Old Wed 02 January 2008, 04:34
You guys are going to keep right on until I have to start posting pics all of my mistakes just to feel like an honest man. (and there is a limit to how many pics you can post on this forum) Thanks y'all
Old Wed 02 January 2008, 05:43
JR
Those Nuetrik 4 pin xlr's look nice! It's nice to hear that "click" sound when you make a good connection! I assume from the order list with Markertek you are using the xlr's only on the machine end of the run and your terminating to the Gecko's directly within your drive cabinet. All future versions of my machine will have on XLR on the machine end. All the home runs will be terminated at the box through a nice strain relief. One less connection to solder up.... about 75 dollars less in parts. Every penny counts! Have a great day...I can't believe I am in the shop in florida and its 28 degrees....Brr....I actually had to wear long pants for a change
Old Wed 02 January 2008, 09:22
JR,
Your machine looks awesome. Save some picture room for some pics of your first projects so we can see the end results of your labor
Doug,
Your work looks fine to me.
Sean,
Stop complaining, I woke up to about 30 cm of snow this morning and a chilly -20 C. Drifts at my roadway with the plow spilloff was about 4 feet high. I have been wearing long pants for about six months now.
Old Wed 02 January 2008, 17:57
I'm going to control the router on-off with G-code and a relay, so I've added the disconnect switch for bit change safety. Just can't put a lot of trust in that router switch under the plastic when I can't see it.
Sean you're right the geckos will be straight wired, you can see the umbilical cord in the 2nd picture.
Heath, I'll save lots of room for project pics. Thanks
Old Wed 02 January 2008, 19:38
J.R.,
On your Slide Plate [10 40 330] of the Z-Slide assembly, what size countersunk cap screws did you use.
I'm re-drawing the slide plate, using M6 screws and it just doesn't look right. The major diameter [12 mm] of the head does not leave room for Hole B. I'm using the CAD drawing off McMaster (p/n 91294A236) for dimensions.
When looking at your pictures, it looks like drawing 10 40 330. Just wondering if a dimension is wrong
Old Wed 02 January 2008, 20:23
Greg I used 6mm. I will check the head dia in the morn and post. You are right, in the real thing there is not a problem.
Old Wed 02 January 2008, 20:39
J.R.,
Don't bother. I found the problem. My AutoCAD default was on radius and should have been diameter.
Sheez, if your not making mistakes, your not doing much.
Have a good evening and thanks. Sorry for wasting your time.
Old Tue 08 January 2008, 07:10
J.R.,
I've been using the pictures that you posted allot and just want to confirm something.
In the top picture of post 81, is the 0,0 (x,y) corner nearest the photographer?
Yours (and everyones) pictures are a tremendous help.
Old Tue 08 January 2008, 11:58
Greg 0,0 is diagonally across the machine. But Gerald made a suggestion near some of my first complete pictures posts (best I remember) saying I should have put the X cable chain on the other side, because it will be difficult to reach over it.
Best I remember I wasn't the first to say it, but "a picture IS worth a thousand words" ;-)
Old Tue 08 January 2008, 12:31
J.R.,
Your reading my mind. I just ordered the cable track last night and now am thinking about installation. Which side, etc.
Greg
Old Tue 08 January 2008, 14:56
cobra427mnsi
Just call me: Paul
Leamington, Ontario
JR
When you say that 0,0 is diagonally across the machine, does that mean any corner can be made to be 0,0? May be a stupid question, but ,if I don't ask, I won't know for sure. In the picture mentioned by Greg, the corner nearest to the photograph would be good for 0,0 because the cable chains are out of the way.
Paul
Old Tue 08 January 2008, 15:21
Paul,
Gerald is ahead of us. He has started another thread explaining the orientation of 0,0. Has drawings.
It's under
Wire & cable management / cable location & orientation
Talk about service
Old Tue 08 January 2008, 16:08
I only have experience with my cnc wood lathe. It is a rear tool post. Home or 0,0 is as far back and to the left as the machine will go. I assume a cnc router has 2 positions that can become home or 0,0. They are, when you're standing next to the side face toward the machine, you're extreme left. I would think the keyboard should be very close at hand.
