#91
I think he is already on it.
#92
I work part time, and go back on Tuesday
#93
Construction has officially started
![]() Got 50% of the base welded over the weekend and continued today to start the final pieces. Did a quick check to see if everything was fitting as per the pic. I was going to weld the side panels but after spending the day trying to do just that I have decided to bolt everything so my tack welds will be broken and mounting plates added to each section. I have more work for the next couple of days so the next update will probably be around this coming weekend. It is definitely exciting seeing this thing go together, so looking forward to doing more! Cheers |
#94
Looks very sturdy Bruce.
Ross |
#95
Looking good mate !
Will you be offering those bikes for sale on the net ? Looks as if some of that other stuff will have to go as well, or will you be going on a diet ? |
#96
Thanks guys
Al, its being initially built on my garage entry driveway, I can't get it in my garage just yet as my other 4x4 cnc is in there along with a long neglected model railroad in the making. Oh and alot of that in the driveway is destined for the skip bin that I haven't got yet ![]() |
#97
You'll need a skip when your MechMate gets going.
Offcuts, Skeletons & lots of lovely dust. Whats the story with the other C.N.C. ? I cannibalized mine. The bed ended up as a top for a bench, somewhere else to stack offcuts and junk. |
#98
Hahaha, thats what most of what is in the background is, offcuts and failed projects.
The other CNC is a Joes CNC, one of the original leadscrew versions, aluminium extrusion and MDF. Never had much luck with creating anything of worth from it. I could have enhanced it to make it better but for a little more I could build the machine I have always wanted, namely a Mechmate so the decision was made to just fix up the old one once my MM is cutting. That machine will end up in the driveway to make room for the beast in the garage ![]() |
#99
Once you get your MM going... I doubt you will bother with your old Joes any more...
#100
Been looking for more 65x50x6 for the past couple of days with no luck. The last place I got my other lot from now have a $250.00 minimum spend. Ended up buying 65x65x6 instead which only means a little more effort to get one leg down to 28mm. Oh well, such is life.
#101
I agree Ken. The entry level machine I posted pics of at the beginning of my build thread has gone untouched since the first day the MM came to life.
Probably should sell it to someone else looking for an entry level machine. |
#102
A little more progress. Lower table fully welded, tomorrows job is to perfectly square it up (currently 4mm out of square) and drill & weld the PFC mounting plates and foot plates.
#103
Found my 25 yr old drill press wasn't big enough to drill the 200PFC and was dreading drilling holes with a power drill. Happened upon a drill press for sale at the local camper manufacturer yesterday and bought it today for $200. Lovely old beast built like a tank, comes with a 20mm chuck, multi speed etc etc. Give me an old used too any day over a chinese import new one!
#104
Speaking of tanks, your frame is one. That puppy is solid. Nice work!
#105
Thanks Pete, wanted to make it as flex proof as possible. Didn't want any "leaning on the machine" to affect the cutting like some other cnc's out there
#106
Frame looks about right to me...
#107
Mike needs to move you into the Construction Started heading. I think you are well out of the planning stage.
#108
Speaking of moving, have you got an overhead crane or will you invite the rugby club over.
Looking good. ![]() |
#109
Thanks Mike for the move!
Al, she is all bolt together so I am simply unbolting the bits and reassembling the right way up, no cranes involved, only muscle for the main beams ![]() |
#110
Bruce,
If it is all bolt together. Once you have it leveled and square, take the time to put in locating pins/dowels and stamp each piece as to location (ie AA, 1E etc. Then if you have to move it later to another location, setup will be easier. |
#111
Good idea Pete, thanks. Was just looking at metal stamps on ebay, bit pricey but I will continue to look for some cheapo sets. Will also grab some roll pins for the task.
Oh, and got my final motor plus a roll of tape for sticking the rack on. Went with Husky tape, $65 odd for a 16.5m roll of 2mm thick, 15mm wide A5200W. Priced 3M VHB but it was double that here in Aus. Bought my toroid (35V 4.5A x2 300VA), my 10000uf 100V caps and the bridge rectifier the day before. All I have left to buy is some wire, a gas strut, one more motor spring and work out the cable chain stuff. All I will need after that is time...... Last edited by racedirector; Thu 19 December 2013 at 00:06.. |
#112
Just use a center punch.
1 dot to 1 dot. 2 dots to 2 dots and so on. Or you could do a dotty A,B and so on. |
#113
Brilliant Al, sometimes it takes others to point out the simple methods instead of over thinking and spending money. In my case spending money is a bad thing!
#114
![]() My father taught me to be economical. All the company's I worked for were tight fisted. I learned to make do with what I had and to be inventive. Glad to have helped. |
#115
Don't use a roll pin, they will shear or suffer shear marks between the two pieces of steel when a force is applied for a long period of time. Use of alignment dowels is preferred then roll pins if you cannot obtain them.
#117
I gave my old CNC a chance to be resurrected while I build my beast today and it let me down as usual. So as punishment I am pulling it apart tomorrow to make room for the MM to be built in the comfort of a closed garage.
With that done I am hoping to have something workable by the end of January 2014 depending on work. Roll on 2014, the blue beast is coming ![]() |
#118
You know what they say,
"Out with the old and in with the new". Wishing you all the best for the year ahead. ![]() |
#119
Just rang a local one man engineering shop to ask about boring out my pinions. Quoted $10-15 each which I thought was pretty good - $40 to $60.00 for the lot and more accurate than me using a drill press. Will drop them up next week.
No progress on my build, still clearing the garage inbetween the heatwave days here in Sydney's West. Old machine is gone though so have no CNC to distract me from my task. |
#120
Made some progress this week, hope to have the machine standing right side up ready for the top bits by the end of the weekend.... in the garage instead of the driveway
| Ordering Parts - Sydney Australia | Bazza | Construction started, but not cutting yet | 43 | Thu 13 August 2015 20:20 |
| Belt Drives, Control Systems & Machining | islaww | The Market Place | 2 | Fri 18 July 2014 12:25 |
| 12/14 free machining mild steel | Quadro | Cutting various materials - bit selection, feeds, speeds | 8 | Tue 02 October 2012 22:31 |
| New Sydney Mech Mate, 3700x2100 | G30ff0 | Introduce yourself and start planning | 8 | Fri 08 October 2010 08:33 |
| Machining of the rails | jeff | Archives | 23 | Wed 20 June 2007 08:43 |
