video. https://www.youtube.com/watch?v=m6xEayjwU4c
Old Tue 08 March 2016, 14:20
Kornerking
Big Falls, Mn
A few hours later and we have it whipping along.
https://www.youtube.com/watch?v=PVhy58whO_c
Old Tue 08 March 2016, 16:58
Great job Pete.
You've spoiled the build time curve.
Old Tue 08 March 2016, 17:50
Kornerking
Big Falls, Mn
I have to give the credit to Tony the tiger. He has been impressive in this project.
He was the one who figured out that the resistor was a bit high. Went from a 39k to a 36k and George purred.
Old Wed 09 March 2016, 18:26
Kornerking
Big Falls, Mn
George is cutting
4 weeks ago today we started cutting steel. Today we started cutting wood. We spent a good part of the day calibrating the motor steps and leveling the z slide. We got the travel to within a 32nd on 90 inches of travel. Close enough at this point for what we cut. The trammel worked very well for us in leveling the router.
Any way it is time to move to the Senior circuit. " Mechmates already cutting"
Here is a video.https://www.youtube.com/watch?v=GGUttwvVWJE
As soon as the logos get here it will be stickered.
Old Wed 09 March 2016, 18:50
MarkRH
Just call me: Mark
Maryland
Nice job Pete and Tony, you made it look easy!
Old Wed 09 March 2016, 19:11
Kornerking
Big Falls, Mn
Thanks Mark.
We just kept it simple.
You're next.
Old Thu 10 March 2016, 07:44
dbinokc
Just call me: DB #118
Oklahoma
Great job and amazing progress.
Old Thu 10 March 2016, 09:23
Kornerking
Big Falls, Mn
Thanks DB.
It has helped that we had 2 heads figuring things out. And the information needed is here on the forum.
Hopefully by the end of next week we are in production with George.
Old Thu 10 March 2016, 13:08
technogod
Just call me: technogod
bakersfield
Looks awesome sir.Your grinding process on the rails is definitely a genius approach.
Enjoy your new money maker
Old Thu 10 March 2016, 14:21
So Pete, Mach 3 has a gadget whereby you put a measured set of marks the full length of your table, and tram your router point to point, and Mach 3 will calibrate to that exact distance.
1/32" over 90" is unacceptable on THIS forum, sir...
Old Thu 10 March 2016, 16:00
True Dat my brother
Old Thu 10 March 2016, 16:10
Kornerking
Big Falls, Mn
Ha. Wood will expand and contract more than THAT overnight.
But pretend I am from Missouri. Show me.
Got the touch off working today. Now to set the laser cross hair.
Picking up the material for the table on Monday, then we can set the jigging for the dovetailing.
Old Thu 10 March 2016, 16:12
Kornerking
Big Falls, Mn
Thanks. Cash machine. It should be paid back in a few months.
Tony is already planning for the next one.
Old Fri 11 March 2016, 20:07
Kornerking
Big Falls, Mn
Working on my dovetail joints today. They are fitting like a glove.
This is my main need for the mechmate. We need to do a 45 joint on our drawers and George should do it.
Old Wed 16 March 2016, 06:30
Kornerking
Big Falls, Mn
We got George moved to his permanent spot yesterday.
We will do the relevel today and start the ducting for the vacuum today and hang the control panel on the wall.
Shop is in mild disarray for a couple of days.
Old Wed 16 March 2016, 17:19
Kornerking
Big Falls, Mn
We will be working with 60 x 60 sheets of baltic birch so we built a machining area for it at 61 x 61. Surfaced it today so we can begin cutting.
Both ends of the table will have fixtures for doing our dovetails. Now I can use my surfaced area to cut the parts to build the jigs for that.
Awesome. At least to me.
Short video of George in action.
https://www.youtube.com/watch?v=l0nRdjzaOUA
With our vacuum we wanted a non porous substrate so we glued formica to the surface. Hopefully it serves the purpose. Years of doing countertops gave us a supply of material. Looks purty as well.
Old Thu 17 March 2016, 19:37
Kornerking
Big Falls, Mn
Started making money with our mechmate today. Cut out parts for our Kornerking product on it. We got the vacuum system working for the holddown. No clamping or screwing needed.
https://www.youtube.com/watch?v=GqqKwtYLjIg
Old Fri 18 March 2016, 18:25
Great work Pete and if I may jump in, you acceleration looks too small. Something in a range of 200mm/sec or in inches 8-10 ips. Also if that end mill is in range of 6mm or 1/4" you can do plywood easy in just 2 passes. This accel might be needed for this beast Biesse 335 retrofit I done recently but he Mechmate is much lighter and can be much more maneuverable . Try bumping that accel to 20 or more (600mm/sec) and you may get away with cv on outer corners, that will improve your cut time significantly.
Old Fri 18 March 2016, 21:37
Looking great Pete.
Looks like you've been moved to the MM already cutting area.
Back Doing Some Arcade Fun #19 - Smith's Falls, Ontario, Canada bradyaero MechMates already cutting 146 Tue 27 January 2015 10:41
'Clean' Vectors - free project plans for the woodworker Kobus_Joubert Golden Resources 6 Thu 13 August 2009 07:34
It's all Darren's fault!! - Big Falls, Mn Construction started, but not cutting yet 0 Wed 31 December 1969 19:00
