Old Thu 14 November 2013, 09:47
IMMark
Just call me: Mark #119
Columbus Ohio
I call her Big Blue #119 - Columbus, Ohio
Can someone tell me, what actually hits the x rail stopper block (10 10 248)?
Is there something on the gantry that hangs down and catches it?
Also, regarding installing the x rails; did any of you make the holes through the main x beam somewhat larger to give some adjustment room for the x rails? Or is that not a good idea?
Mark
Old Thu 14 November 2013, 11:29
parrulho
Just call me: Paulo #108
willemstad
Netherlands Antilles
is the limit switch support bracket... M1 18 000. About the holes on main beam they are already more large on rails to give adjustment.
Old Thu 14 November 2013, 14:48
IMMark
Columbus Ohio
Thanks Paulo
I appreciate the answers!
Of course, it brings up more questions. Does anyone know (maybe Metalhead)...why are the stop blocks (SB4) sold as a set of 3? Am I missing something here....don't you need 4 of them?
Mark
Old Thu 14 November 2013, 15:08
2 for the gantry (1 on each side) and 1 on the Y-car, the gantry needs 2 because its so wide and is possible to twist out of shape, the Y-car is very stiff and relatively small so only needs the one (it fits on the side where the motor is mounted)
Old Thu 14 November 2013, 15:39
IMMark
Columbus Ohio
Thanks Alan...that makes sense.
Mark
Old Tue 19 November 2013, 12:55
IMMark
Columbus Ohio
I have another couple of questions.
1. As far as the installation of the racks. Is the general consensus, to use tape only or to still attach each end with bolt?
2. Regarding Prox. Sw. target hole, is it drilled all the way through the rail, but stops at the main x beam?
3.Can Prox. Sw. be added later, if the target hole is drilled and the mounting hole through the stopper/limit Sw. assembly? Is wiring them in later anything consideration?
4. How long is the adjusting bolt through the x rails stop blocks? I am in the US and went with 5/16-24 holes in the blocks.
As always, thanks for any input!
Mark
Old Tue 19 November 2013, 15:06
1. VHB tape is fine only
2. Hole thru the rail, but not into the main beam
3. yes, any of the proximity sensors can be added later. The stops should be installed during initial build and are important.
4. my machine used a 2" fully threaded bolt w/ jam nut. Threaded the square bar stock and welded it to the rail as noted in drawing past the proximity hole. This gives you about 1/2" of fine adjustment of gantry square. More than enough.
Old Tue 19 November 2013, 16:48
IMMark
Columbus Ohio
Fast reply..and all answered : )
Thanks!
Making progress, I am sure there will be more questions...but it is coming along!!!
Mark
Old Thu 21 November 2013, 09:33
IMMark
Columbus Ohio
Two more questions.
Is it critical if the X rails are 1/8" short?
Regarding painting the X rail. Do you try to tape off the gtound part orpaint it all and sand the paint off the ground part?
Mark
Old Thu 21 November 2013, 10:08
What is mostly affected is the swing of the motor plate and the size of the pinion.
For the most part, you should not be affected.
If you have a 30-35T pinion...no issue. If you have a small 20 or 24T pinion you may not fully swing into full engagement in the rack. I have been there!
Regardless. You should be okay.
Tape off the V area. Or, it will wear off in about a week! Not terribly critical.
Old Thu 21 November 2013, 10:14
IMMark
Columbus Ohio
Great news...and thanks for the fast replies!
More to come I am sure.
Mark
Old Thu 21 November 2013, 19:28
...glad to help when we can.
Old Sat 07 December 2013, 09:15
IMMark
Columbus Ohio
Couple of more questions...
Regarding stopper lip (M1 18 022)
The specs call for a thickness of .200", I would like to be able to use .250".
Is it ok to use the thicker stock, and if so...do I need to adjust the overall height of the finished assembly, to accommodate the extra .050"?
Also, I am a self taught metal worker (and still teaching myself stuff)...so, how do you guys make the wedge shaped cuts in the angle iron of the same part?
Thanks for any advice!
Mark
Old Sat 07 December 2013, 10:49
I used 0.250 angle.
Old Sat 07 December 2013, 10:52
You need that cutout for the prox switch if you are using one. I used a mill but it can be done with a bandsaw and grinder, a grinder with cutoff wheel, only your imagination is your limit there.
Old Sat 07 December 2013, 11:34
IMMark
Columbus Ohio
Thanks Pete
After looking at the drawings again..I guess the thicker stock doesn't effect it. I was thinking it would make the height .050" too much...but it is still just 1" wide.
I have a milling machine too...still learning how to use it...but I was going to give it a try, using a swivel vice? 2nd option was to go at it with a cut off wheel.
I will see how it goes...thanks again for the suggestions!
Mark
Old Sat 25 January 2014, 16:05
IMMark
Columbus Ohio
Time for some more questions!
Regarding the spacing of the v wheels for the z plate. The post here; http://www.mechmate.com/forums/attac...1&d=1215270307
States to add 11mm for the hole spacing in the spider. The v wheels that I have are from Superior Bearing (where I think most people get theirs from) but the bore on them is listed as 0.4724" (0.039") difference from the 11mm? Am I missing something here...any input is appreciated.
