Old Tue 05 February 2013, 05:20
saas
Just call me: saas
ceje
Slovenia
npn -relay- pmdx-122 wiring diagram
After much thinking, ... I was unable to resolve this
how to connect this?
I hope that there is someone who has the time to help me
tx
Old Tue 05 February 2013, 05:55
See if this helps you.
There is some additional stuff that you don't need.
Old Tue 05 February 2013, 06:39
saas
Just call me: saas
ceje
Slovenia
first like to thank you found time for me and your explanation
means,
I have to have a power supply of 12 V DC!?
which is most commonly used?
Old Tue 05 February 2013, 10:42
Or 5v or 24v or other.
Personally, I ordered a power supply from Antek with:
56V tap for steppers
12V tap for prox circuit
5v tap for laser, led's
Old Tue 05 February 2013, 11:11
saas
Just call me: saas
ceje
Slovenia
I have a toroid trans output of about 30V and 9V/1A
can I use the 9v for pmdx-122 and prox?
Old Tue 05 February 2013, 12:06
Most Prox are 12v/24v but to vary. For instance, you can order a version that is 10vdc-30vdc allowable. 9v might be low for the sensor to activate and sense properly.
Old Tue 05 February 2013, 12:20
saas
Just call me: saas
ceje
Slovenia
hmm,
Then, without complicating remains (repeatedly presented)
DC Switching Power Supply,
Slim-line,
DIN-rail mount,
Plastic Case,
12V/4.2A Output,
85-264VAC Input
Do you agree?
Old Tue 05 February 2013, 18:16
4.2A (50VA)is too big... you can save easily 50% if you go for a 2A SMPS which is still too much capacity for just 3 proxy switches. If I remember off the back of my head, each swith is 200mA & a3x200ma=0.6A double safty factor (which is already way too much for such application) is 1.2A & triple the safety factor is 1.8A... Why don't you save the difference in price to get a 6-pack?
Old Wed 06 February 2013, 00:46
saas
Just call me: saas
ceje
Slovenia
..on this data I'm not careful
thanks Ken
PMDX-122 vs PMDX-125? salewis 70. Control Systems 6 Fri 06 November 2009 06:16
PMDX-132 instead of the PMDX-122 SteveWellman999 70. Control Systems 23 Mon 02 November 2009 12:47
PMDX-122 & Geckos 203V Diagram ??? kanankeban 701. Motor Drives 1 Thu 08 October 2009 00:00
Servo motor encoder wiring - is my diagram correct? rocky2889 70. Control Systems 10 Sun 01 March 2009 21:49
PMDX-122 relay output voltage? chopper 70. Control Systems 10 Thu 04 December 2008 08:00
