Old Tue 14 May 2013, 08:03
carcan
Just call me: Carlo
Camparada
Italy
Heavy duty and cheap motor connectors
To connect motors I bought this cheap (plug & socket only 5 euros) connectors
File Type: jpg $(KGrHqVHJDkE63ZdB++JBO155Us0Zw~~60_35.jpg (4.1 KB, 366 views)
Old Sun 19 May 2013, 15:52
silverdog
Just call me: Sergio #70
Rome
Italy
Ciao Carlo,
Where ?
Did you buy the laser parts in italy ?
thanks
Sergio
Old Mon 20 May 2013, 02:34
Sergio, that is the connector between motor car and trailer - many automotive places sell them.
Old Mon 20 May 2013, 02:54
silverdog
Rome
Italy
Thanks Gerald,
Yes that conector is easily available, maybe a litle too large for my taste.
Old Mon 20 May 2013, 03:17
The modern trailer connectors have become much smaller. But, I still would not use any connector. It is almost never needed to disconnect the cable from the motor - so few times that we can cut the cable and make a new soldered joint if we need to. This is the joint that I trust the most - solder (or crimp).
Old Mon 20 May 2013, 03:57
silverdog
Rome
Italy
Yes I use no connectors, the only problem I had with my Mechmate were the gecko connector which were a bit loose, I had to disassemble them and tight the spring. My Mechmate is going to have a new house (a professional location instead of my garage) so a minimum disassemble is needed .... but as usual your advice is the simplest and the better, thanks.
Old Mon 20 May 2013, 07:58
carcan
Just call me: Carlo
Camparada
Italy
I would use these connectors because I want to share the electronic box with a hot wire CNC foam cutting machine
Old Mon 20 May 2013, 08:41
silverdog
Rome
Italy
Yes I'm thinking about adding the 4 axis and one possible simple and economic solution is to use the electronic of one the X axis (as far as I understood I don't need the X axis movement when the 4th axis is in use) with a mach3 dedicated setup and a dedicated motor.
Heavy Duty Leveling Feet SOLD! JamesJ Archives 3 Tue 08 January 2013 21:29
Stepper motor connectors mrloeng 70. Control Systems 0 Mon 15 March 2010 04:45
Soldering DB9 connectors on the motor cables for the Gecko G540 Gerald D 60. Wiring & Cable Management 34 Sat 23 January 2010 12:19
what about connectors like this? revved_up 60. Wiring & Cable Management 7 Tue 24 February 2009 18:59
Heavy spindle mordalez 40. Z-Slide 3 Sun 11 January 2009 09:49