Mark
Old Sat 25 January 2014, 16:34
The v wheel spacing in the drawings is only a GUIDE to layout.
Depending on your z-plate stock (which in many places in the work is either 100mm or 4" (which is 101.6mm).
The bearings which are BWC compliant should be 12mm and the offset studs are 1/4" bore with 12mm shank. The Superior bearings should be 12mm which is .4724" imperial.
Old Sat 25 January 2014, 18:31
IMMark
Columbus Ohio
Thanks Sean
I made a mistake and had to re-weld the holes. I am triple checking everything this time!
Thanks for putting my mind at ease.
Mark
Old Sun 02 February 2014, 14:37
IMMark
Columbus Ohio
Does this sound like it meets the E chain requirements?
ID: 15/16" x 1 1/2", OD: 1 3/16" x 2" , Bend radius 5.5" chain center to chain center?
Mark
Old Sun 02 February 2014, 19:56
looks small to me.
I used IGUS E-chain that was almost 3" wide, 1.75" tall and bend radius of 8" (or 6")...but much larger than what you have.
The inside fills up quickly.
3 - 4 core18 gauge
1 - air hose
1 - 12/3 for router or spindle
1 - 7 core control cable
2 - 18/2 for button station extras
...air
Old Mon 03 February 2014, 13:47
IMMark
Columbus Ohio
OK, thanks.
I wonder if it would be ok for the Y run?
Also, what do you use the air line for?
Mark
Old Mon 03 February 2014, 13:53
Air line I have used for many things, but mostly:
- air powered automizer for cooling of tool when cutting alum or plastic
- blow air to direct the dust pickup with 1/2 of dust shoe removed when using specialty cutters
- run air drill when I change out spindle for drilling operations.
- I also test using it with my DA sanders as a type of polishing fixture ( once )
Old Tue 04 February 2014, 10:31
IMMark
Columbus Ohio
Thanks for the tips...must have airline
Looks like Igus E26.07.063 should handle all needs?
As for placement of the fixed end, is it located at table center or is there an offset?
Also, as a side note...on laser cut parts, do you knock the "sharp" edge off ?
Mark
Old Tue 04 February 2014, 12:08
Fixed end placement? Can you elaborate? - not sure what your asking.
I touched all the laser parts with flap wheel disk to break all the edges (the paint sticks better on smooth edge)
The igus you picked will do...I found that or similar on Ebay when I built my machine.
Old Tue 04 February 2014, 15:44
I used a BD powerfile for breaking the edges of the lasercut parts. It gives you more control and you can enter smaller corners than you can with the flapper disc. One of my favorite tools, I use it very often on all kinds of materials and projects. But a flapper disc and some hand files will do as well. Even hand files alone will do. The paint will creep away from the sharp edges if you don't do this.
Old Tue 04 February 2014, 16:40
IMMark
Columbus Ohio
Sorry, by fixed end. I meant the largest of the cable chain shelf parts. I don't see where it placement is on the main x beam?
Also thanks for breaking edges tips Fox and Sean....I have started doing them now.
Mark
Old Tue 04 February 2014, 20:51
IMMark
Columbus Ohio
Also, Sean I read your post in the E Chain section, regarding the length of chain to order for a 5 x10 table...buying in 5 feet sections , 3 would be more than enough (15 feet total) for both the x and y's?
Dose that sound right?
Mark
Old Wed 05 February 2014, 07:30
Mark,
15' should be enough.
The quick calculation for the correct amount of chain is 1/2 (length of axis travel) + 1/2 bend diameter + a little bit.
So, in practice, if you have a 10' table, you will need 5' move + 2.33' bend + a little extra for the x axis. Which is about 9'
The y axis is 2.5' move + 2.33' bend + a little. Should be about 5.7'
Just double check the bend radius for that IGUS chain to be certain that you have enough length to make the 1/2 diameter distance without being short.
Old Wed 05 February 2014, 09:30
IMMark
Columbus Ohio
Thanks!
I wanted to be sure about the formula. Igus lists the radius as 2.48-9.84. I guess that is a min. and max?
Why thoughts on my placement question? I may not have explained it well. I am not sure how to determine where along the main x beam, to attach the first bracket that will support the fixed end of the E chain. Is it at the center of table length it is there an offset?
Mark
Suddenly, production! Cutting, Labels and Blue! #110 - Montgomery, IL sierra347 MechMates already cutting 21 Wed 18 September 2013 18:59
New Mechmate Started! - Columbus Ohio IMMark Introduce yourself and start planning 23 Tue 30 April 2013 14:03
Call me Wade - Brighton, Colorado dkwllc Introduce yourself and start planning 1 Wed 03 February 2010 11:14
3D Sign from Blue Foam astrolavista The Show Room 3 Sun 12 July 2009 19:09
Small logo cut in alu - Blue Ridge, Texas DocTanner MechMates already cutting 5 Mon 14 April 2008 14:10
