Old Sun 16 November 2014, 23:03
Well stated Jack.
Old Mon 17 November 2014, 03:41
Pete, your screenset is pretty cool. I can see how relocating some of the functions together can work for you. Nice job!
Old Mon 17 November 2014, 07:08
Well said, Gents.
Old Mon 17 November 2014, 08:23
ger21
Just call me: Ger
Detroit, MI
Nice work on that. I know firsthand how long the graphics part takes.
Old Tue 18 November 2014, 04:04
I bet you do Gerry.
Old Wed 19 November 2014, 22:06
Gerry, I know you do and thanks for the compliment. You have a smooth and well organized screenset. A lot of people will attest to that.
I just found a classic programming mistake of rushing when you should be concentrating, this was on a function assigned to a button and it did not match the label. Was driving me insane why the spindle would not work properly. In the end, it was the idiot that was making the screenset.....me. Well it is not the first time, you would think I would have learned by now. Working on the final buttons to be made and scripts for the touch off and auto set the DROs. I used the AskTextQuestion function on most probe buttons to prompt if I want to use the last value or use a new one for most actions and update accordingly. I will update the pics on Dropbox as I can.
I have cut out several labels using the 'shop-vac table'. I am very pleased. I think I may have to pick up some MDF to make a better top now.
Old Sat 22 November 2014, 12:07
Changes uploaded
Old Thu 27 November 2014, 18:31
Mayan Haab I draw up. If anyone is interested, I will post the vectors later. 34" diameter cut out of 0.75" pine.
Glue up
Cutting
Cutout
Old Fri 28 November 2014, 00:06
Nice
Old Fri 28 November 2014, 06:14
racedirector
Just call me: Bruce #122
New South Wales
Impressive as usual Pete, nice job!
Old Sat 29 November 2014, 01:04
IN-WondeR
Just call me: Kim
Randers
Denmark
Wat type of cutter did you use for this. When ever I cut in Pine, then it turns out like crap, cause of the stringy chips. Or is that spruce that does this...
Hmmm, Pine here in Denmark, might not be the same Pine you have...
Old Sat 29 November 2014, 10:55
It is stain grade pine. I find that you have to run feed at little less and the spindle speed higher. I used a Freud 90 V bit, a Freud double flute straight bit and Onsrud up cut spiral. For the most part it will cut clean however being Pine there is always a small amount of finish sanding to do.
Old Sun 14 December 2014, 19:37
Not quite finished, still need clear coat sealer applied.
Almost Done
Old Sun 14 December 2014, 19:44
racedirector
New South Wales
That looks awesome Pete, very impressive!
Old Mon 15 December 2014, 05:08
Very nice indeed.
I will put it on my 'One of these day's' list.
The list is long.
Old Mon 15 December 2014, 05:38
racedirector
New South Wales
I have one of those lists too Al - snap!
Old Mon 15 December 2014, 06:00
Duds
Just call me: Dale
Canberra
I don't have a list, I have a Pinterest Board Does that make me a tragic young punk. My wife introduced me and I love it. https://www.pinterest.com/generalrepairco/cnc-made/
Old Mon 15 December 2014, 07:47
While I do not use Facebook or Pinterest as I feel it uses up valuable time best spent elsewhere. That is a nice board you have Dale. It should be listed under websites that inspire here at the forum.
Old Mon 15 December 2014, 08:07
Mayan Haab crv3d, dxf and eps files in Zip format below. I removed all toolpaths since your tooling will be different.
Click Here
Enjoy.
Old Mon 15 December 2014, 15:46
Top Coat Finished , on Flickr
Old Mon 15 December 2014, 15:54
racedirector
New South Wales
Wow thats big! Looks great Pete, that smile says it all
Old Tue 16 December 2014, 10:50
nice work, looks pretty sharp...any details shots ?
Old Wed 17 December 2014, 10:23
Just what I have on my Flickr page
Old Wed 17 December 2014, 20:10
That looks awesome!!
Old Thu 18 December 2014, 04:59
Hey Pete,
you should put your flicker page in your sig on this forum (nice stuff there)
Old Sun 21 December 2014, 00:46
Thanks Fox. I have had it linked under my home page. Unfortunately this forum doesn't allow end of post signatures or I would have one.
Old Sun 21 December 2014, 05:49
Nicely done Pete, I bet painting it was a real pain in the arse.
Old Sun 21 December 2014, 07:42
Yes it was
Old Tue 10 February 2015, 21:53
Made an update to the machine. Will post picture after painted.
Old Wed 11 February 2015, 21:15
You tease...��
