Old Fri 04 December 2009, 12:10
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
Anyone familiar with Nexen roller pinions?
At first glance, the technology seems brilliant for our application.
http://www.nexengroup.com/nexen/prod...87&mainpn=true
Old Fri 04 December 2009, 12:43
Search this forum for nexen to see a lot has been said about it.
Old Sat 23 August 2014, 08:24
ger21
Just call me: Ger
Detroit, MI
The previous post is probably a spammer who brought this thread back from the dead, but I have something to add.
I'm building my own design 4x8 router. I happened top stumble across a pair of used Nexen roller pinions on Ebay, and bought them $180 each.
I spent a few hours creating an AutoCAD macro that would draw the tooth profile for the rack, and cutout a sample rack from baltic birtch.
The idea was to machine the rack from 3/4" phenolic plate on our Morbidelli router at work.
The sample looks like it should work fine, but I need to machine a sample from phenolic to see how precise I can get it.
My original plan was to use a custom made version of the Servo Belt drive system. http://bell-everman.com/servobelt-linear-drive
I'm still on the fence as to which method I'll use, until I make a sample rack for the roller pinions.
But I think this could be a viable option if the rack can be fabricated accurately and cheaply enough.
One issue I ran into was that these pinions are rather large, and need to use some type of gear reduction. After a few days of searching, I picked up a pair of 21:1 planetary gearboxes with 0 backlash from Ebay. These will be used with 400w brushless servos.
Old Wed 27 August 2014, 16:07
Jason Marsha
Just call me: Jason
B'Town
Barbados
That is a big pinion. What is the bore size for the shaft?
Jason
Old Wed 27 August 2014, 16:37
ger21
Just call me: Ger
Detroit, MI
I think it's 30mm. But I don't need to mount it to a shaft. I turned an adapter to mount it to the face of the gearbox.
Old Thu 28 August 2014, 03:22
However good or bad those Nexen rollers are, I still think that the rack and pinion system is by far the most affordable, easy to maintain, install, to get, etc for a Mechmate user, like Gerald intended with his K.I.S.S design approach.
If anything I would rather upgrade to helical rack and pinion then a Nexen system I think. Still nice to see the outcome of your endeavors though.
Old Thu 28 August 2014, 03:55
IMHO, this is good when there is a space constrain.
If gearbox is needed, then that would defeat the space-saving advantage.
Understanding & Selecting gear pinions - setting the steps per mm[inch] fabrica Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 96 Thu 03 May 2018 06:43
Gear racks & pinions for plasma/router machines [email protected] The Market Place 10 Fri 17 April 2009 14:24
NIKO Track Roller Bearings marchantdice The Market Place 6 Mon 28 April 2008 07:11
Hardening the pinions, (or the racks?) sailfl Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 12 Tue 19 February 2008 12:33
Buying rack & pinions in South Africa JanJC Archives 1 Tue 16 October 2007 23:41