Old Thu 10 January 2008, 06:14
Keyboard extender cables make the keyboard position very flexible
(Avoid wireless keyboards though )
That limit gets raised for the good guys
That disconnect switch looks good and accessible. Nice location.
On the cable chains, I think that JR will agree with me that the purple version would be better from an operator's viewpoint:
but that the connection between the two chains wouldn't be as neat as the twin pipe system he has now.
The Mamba drawings result in the purple "method", but I stll have to check if cables can be routed neatly between the 2 chains.
On cables and wiring, the connectors and rubber grommets look top-notch!
Once before I was nervous of the little space you left in tubes for cables, and that umbilical under your control box has me nervous - you still need a fat ground cable it seems?
Old Thu 10 January 2008, 06:22
There is one HUGE omission
Why havn't you mentioned that it already moves, cuts and spits sawdust?
Old Thu 10 January 2008, 12:34
As of yesterday there is a #12 fine braided ground wire running in that umbilical cord thank you . I think I could get 1 or 2 more control wires in there (using grease) if I had to.
and the above is on my to do list!!!!!
Old Thu 10 January 2008, 13:27
You can go ahead - I have my fingers in my ears
Old Wed 16 January 2008, 06:58
Here I am waiting on parts
Old Wed 16 January 2008, 08:11
J.R.,
That's about the coolest / cleanest setup I've seen. Where did you get that wire duct system and what's it called?
Old Wed 16 January 2008, 08:20
I made it using my table saw. I think the white stuff is called starboard it's 1/2" thick, the clear pex glass is 1/8" thick. Just cut the grooves to fit your cable.
Old Wed 16 January 2008, 15:12
...somebody has way to much free time
Great wiring!
Old Wed 16 January 2008, 19:50
Really Inspiring, Never knew one could be " Electrically and Mechanically " so inspiring
RGDS
Irfan
Old Wed 16 January 2008, 21:46
Did everyone spot the green ground wire and the connections to the cable screens?
Old Wed 16 January 2008, 23:34
Not me, until you mentioned G', again charming as it can be. Way to go JR.
Irfan
Old Thu 17 January 2008, 08:28
JR,
Great job on your wiring. If I could offer one suggestion, it would be to carry your shield closer to the geckos so you have less unshielded wire sitting out in the open. Any open wires will radiate noise. Some of the connections (the ones farther to the left) have a little more exposed wire.
Your build is looking awesome.
Old Thu 17 January 2008, 12:17
I propose that we ban JR from this forum. Or at least ban him from posting anymore pictures of his outstanding craftsmanship. It's not fair to amateurs like me to have my primitive creations compared to the work of a world class professional. From this point forward, I'm going to make my wife operate the camera thereby guaranteeing that the photos will be blurry and off center so no one can see the junk I've built.
Cool it JR. You're really embarrassing me.
Old Thu 17 January 2008, 12:33
You guys are just too funny!
Old Thu 17 January 2008, 12:34
I know Doug is only joking,
But J.R.'s high standards and top notch craftmanship, makes us all work harder to meet a higher level of MechMate (wow, how Zen)
Keep the pictures coming. You can't believe how much I use your photo's.
Old Thu 17 January 2008, 19:36
I would call it the "Art of making a Mechmate". its not just to make a mechmate but "to add soul to it", Right JR!
Meanwhile had a blast reading Dough's post,LOL, keep up the spirit Dough...... !
Great work JR
Old Fri 18 January 2008, 05:31
Thanks everyone I needed that. Irfan more than anything else it's probably just "somebody has way to much free time"
JR's rail grinding skate in a Lasered & Bent format for 4.5" grinders Gerald D Rails & Rollers 198 Mon 13 April 2015 20:59
Add one more CNC addict - North Carolina rodom Introduce yourself and start planning 0 Tue 01 December 2009 06:54
She makes dusty MOVES! - North Carolina, USA Jeffn11 Construction started, but not cutting yet 23 Sat 01 August 2009 20:36
Plasma burner started - Albemarle, North Carolina subman Construction started, but not cutting yet 8 Sat 27 September 2008 19:25
One more MechMate starting - North Carolina, USA Bernhard Construction started, but not cutting yet 5 Fri 28 December 2007 16:11
