Old Wed 02 December 2015, 11:19
Kornerking
Just call me: Pete #127
Big Falls, Mn
Ha. Just found it.
I need to compare what I already have and then get the rest.
Need motors and power supply for sure.
Old Wed 02 December 2015, 20:41
Welcome back, knucklehead!
I may have to add a second gantry to mine. Retirement isn't working out so well.
Old Thu 03 December 2015, 06:43
Kornerking
Big Falls, Mn
I may need to come visit you again.
Just a warning.
Old Thu 03 December 2015, 09:28
Anytime.
Mid January I'll have a BlackTooth Laser added to the arsenal.
Old Thu 03 December 2015, 11:02
Kornerking
Big Falls, Mn
Is that the reason for the second gantry?
Old Thu 03 December 2015, 18:49
No.
Old Fri 04 December 2015, 05:22
Kornerking
Big Falls, Mn
Is it free standing then?
Old Fri 04 December 2015, 08:16
Kornerking
Big Falls, Mn
Opinions needed.
Wirefeed welder versus arc.
Any reason one is superior?
Getting ready to buy. Looking at a Hobart
http://www.northerntool.com/shop/too...PRwaAhmC8P8HAQ
Old Fri 04 December 2015, 08:35
I used a stick welder for the base table and gantry, and a wire feed MIG for the Y. car.
The blackTooth is a stand alone machine.
Old Fri 04 December 2015, 10:42
That welder you linked to is actually a very good welder for the price. Additionally, you can get spool gun for it and weld aluminum as well.
Good luck
Old Mon 07 December 2015, 15:07
Kornerking
Big Falls, Mn
Question.
I have a large supply (200 ft) of heavy wall 2 and 3" pipe. Am I being pennywise and pound foolish to consider using it for the base structure?
Old Mon 07 December 2015, 20:40
That Hobart is a nice machine.
https://www.millerwelds.com/equipmen...021572-no-name
This is a nice welder also. I have a 185 (older Version) and I added a spool gun (for aluminum welding) .
Miller and Hobart are owned by the same company since 1996
http://www.hobartbrothers.com/about-...of-hobart.html
So a lot of cross brand (Think Chevy vs Cadillac)
You should invest in the most welder you think you will need. Not just for the MM build.
I have a 252 and it does all I ask it to do.
https://www.millerwelds.com/equipmen...illermatic-252
Old Mon 07 December 2015, 21:38
Round pipe for the legs and cross bearers are fine
Old Tue 08 December 2015, 07:50
Kornerking
Big Falls, Mn
Ordered my welder. Getting the Hobart.
Motors next.
Old Tue 08 December 2015, 22:48
Make me proud Pete.
Old Tue 29 December 2015, 12:21
Kornerking
Big Falls, Mn
Yes
I can get started on my tabletop project. Transformer and steppers are here. I will finally be able to put the parts I got from Darren Sayler to use.
Old Tue 29 December 2015, 20:38
EXCELLENT!!
Remember, you eat an elephant a bite at a time.....
You'll never find the perfect time to build it, so stay on it and break it down into manageable steps you can steal a few minutes a day to complete.
Old Tue 29 December 2015, 20:58
Kornerking
Big Falls, Mn
Tony and I spent a couple hours tonight looking at Geckos and such as well as your electric box. .
The antek transformer I received did not have the 2 orange wires yours show, or their website shows , so I need to call them for input. Unless someone here cares to elaborate.
Old Wed 30 December 2015, 05:03
Those are for secondary power.
The power supply I sent you does not have secondary power winding on it.
What are you trying to power?
The PMDX-126 uses the 115v input power and the Geckos use the primary output voltage from the power supply through PMDX-134 (or PMDX-133) board.
If you are going the Smooth Stepper route, You should mount it on the PMDX-126 as a daughter board and take power off of it. This simplifies the wiring and saves space in the box. Also, if you plan to use a spindle in the future, go ahead and mount a PMDX-107 board on the PMDX-126 as shown.
This consolidation is just some of the ways as builds progress we continue to refine and simplify builds.
Old Wed 30 December 2015, 05:31
Kornerking
Big Falls, Mn
Thanks Mike.
Ok. One bite down. Now to digest it.
Dang glad Tony (my son) is along for the ride.
Old Wed 30 December 2015, 06:09
Kornerking
Big Falls, Mn
Lesson 1.
Dig deeper for solutions.
Just because Darren has orange wires doesn't mean I need them.
Old Thu 31 December 2015, 12:08
Kornerking
Big Falls, Mn
Bent parts inventory. This is from a kit i bought from Darren a while back so needed to see if it was all there. Almost. Missing the idler plate m130 332.
And had some extra parts.
Extra parts
Old Thu 31 December 2015, 13:49
no image?
The image is not displaying. It is getting a getting a 403. Basically display is being denied from your google user account.
You may be able to see it, but it is denied to the rest of us.
Old Thu 31 December 2015, 14:19
Kornerking
Big Falls, Mn
OOPS, to late to edit it.
Here they are smaller.
Old Thu 31 December 2015, 14:20
Looks good! Much better to view!
Old Thu 31 December 2015, 14:51
Kornerking
Big Falls, Mn
It's like my birthday every day as I open these packages.
Old Thu 31 December 2015, 19:22
Wish I would have kept it all now.
Oh well.
Old Fri 01 January 2016, 07:34
Kornerking
Big Falls, Mn
What are those pieces in the bottom picture?
Old Fri 01 January 2016, 09:16
proximity sensor mounts/travel stops.
Old Sat 02 January 2016, 18:45
Stop Blocks
The one without the holes is for the Y axis since it usually has some adjusting needed per build.
Back Doing Some Arcade Fun #19 - Smith's Falls, Ontario, Canada bradyaero MechMates already cutting 146 Tue 27 January 2015 10:41
'Clean' Vectors - free project plans for the woodworker Kobus_Joubert Golden Resources 6 Thu 13 August 2009 07:34
It's all Darren's fault!! - Big Falls, Mn Construction started, but not cutting yet 0 Wed 31 December 1969 19:00
