Old Thu 16 February 2012, 03:30
Hey JR, was that your annual post to the forum? Great to hear you are still active!
Old Thu 16 February 2012, 06:57
This one is the 2nd post this year .... just to prove Gerald wrong .
Sean this statement really holds true .... "It takes more time for clean up than it did to cut sometimes. Static cling!"
I have been cutting for this customer 2 years now with no increase in price. I cut 1/8" and 1/2" thick material for $20 per sheet. The customer wants no increase and I want/need $25. Thanks Sean for the input. J.R.
Old Thu 16 February 2012, 07:43
Around here a simple sheet cutout starts at $35.00
Old Thu 16 February 2012, 14:59
Thanks Darren, that helps. I need to know I'm being fair and not greedy.
Old Sun 10 June 2012, 09:03
Originally Posted by Guillermo
Hi J.R.
I am in the process of building a computer dust-proof
case for running mach 3 in mi water-jet project. And
after reviewing your posts i am interested in
knowing if you preserves the original setup of the
control box cooling system or have made some
improvements.
Would appreciate a short description of the used
parts and any advice.
Thanks.
Guillermo.
Re: control box
Hello Guillermo. I am planning to build another machine. The current control box cools fine by pulling air into the box, this requires the box to be air tight. The new box will cool by pushing air (Gerald's suggestion) into the box so any small holes will just let a little air out, no big deal. The main exit will be an aluminum square tube large enough for all the Gecko drives to mount on the surface creating a perfect heat sink. One end of this tube will be open inside the box, the other will attach to the exterior of the box (maybe the bottom, to prevent dust from getting in when not in use). It will have an exit hole cut to match the inside of the tube. All air will exit through this tube therefore cooling the drives and the interior of the box (the air has to be filtered of course). I also plan to have one or two hinged panels for easy access to all components. I hope this helps ....... J.R.
Old Sun 10 June 2012, 11:29
J R
Is this customer you are cutting the sheets of PVC cutting for them selves or their client. I recently had a discussion with my client and they are planning a price increase to their client in Dec. I told them I could wait but I need to see an increase.
I don't believe a $5 increase is out of order. You are cutting 20 for a $1 a piece. Your gas, electric, bits etc have gone up. $0.25 per piece in not an unreasonable increase.
Old Mon 11 June 2012, 06:15
cbboatworks
Just call me: Gene
Wilmington NC
JR I was paying $31.50 a sheet so $25.00 sounds great
Old Mon 11 June 2012, 09:33
Re: control box
Hi J.R.
Some more qustions.
# 1 What fan cooler specs and quantity would you
recommend.
I used one computer power supply cooling fan and it works great, everything in the control box is always well within a safe tolerance.
# 2 Will you use again a pool filter for the air inlet
and have you evaluated the use of automotive
filter.
I did think about using the auto filter, but opted to use the pool filter and again it works very good. I don't have a dust problem. Little dust find it's way in via the cracks I mentioned, but the proof is evident by the dust trail around the holes.
Here is a link of what i have in mind.
http://cdn.wardjet.com/images/Calyps...omputer_sm.jpg
Well come your comments.
Guillermo.
Guillermo if I may make a suggestion .......... lets continue this discussion in my thread so others might benefit. Thanks J.R.
Old Mon 11 June 2012, 09:44
Nils, she does resale the items.
As a matter of fact ..... it's the customer you suggested I contact a few years back. Thanks again J.R.
Old Mon 11 June 2012, 16:50
Guillermo
Just call me: Guillermo
Puerto Ordaz
Venezuela
Hi J.R
Thanks for your comments and wecome any other suggestions.
Guillermo.
Old Wed 07 November 2012, 22:32
I am sad to report that J.R. Hatcher has passed away. He was a friend here as well as on facebook and I was shocked to see posts of his passing today on facebook. I do not have any other info as of yet and when I get more info I will post it here. RIP J.R.
Old Wed 07 November 2012, 23:29
That is indeed very sad news. His first wife passed away while he was building his MM in 2007. May the two of them rest in peace together.
