#151
![]() Hoping this turns out great for you ![]() |
#152
Nice chair... good work!
#153
Another project just because.
Friend of mine lost his dog recently, so I cut this out of a scrap sink cutout of Livingstone solid surface material. ![]() It is way easier to read in person than a pic. |
#154
Moving more and more into panel processing.
Does anyone have a link or even better, plans for a DIY vacuum panel hoist? I have an old electric hoist, and a sliding door track already. Mainly looking for the vacuum pod/human interface part of the equation. I saw one on another forum I liked, but it was very scarce on details. |
#155
A coffee table project for a friends mancave.
Reversible Mahogany top in a metal welded frame. ![]() ![]() Last edited by darren salyer; Thu 13 December 2012 at 18:03.. Reason: fixed spelling |
#156
MDF bleeds air bad so lets hope you can get at least 5 InHG of vacuum. You would have 2.5 Psi. 80lbs (MDF) / 2.5(Psi) = 32 square inches to lift your sheet. A 4"x8" vacuum pod should lift a 80lbs sheet. You should figure in a bit more for bumping sheet into things and the jerking motion of the lift. Even if you double the size it will not be that bad as far as size of the pod. What you will run into is your pump may not be able to keep up with all the free air of the MDF. Bigger can actually hurt you more. Have a look at this for building a pod. http://joewoodworker.com/veneering/vacuumclamping.htm A simple 3 way valve would work just as good. http://www.ebay.com/itm/3-2-Way-1-4-...item2c62c4adf5 |
#157
Another fun little project.
#158
Somebody needs to post something.........
Some signs we did using 1/2" AZEK. 96 9" letters nested into one sheet of material with room to spare. We pocketed the back boards .015", painted the two colors seperately, then used silicone to glue the letters into the pockets. ![]() ![]() Doesn't appear that samples of MM work generates much interest...maybe I should stop? |
#159
Darren, I think you'll find there is a lot of quiet interest. That's some nice work you're doing there. Are the letters stacked? They look deeper than 1/2".
#160
Hi Darren,
No, please keep on posting your works, it's always nice to see new stuff. Nice work through ![]() Last edited by Axel1966; Thu 20 December 2012 at 08:30.. |
#161
Letters are 1/2" deep.
Thanks, guys. I'm happy to post stuff, I just don't want to be seen as a person cluttering the forum with pics. I would think seeing pics of completed work could inspire visitors to undertake a build. |
#162
On the coffee table project, it is mahogany with .125" pocketed and epoxy filled areas for the logos and laces. For the NFL logo, I first routed the entire shield, filled with white epoxy, then came back the next day and routed the red and blue areas,filled them, and after it cured, used an end mill to surface the epoxy just proud of the mahogany, then random orbit sanded the entire table.
#163
Yep folks are looking
http://www.mechmate.com/forums/forumdisplay.php?f=78 Over 8400 views in this thread. Keep up the good work. I love to see what the MM can produce. |
#164
Darren,
following Brad comment, I’ll add : Have a look at your thread view count before posting…..and compare it with the numbers after a few days…..You’ll have a better picture and then will realize, regardless how many may see your enthusiast state, you first post these to share, not to compete how many may view it !? I’m one of those…silent observer that appreciate your time, as well form all others members, to post your observation, projects, progress, experience….and on ! Hey…. Enjoy a GREAT holiday seasons…..and YES please, as others, continue to contribute and share !! Amicalement, Robert ![]() |
#165
Your posts and pictures are a great inspiration for all of us "lurkers" please keep sharing!
#166
Darren,
I will say that I wish more pictures were posted. With limits on the pictures sizes and storage here you could always use a site like Flickr or Photobucket and have links to them. I find this is preferable rather than using up the allotment of space here. You do nice work. It is great that you share. Another nice feature of Flickr (and most likely Photobucket) is you can see how many times your photo has been viewed I you would like to know that. Last edited by pblackburn; Fri 21 December 2012 at 14:02.. |
#167
Actually, everything is hosted by Photobucket and linked to from here. Seeing cool projects others have done kept me motivated during some of the darker hours of the build.
#168
I know that dark feeling all too well. You definitely have a skill set above me with wood. My is mechanical and metal but I hope some day to become better with wood. I like the way you used epoxy and that is something I have never seen done where I live. Pretty cool seeing something like this from Missouri as my sister lives in Kansas City.
#169
Darren,
Keep the pics coming. It is always great to see what different people are doing with their Mechmates! You are doing some excellent top notch work! |
#170
Darren, Don't stop posting pictures, they are of great inspiration , because of your pictures I have just started my build, currently building 3:1 gearboxes and will order steel work ing the new year, have already purchased one stepper motor from OM a 296 to get me started, so please keep posting, a here's wishing you a happy Christmas, Andrew
#171
Hi Darren
The images you are posting provides lots of motivation for us all. Like yourself I have made a point of posting lots of photos of work as they tell such a big story fast. Love your work and also the techniques you are using to get lots of colors happening in your resin inlays. Cheers Ross |
#172
My attempt at one of Vectrics projects.
Could have turned out better, but the couple loved it. ![]() |
#173
Darren,
That looks great! I did not see that one in the monthly project download. Where did you find that one? |
#174
Hi,
Nice piece ! What kind of finishing is it ? How did you darken the engraving ? |
#175
Hi Axel,
It was a 1" thick Hard Maple blank. Finish was a lacquer stain with a lacquer topcoat. Picture was before sanding/rubbing the lacquer. Darkening the letters was as easy as not wiping the stain out of the letters, and letting them dry before topcoating. My wife is happy, because she now has the perfect gift for whoever gets married in the future, with no shopping necessary. |
#176
Hi Heath,
I found it on the Vectric Forum. http://www.vectric.com/forum/viewtopic.php?f=29&t=14960 Apparently is was for a users group meeting, initially. Fun project. |
#177
Thanx
#178
Darren, in regards to your questions on your post 156, I may not have links your after, BUT, have a look at one of my costumer site, he specialize in venturi generated vacuum lifting devices.
It should convince you....if not give ya some / many ideas !! Robert ![]() |
#179
Very neat site. Thank You, Robert!!
#180
Hi Darren
If you are still looking for the hand valves (hydraulic actuators) that Russell mentioned in post 156. Go to http://www.ebay.com.au/itm/1PCS-3-Wa...ht_2950wt_1168 We use them as actuators for the hold down on shaping machines, and this appears to be a very good price for an SMC type knock off. Regards Ross |
| University Of Missouri Saint Louis Theater | ganderson | Introduce yourself and start planning | 8 | Fri 31 October 2014 18:53 |
| Starting my MM Build - St Louis MO USA | inventek2000 | Construction started, but not cutting yet | 38 | Sun 25 September 2011 18:51 |
| my machine cnc | marcoscnc29 | Archives | 1 | Sat 24 April 2010 18:58 |
