Old Sun 16 June 2013, 20:10
IMMark
Just call me: Mark #119
Columbus Ohio
Warning: Do not do business with Wny-Supply
Just to warn others so they don't fall victim as I have!
I purchased a phase converter from Wny-Supply.
After receiving the unit I hooked it up to a Bridgeport milling machine. After about 20-30 mins of operation, the motor got so hot that is burnt out. Since the mill was new to me, I assumed that the motor was bad when I bought it. So I purchased a new motor, hooked it up. This time I kept close eye on the motor...and sure enough, in short order it started to over heat! The problem was with the phase converter! I have attempted to contact Wny-supply for the last two months, without a single word in reply! Although my emails were promptly returned when I was purchasing the unit, all attempts to even discuss the matter went ignored. I will gladly eat the cost of the unit, and will tell others of my experience to hopefully save them from going through what I have. Please be warned, terrible business practice...don't trust the company or their products!!
As a side note, I purchased a Teco VFD and have been very happy with the product!!
Mark
Old Mon 17 June 2013, 05:10
Mark,
I have a Teco VFD from FactoryMation and it has worked very well.
Old Mon 17 June 2013, 06:28
IMMark
Columbus Ohio
That is where I purchased my VFD as well. Great product for sure.
Knowing what I now know, a VFD is the way to go.
Mark
Old Tue 18 June 2013, 05:14
gixi
Bucharest
Romania
VFD setup
Hello IMMark,
One year ago I bought the VFD from Delta (Romanian representative) and the spindle from China. I install everything as a kitchen project (as Gerald teach us) and the spindle become very hot.
The service man from Delta told me that I have a wrong setup of the VFD and he told me by phone how to setup everything and till now everything is OK.
So you should give a second look on your VFD setup.
Old Tue 18 June 2013, 15:30
IMMark
Columbus Ohio
The phase converter that I bought (sadly) from Wny-supply, was a Static Phase converter. That is the one that was not worth buying, and had no support from the company. The Teco VFD works great!! They actually both hook up, basically the same way. I am in the US, using 220v, single phase at 60Hz.
But thanks for the suggestion.
Mark
Old Wed 19 June 2013, 12:09
What TECO are you guys using? I have a 7300 series, but do not have a spindle to test it with yet. I want to offer a matched set and one of my kits.
Old Wed 19 June 2013, 15:09
IMMark
Columbus Ohio
I have Teco FM50, the 230v is available from 1/4HP to 3 HP (which is what I have on my mill, the 3 HP that is). I have it wired to remotely reverse motor direction and on a potentiometer for speed control.
Mark
Old Wed 19 June 2013, 16:09
This is what I am using.
TECO 7300CV AC Drive, 5 HP, 230V 3 PH Input, 230V 3 PH Output, 17.5FLA, IP20, Frame 2 (JNTHBCBA0005BC-U)
I have a square body air cooled spindle that I purchased from Dale in St. Petersburg, FL. He designed the spindle and has it manufactured in China under his specs. I paid $660 for the 3 HP spindle. He stands by his spindles. I own two of them now. I recommend him.
Post 513 is a picture of it.
http://www.mechmate.com/forums/showt...?t=794&page=13
Old Wed 19 June 2013, 22:52
How did you get 3 phase in? Are you wired for 3 phase in your garage?
Old Thu 20 June 2013, 03:36
MetalHead,
I am not in my garage. I have not been there for some time.
I ran 3 phase for the spindle.
Old Thu 20 June 2013, 16:36
The Delta VFD that I used with my Columbo 3hp spindle converted single-phase 240VAC to 3-phase. The VFD was rated at 5HP to allow it to perform that conversion. It's my understanding that many VFDs can be fed from single-phase supplies as long as the VFD is rated at 2X the current of a 3-phase unit. Check the owner's manual.
Old Sun 23 June 2013, 19:09
zumergido
Just call me: Fernando
BS AS
i allmost kill my spindle. 3hp elte with a lg VFD couse i set up it wrong. after a second reading everything works fine. even see some smoke..
Big 3 Dimensional Sign for own business Roadkill_321 The Show Room 14 Sat 07 April 2012 12:56
The Power Supply needs only to supply 2/3 of the rated motor current Gerald D 702. Power Supplies 0 Sat 05 December 2009 21:09
The MM is built. Now what ? - Building the business on 5 questions gixi Miscellaneous / General / Whatever / Catchall 1 Tue 13 October 2009 11:07
The fun of doing business in Africa Gerald D Miscellaneous / General / Whatever / Catchall 6 Sat 09 May 2009 12:30