Old Wed 07 November 2012, 23:44
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
I am very sorry to hear that. He will be missed on this forum.
I think he was a very good designer and his rail grinding and dust shoe ideas were used by many.
Old Thu 08 November 2012, 00:16
RIP J.R. you will be remembered with fondness around the world by those you helped and inspired.
Old Thu 08 November 2012, 01:11
southernduckie
Just call me: Andrew (Duckie)
new south wales
My feelings of J.R.
Inspired most people, motivated many and helped all who asked.
The community is poorer for his loss.
Thoughts to who he left behind.
R.I.P. J.R.
Old Thu 08 November 2012, 04:05
JR, a man who not only inspires me and many of us, but a man of a good hart that was surely be praised by its steps & passage among many others than us. A man whom we've had the good chance to have among us…too !
It was a privilege to exchange with you.
R.I.P JR….. we thank you for your great contribution.
Old Thu 08 November 2012, 05:16
R.i.p. Jr.
Old Thu 08 November 2012, 06:23
R. I. P. Jr.
Old Thu 08 November 2012, 06:49
This is a sad week.
I had a great, productive time working out the methods that we all enjoy in the MM machines we use today evolved from Classic to Mamba with JR personally. He was a great contributor to the MM community. May he and Rose rest in the peace they earned.
My heart goes out to his family during this time.
Peace my friend.
Old Thu 08 November 2012, 10:12
Indeed a sad day. He will be missed !!
Old Thu 08 November 2012, 10:18
fabrun
Just call me: fabrice
france
France
it is always a sad news to learn something like that
rip Jr
Old Thu 08 November 2012, 10:34
JR
Helped a lot of builders with their machine. I am sad to hear of his passing.
Old Thu 08 November 2012, 17:43
Castone
Just call me: Leo #41
Soddy Daisy , Tn
JR was a good guy talked to him several times always ready to help,
he will be missed.
Old Thu 08 November 2012, 18:20
JR was inspirational and encouraging. We were lucky to have him in our community, and we're lucky his contributions live on.
Old Thu 08 November 2012, 21:01
In case anyone wanted to see JR's obituary,
John Richard Hatcher
Old Fri 09 November 2012, 05:15
cbboatworks
Just call me: Gene
Wilmington NC
I was greatful to spent a littile time with JR a few weeks ago he was as happy and free as he could be, I started to break down and shed tears as we talked, with his great sense of humor he ask Gene whats wrong? everything is ok I am healed I am ok GOD is in control, He was not afraid one bit he knew His Lord and Savior he knew he would be home soon, it was a pleasure to know JR an his family he was a wondeful man, father and husban, who would give the shirt of his back , JR RIP brother may God Bless you and your Family
Gene
Old Fri 09 November 2012, 21:40
What a shock to hear this. RIP JR.
He was a true friend
Old Sat 10 November 2012, 06:07
Rip j r
Old Sun 11 November 2012, 09:40
Jason Marsha
Just call me: Jason
B'Town
Barbados
Rest in peace JR.
Old Wed 14 November 2012, 10:38
liaoh75
Just call me: David
Taibao
Taiwan
A true inspiration to us all at the very beginning of the Mechmate community! Reading his posts inspired me and made me believe I could really build this Beast. The world has truely lost one of its greatest.
May your family and friends find peace in their hearts in these difficult times. Rest in Peace JR.
JR's rail grinding skate in a Lasered & Bent format for 4.5" grinders Gerald D Rails & Rollers 198 Mon 13 April 2015 19:59
Add one more CNC addict - North Carolina rodom Introduce yourself and start planning 0 Tue 01 December 2009 05:54
She makes dusty MOVES! - North Carolina, USA Jeffn11 Construction started, but not cutting yet 23 Sat 01 August 2009 19:36
Plasma burner started - Albemarle, North Carolina subman Construction started, but not cutting yet 8 Sat 27 September 2008 18:25
One more MechMate starting - North Carolina, USA Bernhard Construction started, but not cutting yet 5 Fri 28 December 2007 15:11
