Old Fri 28 March 2014, 13:59
SEIKI
Just call me: MARK
TROY MI.
I machine a 1" thick plate to 3/4" and then cut the parts out, I then machined the base plate to 1/2" thickness. After I posted the pictures I went and modified the existing base to get lower to the table.This is for a porter cable router that has a 3.500 outside diameter so if anyone would like the DXF file I would be happy to let anyone have it.
Old Thu 03 April 2014, 20:43
SEIKI
Just call me: MARK
TROY MI.
Does your router or spindle face the long or short overhang end of your table?does it make a difference? Right now I have mine set up facing the y axis motor and the long overhang of the table.
Old Fri 04 April 2014, 04:43
Mine faces the short so the spindle cuts the full length of my table. I don't really know if there's a disadvantage the other way except that the backside of the spider is a great surface to mount dust collection stuff.
Old Fri 04 April 2014, 06:41
Same as Tom I believe.
Old Fri 04 April 2014, 15:10
SEIKI
Just call me: MARK
TROY MI.
So what end of the table are you guys using for your x axis 0 or home?
Old Fri 04 April 2014, 15:17
Mine's short x side, right side if you're looking down the x rails, but you can put it anywhere you want it
Old Fri 04 April 2014, 17:58
racedirector
Just call me: Bruce #122
New South Wales
Mark
Take a look at this post:
http://www.mechmate.com/forums/showt...8&postcount=62
Old Sun 06 April 2014, 18:52
SEIKI
Just call me: MARK
TROY MI.
Thanks for that link Bruce,I was searching for that the other day and couldn't find it. I switched things around today and took a short video before I tear it down for paint. Try this link if, it doesn't work I'll repost the correct one.
http://youtu.be/t1_42_28osU
Mark
Old Sun 06 April 2014, 19:10
SEIKI
Just call me: MARK
TROY MI.
I also went to tractor supply today and picked up the paint supplies. Thanks to Mike (metalhead) for the links
Old Tue 17 March 2015, 13:09
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
Nice build,
awesome toys!
Old Sun 22 March 2015, 06:23
A very nice feeling seeing it move.
Nicely done, close to the fun part
The Build is the BOSS!! #132 - Vernon BC, Canada mike nelson MechMates already cutting 47 Sun 30 August 2020 23:54
Joining you from Florida Learning to build - Mia, FL Ruffs700 Introduce yourself and start planning 7 Wed 20 July 2011 21:42
Started build with 4th axis erich Construction started, but not cutting yet 3 Wed 02 June 2010 10:10
Just started the build - Auckland, New Zealand wheelygood Construction started, but not cutting yet 24 Sat 03 April 2010 02:01
Canadian User Joining Group ACFerguson Introduce yourself and start planning 17 Mon 08 February 2010 10:37
