Old Sat 28 September 2013, 05:08
Wooaow....that was fast
Congrats....many hrs of fun to come
Enjoy
Old Sat 28 September 2013, 05:38
Its Alive! Excellent Job Al!!!
Old Sat 28 September 2013, 16:12
Bravo!
Old Sat 28 September 2013, 16:50
SWEEET!!
Great job.
Old Sun 29 September 2013, 23:18
Smile 144 Holes
Thanks for the kind comments.
Just run its first proper program.
144 holes 10mm dia in the spoilboard for my clamping arrangement.
1 hour 55 minutes.
Old Mon 30 September 2013, 06:29
Awesome !!! Now for some logos !!!
Old Mon 30 September 2013, 06:50
Moved
Wow !
Its moved and I have been moved.
I spent the afternoon installing the T nuts. Boring but it had to be done.
More to do tomorrow weather permitting.
The remains of " Typhoon Wutip " are heading directly for us.
I had a lucky escape this afternoon.
The machine was powered down.
I was using a pistol drill to finish some holes.
The pinions were engaged so I was using both hands to move the gantry.
The gantry stopped, without thinking I gave it another pull.
It moved a bit.
Then I realised something was wrong.
The extension cord was wedged under a V wheel.
The cable was thin so I was lucky I did not give it another pull.
Next time a proper extension lead and not across the machine.
Been a bit ironic if me and the machine were finished on the same day.
Old Wed 02 October 2013, 04:47
Spoilboard
Z slide & Router squared to the bed.
Spoilboard faced.
Logos on order.
Getting there.
Old Wed 02 October 2013, 07:19
Glad you averted the close call with the cord.
Machine is looking really good.
Old Wed 02 October 2013, 09:27
zumergido
Just call me: Fernando
BS AS
looks like your spindle is not 90degrees on the y x axis. that make a pattern when you face the spoil board.
there is a easy system with a wire and a drill bit to calibrate the spindle. i cant find any tutorial online. i have to make one.
Old Wed 02 October 2013, 10:01
There are 2 ways to set yout Z axis perpendicular to XY plane.
1) the simple way. eye balling a set square the cutting bit to the table (after it is surfaced
2) the complecated way which I won't go into as it is very well documented somewhere in this forum.
Old Wed 02 October 2013, 12:50
Super quick and easy way........
Cut a 24" x 24" square double or triple thickness FLAT MDF/PLY base....drill 1/2" hole in middle
Chuck up router/spindle in collet - then tighten the machine world around the base and spindle.
Surface the table.
Do it again, this time use a L shaped scribe and feeler gauge if needed to set the pitch/yaw of the assembly.
Personally, I used (2) framing squares to set the z-plumb in the y carriage in the x and y direction. Then I connected the router to the z and did it again.....The second time I did it the first way I described and saved about 3 hours.
Old Thu 03 October 2013, 00:00
Smile Testing Times
Thank you for your concerns and comments.
I squared it using the facing cutter.
Perhaps not perfect but good enough for what I want to do for now.
I am very pleased with the machine and its performance.
I ran a test this morning.
Everything cut the right shape and size.
Like a hot knife through butter.
Old Thu 03 October 2013, 02:02
Logos
One MechMate reporting for duty Sah !
Old Thu 03 October 2013, 05:27
..definitely has the logo part covered!
Congratulations...happy cutting
Old Thu 03 October 2013, 08:00
I thought I had a lot of logos.....lol.
Just kidding, machine looks great.
As you gain experience, you will look at every project, no matter how simple, and think: How can I do this with the MechMate?
Old Thu 03 October 2013, 15:36
Jolly good!...carry on...
Old Thu 03 October 2013, 20:28
I like the motor logos !!! You get #114 !!! Congrats !
Old Thu 03 October 2013, 21:03
Cool #114
Yahoo !!!!!!!!!!!!!!!!!!!!!
A number, thank you very much.
Very happy to be here.
I saw the .dxf for the motor logos.
Someone said about keeping dust out of the rear bearings, so I ordered a set.
The blue is a bit darker than what I wanted but it might fade with the sunshine.
I said in my first post that I spent 25 years on other peoples machines.
Now I have one of my own.
Absoutely brilliant.
Thank you all.
Now I had better go and do some work.
Old Thu 03 October 2013, 21:09
Now its time to start building cool stuff.
GREAT JOB!!
(I have the same motor decals on mine.)
Old Thu 03 October 2013, 21:43
digger
Just call me: Milosh #113
Toronto
Happy dusting Al.
Looks very nice.
Old Thu 03 October 2013, 21:49
Congrats! Looks great!
Old Thu 03 October 2013, 22:25
Updated Builder's Log
Al,
Here is the Updated Builder's Log with your entry added.
Congratulations on earning Serial #114 on a great machine...and FAST too!
Old Thu 03 October 2013, 23:56
On the Masthead
Thank you Gent"s.
Number nailed to the Mast.
Thanks for updating the build log.
Just a small point on the "Builders Log"
The Y travel is 696mm (It could be somewhere over 700mm if I changed the hard stops)
What is a "Small form factor ?
I think the build hours are about average.
It took me about 500 hours but I had nothing else to do all day.
Now I have something to do all day every day.
Mrayhursh
Just call me: Hurshy
Riverview, Florida
First Project
Congrats on your build. Can't wait to see your first project(s).
Old Fri 04 October 2013, 06:41
Detail
I had a play about this afternoon.
Quite impressed with the small detail on the rose (30mm dia).
A bit like watching a Sumo wrestler dance in a Ballet.
Well pleased.
The rose is in Tamarind.(End grain)
The ship in Padauk.
Old Fri 04 October 2013, 18:12
I love it!!! Sumo at a ballet!!! Good description!!
Old Sun 06 October 2013, 03:19
Work in progress
I had a couple of cable drum ends(plywood) that I salvaged a couple of months back.
I saw Darren Salyers gear and thought why not.
Glued some mdf offcuts to the ply.
Well impressed the way my machine cut the teeth.
I will have to turn it over to cut the teeth full depth as the cutter was too short.
Hope to finish machine it tomorrow.
Old Sun 06 October 2013, 06:19
I'm jealous, everyone is making their own gears but me
Old Sun 06 October 2013, 07:36
Don't worry Tom.
One day soon you will be heading away from the kitchen table and carving signs "Get your gear here"
Started making windows with the mechmate ... #70 - Rome, Italy silverdog MechMates already cutting 100 Wed 26 April 2017 23:02
Lookin for Gremlins - Isarn, TH lonestaral Troubleshooting 8 Mon 02 November 2015 13:10
Oh Can I ?? - Phuket Thailand jek Introduce yourself and start planning 10 Fri 24 June 2011 06:55
Newbie to CNC - Chiangmai Thailand chainarin2553 Introduce yourself and start planning 1 Wed 15 June 2011 06:27
Free Cad and Cam HeekCNC Windows & Linux Regnar CAM 0 Thu 16 September 2010 20:24
