Old Tue 10 February 2015, 09:48
Very nice. ... What size is it? (Diameter)
Old Tue 10 February 2015, 13:18
Originally Posted by lonestaral View Post
400 mm dia, 32mm thick Padauk.
About 16" diam, 1.25" thick
Old Tue 10 February 2015, 13:45
Even at 60.....your still darn good
Old Tue 10 February 2015, 22:48
Wish I had one for some fat cats in our Country.Would send them to a place where it is hot.
Old Wed 11 February 2015, 05:42
Top clamp on all 4 corners.
Circular face the flat area for the symbols.
42mm dia cutter, bottom speed, F1200. A couple of minutes.
Engrave all lines, 10mm v, Mid speed, f1000. 16 Minutes, ran the path twice, saved on sanding time.
Carve the symbols, same as above. 10 minutes.
Rough dish the mid section, 12.7mm Ball nose, 5mm d.o.c., 6.35mm step over, F1200., 20 minutes.
Finish dish, 4mm ball nose, F3200., 50 minutes.
Outside profile, 12.7mm cutter, 5mm d.o.c., f1200, 6 minutes.
A couple of hours to sand, defuzz, seal, varnish and apply a bracket.
A piece of the wood broke away and jammed between the cutter and the outer profile.
There was a jolt. Result, a broken cutter and the Z axis out of alignment.
I made a trammel out of a cutter shank and a 2.6mm welding rod.
The Z is now better aligned than it ever was.
I plan to make a new router plate with gussets welded on.
Should get rid of some slight flexing.
Some of this tropical hardwood is hard and dense.
I could send you one Hennie, but there is no guarantee attached.
Old Thu 19 February 2015, 18:01
Very nice indeed.
Old Sun 08 March 2015, 06:59
Rotating things
I made a simple 4th axis last year.
It was my intention to build a proper one and try a reduction drive.
I gathered the parts over the last year.
After a period of not wanting to do anything for 6 months, I made a start yesterday.
I have 3 nema 23 motors from my old machine.
I made a 6:1 reduction drive from plywood to prove it works.
It did, very impressed.
Started work on the 4th axis today.
The shaft, and other bits came from a scrapyard, motorbike parts, hence the gears.
I have a plan for the nema 23 motors and reduction drive.
It involves a lathe.
I will ask the questions on the 'Catchall' thread.
Old Mon 09 March 2015, 17:55
Been wanting to do this myself, but sit on the couch til the feeling goes away.
Old Mon 09 March 2015, 20:03
Sitting on the couch is more comfortable than sitting on the fence.
Old Tue 10 March 2015, 07:04
Hey, mine is sitting on the floor. Have not had the time to integrate it into the machine yet. So I have been on the floor for 2 years. They say all good things come with time. I am trying to convince myself of that.
Old Tue 10 March 2015, 07:20
silverdog
Just call me: Sergio #70
Rome
Italy
I am in the Club too :-)
Old Tue 10 March 2015, 15:18
Mine too have I really been that busy that I have not been able to get mine fitted or am I just a grade 1 procrastinator?
Old Tue 10 March 2015, 19:40
Once you start 4 sided machining...or continuous 4th axis...it's like an addiction.
Old Tue 10 March 2015, 21:15
Oh sure, Sean....now you tell us....
Old Wed 11 March 2015, 00:38
Take Sean`s word for it.
Old Sun 15 March 2015, 21:53
. Lol.
Old Sun 22 March 2015, 00:52
The Bolt test
I tried out my 4th axis in earnest this morning.
It worked better than I had hoped.
It didn't bat an eyelid .
No missed steps. It worked.
Both the 4th axis and and myself passed the bolt test(as performed by Isla WW).
MechMate, every day a new adventure.
Now, about this lathe.
Old Sun 22 March 2015, 04:29
Nice test!
Old Sun 22 March 2015, 04:41
racedirector
Just call me: Bruce #122
New South Wales
Congrats Al, looks awesome!
Old Sun 22 March 2015, 06:20
Very happy for you.....
Old Sun 22 March 2015, 07:15
silverdog
Rome
Italy
Congratulations !
I wonder if I could 3D print the big pulley ... I cannot figure how much force there is on the rotary axis, the PLA of the 3D priner is very strong but it's not metal ... is driven by a nema 23 motor ?
Old Sun 22 March 2015, 07:59
Silverdog.
Yes it is a nema 23 motor.
Geared 6:1
I took 3mm depth of cut with a 42mm dia cutter,20mm step over in Padauk(hardwood) while roughing out.
No problem.
The big pulley cost 18 Pounds Sterling last March.
Might get another to gear the Z axis.
The dp of the big pulley is 114.59mm, 72 teeth.
Hope this helps you.
Old Sun 22 March 2015, 08:19
silverdog
Rome
Italy
Thanks Al :-)
Old Mon 23 March 2015, 10:47
Very Nice!
Old Mon 23 March 2015, 18:42
I would recommend an idler. If it is 6:1 then I assume then you have a 12 tooth driving pulley. This would leave only 4 teeth engaged in the drive pulley unless your center to center distance is really large. Only a suggestion. Nicely executed.
Old Mon 23 March 2015, 19:44
nicely done....
Old Tue 24 March 2015, 06:46
Thank you for the positive comments gentlemen.
#98, sage advise as always.
Yes, I did think about the small contact area.
If I had a lot of serious work for a 4th axis, I would build another with a longer belt and an idler.(Anyone got a STL file of a bust of William Shakespeare]
But for now my new toy will do.
All part of the MechMate adventure.
Old Tue 24 March 2015, 15:06
If you find that stl, I am interested as well.
Old Tue 24 March 2015, 20:21
There are some on http://www.123dapp.com/
Old Sun 10 May 2015, 06:42
I got back from a visit to England a few days ago.
I got some timing pulleys and belts.(Corian, drill bits , files, screws, tea bags, razor blades) 15kg more than what I went with.
I will make a reduction drive for my Z axis.
Today I moved the electrical box from under the machine
and mounted it on the wall.
I can still get down but getting back up is becoming more of a problem
as time passes.
Started making windows with the mechmate ... #70 - Rome, Italy silverdog MechMates already cutting 100 Wed 26 April 2017 23:02
Lookin for Gremlins - Isarn, TH lonestaral Troubleshooting 8 Mon 02 November 2015 13:10
Oh Can I ?? - Phuket Thailand jek Introduce yourself and start planning 10 Fri 24 June 2011 06:55
Newbie to CNC - Chiangmai Thailand chainarin2553 Introduce yourself and start planning 1 Wed 15 June 2011 06:27
Free Cad and Cam HeekCNC Windows & Linux Regnar CAM 0 Thu 16 September 2010 20:24
