Old Mon 12 May 2014, 04:08
painted rail !
With proper bare metal prep....paint will stay
Old Mon 12 May 2014, 05:50
Painted rail!
I'm too lazy to paint the rail after the rack is attached. But was hard working enough to sand the rail to white metal with a hang grinder before I paint.
Old Mon 12 May 2014, 06:58
I degreased my metal with acetone, painted everything with Rustoleum paints, and attached my racks with the tape referenced in post 63 of this thread. No bolts on ends, just tape.
Old Mon 12 May 2014, 08:30
dbinokc
Just call me: DB #118
Oklahoma
No paint on the bottom of the rails, but cleaned with acetone before mounting the X and Y racks with tape. I did use screws on Z.
Old Mon 12 May 2014, 08:41
On the paint, no issues what so ever
Old Mon 12 May 2014, 23:15
chunkychips
Just call me: nick
Ok. Painted sounds like it works. Still I might mask off the tape area before I paint if I don't get impatient.
Thanks for the input all.
Old Tue 13 May 2014, 16:40
I attached to prepped clean metal with the tape. No problems with unpainted.
Old Fri 04 December 2015, 14:08
VHB4599 Tape is available as a stock item on Amazon in the USA. At least today.
Old Sat 05 December 2015, 09:29
jehayes
Just call me: Joe #53
Whidbey Island, Washington
thanks
Old Sat 05 December 2015, 12:12
Update: 1200+ hours on tape. No problems yet. Truthfully, I've done nothing but routine maintenance, and not very diligently. A robust design.
Old Sat 05 December 2015, 20:41
VHB is the way to go....holding strong since 2007
Old Sun 06 December 2015, 19:37
I have one side with VHB and the other with standard double sided foam tape. I did this as a test to see which one held better. Both are still holding fine. The key is prepping the metal so there are not any oils or debris that will interfere with the adhesive.
M310100K Springs for loading motors against the racks Gerald_D Motors & their mountings 11 Tue 10 June 2014 05:08
Joining Rack with Excess 3M Double Sided Tape KenC Miscellaneous / General / Whatever / Catchall 6 Wed 08 July 2009 21:19
Laser/Water cutting racks? PEU Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 2 Sat 21 March 2009 10:54
Hardening the pinions, (or the racks?) sailfl Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 12 Tue 19 February 2008 12:33
Fastening the racks to the underside of the rails rkrecak 10. Base Table 2 Thu 03 January 2008 12:56
