Old Wed 23 April 2014, 09:57
dbinokc
Just call me: DB #118
Oklahoma
Still selling Teflon washers James?
Old Wed 23 April 2014, 21:34
JamesJ
Kansas
Yes I do.! PM on the way.
Old Thu 24 April 2014, 18:48
JamesJ
Kansas
Folks
I just got shocked by the huge price increase for Teflon rod. Rod has more than quadrupled in price and there is no way I can make and sell washers at a reasonable price. I am going to do some research to see if I can locate a lower cost material. If I can I will update this thread. Sorry for the bad news...
Jim
Old Thu 24 April 2014, 21:53
I have a partial sheet of Kydex on the shelf I am planning to use for washers for machine #2....We'll see how that works.
Old Wed 07 May 2014, 10:52
jask
Just call me: John
Kamloops B.C.
Most shoe repair shops should be able to order teflon slider sheets for the soles for curling shoes. you can cut the washers out of these.
Old Thu 08 May 2014, 10:43
What about a Crazy Carpet?
Old Thu 08 May 2014, 10:50
What is a 'crazy carpet'?
Old Thu 08 May 2014, 10:55
Crazy Carpet
Kids up here use them to slide down snow covered hills. Very slick plastic sheets.
Old Thu 08 May 2014, 16:28
JamesJ
Kansas
Thanks for the head's up, I'll check this out.
Old Thu 08 May 2014, 16:33
jask
Just call me: John
Kamloops B.C.
Crazy carpets are normally HDPE high density polyethylene while teflon is TPFE the two are not the same and the mechanical properties of the teflon are superior in this application.
Old Thu 08 May 2014, 22:28
Gerald had mentioned that any slippery plastic material could be used. We are not creating a lot of movement at this joint on the machine. Try it and see!
Old Thu 08 May 2014, 23:10
jask
Just call me: John
Kamloops B.C.
the HDPE materials are much more notch sensitive than PTFE... what this means is that a little nick can turn into a crack that spreads to the center and in the case of HDPE it can allow the wings to spread and continue to crack on the other side of the center hole until it splits in two. Teflon will not do this.
Old Fri 09 May 2014, 03:43
Anything slippery & stiff will do. Delrin, POM, Teflon, nylon... etc etc etc.
Old Fri 09 May 2014, 04:46
For what it's worth.... I'm using UHMW for the past....4+yr, still as good as new
Old Sat 10 May 2014, 09:19
JamesJ
Kansas
I have ordered quantities of UMHW as it comes close to the qualities of Teflon but is not quite as slippery and cannot take nearly as much heat. In the mechmate application UHMW's heat profile gives me the most concern. I will make some washers and try them.
Old Sat 10 May 2014, 10:54
No heat ( direct [friction] or indirect [environment] ) is a concern about this specific application here.
I've unmounted a number of time my tranys, therefore had chances to see if any wear & tear.....and...None.
As for slip"ness".....there maybe some difference (in theory from data sheet) may be interesting to evaluate, but what is the bottom..... "practical" line...for our usage ??
Amicalement,
Old Sat 10 May 2014, 11:17
JamesJ
Kansas
Robert, I tend to agree with you and sometimes I dive too deep in the specs
Mechmate for sale in India javeria The Market Place 9 Thu 30 January 2014 04:06
Mechmate for sale? extremecanvas General - MM Build 9 Sat 14 August 2010 15:10
Problems with square washers (also called taper or bevel washers) gmessler 10. Base Table 7 Sun 16 November 2008 06:12
Teflon Washers..... IN-WondeR Motors & their mountings 11 Tue 10 June 2008 20:27
