Old Thu 26 February 2015, 09:14
userandrew
Just call me: andrew
georgia
massmind diy stepper drivers
Anyone out there using the 4A stepper drivers based on the THB6064 chip on their mechmate? James Newton of Massmind sells the kit on his site. Any opinon on them. I am about to start working on the electonics part of a mechmate build and I was wondering if anyone is using these. This will be a slow build limited by time and money and I thought this might allow me to whet my appetite cheaply.
Old Thu 26 February 2015, 11:49
Hi Andrew , I am using them on my lathe up to now no problems.Straight from China.
Old Thu 26 February 2015, 12:02
userandrew
georgia
Thanks for the quick reply hennie
Old Thu 26 February 2015, 16:49
I would really avoid these integrated solutions as there are really cheap alternatives that require no assembly and work really well and cost the same.
Look for 2M542 on ebay or aliexpress its a 50V 4.2Amp drive.
Old Fri 27 February 2015, 10:50
userandrew
georgia
Thank you Danilom. what kind of bob are you using with that driver?
I've heard of some quirky issues with some of the chinese drivers so I was hesitant to buy any that would require extensive troubleshooting but it seems like you had no issues with yours.
Old Fri 27 February 2015, 13:23
Simple 5 axis bob for 15-20$ (this) , you are isolated on the drives side and on inputs relays 24Vdc that's it ... installed dozen of systems with these components
Only quirky drives are those toshiba 3-4 axis boards and all those integrated ic's. Never seen a mosfet bipolar drive misbehave. And everything that can blow on them is a fuse (when reverse voltage... happens) and you blow up a mosfet with miswiring or it touches the ground (IRL540)
Old Fri 27 February 2015, 18:52
userandrew
georgia
Again thanks... I will give this arrangement a try. I'll start the ordering with a bob, a stepper and a motor to test.
Use Arduino Uno to test stepper drivers and stepper motors Richards 701. Motor Drives 0 Sat 13 December 2014 12:12
80V @ 8A Microstep Drivers as Kit !!! ozanblotter The Market Place 0 Thu 08 May 2008 02:08
Off topic: AC Motor drivers.... GregA Archives 5 Wed 16 January 2008 22:24
Recommended stepper motor drivers - G202 (or G203V?) Gerald_D Archives 35 Thu 03 January 2008 16:36
Parallel Port breakout - getting the signals from the PC to the drivers Gerald_D 80. Computer Hardware & Software 6 Fri 23 June 2006 09:41
