Old Thu 04 April 2013, 00:09
The Youngin
Just call me: Jason
Santa Clara (CA)
Cutting wrong measurement
Ok,
So my mech mate is running very well. The only issue so far is that the cut is short ever so slightly. Tops 1/16 over 48 in (calipers show near perfection)
I've ran the steps per calculation, Still off ever so slightly....
The bit also does not end smooth every time (primarily on rectangles)
It produces a small lump at the start point. Way worse if I run lead ins.
I'm extremely frustrated,
And ideas would help,
Jason
Old Thu 04 April 2013, 00:14
Specs on your machine? Motors? Router? Size of your table?
Pictures, Logos?
Old Thu 04 April 2013, 00:16
What software did you use to create the Gcode? What size bit are you using? What software are you using to run the MM? More details are needed.
Old Thu 04 April 2013, 02:48
If you have marks on start point and its larger with leading then you have some mechanical slop in system, check pinions or belt drives, check v-wheels
and of-course show us your MechMate
Old Thu 04 April 2013, 20:53
Red_boards
Just call me: Red #91
My fixes were:
Check bit (Z-axis) is vertical to table
Tighten Z rollers
VFD wiring - right or wrong javeria 60. Wiring & Cable Management 12 Tue 27 July 2010 21:41
Coil Inductance measurement, is this normal? KenC Motors & their mountings 8 Thu 19 November 2009 02:36
One motor goes wrong way - How to reverse its direction grandpi Troubleshooting 2 Sun 17 February 2008 23:03
Machine runs far too slow (or fast) and the wrong distances - Confusing inch/mm 's Hugo Carradini Troubleshooting 2 Tue 25 September 2007 10:44
Failure Mode and Effects Analysis - What if something goes wrong Gerald_D Archives 0 Wed 07 March 2007 23:44
