Old Wed 17 October 2012, 01:56
Finally, After 2 weeks of hair pulling troubleshooting chore.... while rewiring the control panel, I realized I had my motor pin assigned wrongly, DIR for STEP & vice verse...
All along this time, I knew the problem is gonna be so glaring & right on my face.... Also a simple one to solve... That is IF I can find what was wrong...
All are not lost, something good did came out of my personal blunder, I now know how to monitor parallel port signal, & sending test signal from Mach3 to the BOB... etc etc etc...
Old Wed 17 October 2012, 02:18
. . . . I swap around the Motor pin designation, disregard of what pin number I plug in, including mixing up STEP & DIR of all motors, the result is the same. . . .
It gets confusing, doesn't it!!
Old Wed 17 October 2012, 02:59
It get's to the point when you swap swapped wires and chaise your tail
Old Wed 17 October 2012, 03:02
aniljangra
Just call me: Anil #44
Delhi
Hmm, Like you swap wires and also swap signals in mach as well
Old Wed 17 October 2012, 03:18
Respect Murphy!
Thousand thanks to Anil & Danilo for walking me through all the testing.
Anil even sent me his new drivers.
Old Wed 17 October 2012, 04:53
LOL Ken, Anil was like calling me and was like hitting head on a invisible wall !
finally you figured it out!
Let us know how these work.
Irfan
Old Wed 17 October 2012, 05:14
Ken most problems are simple ... once solved
Before solving though they tend to be significantly more complex and wide ranging.
Well done and a gold star for persistence.
Old Wed 17 October 2012, 05:27
...and the persistence of the MM forum prevails again.
Glad to see your up and running Ken!
Old Wed 17 October 2012, 06:27
Surely eye candy is an absolute must
Anil's new & improved BOB & Drivers
The cover mount is much improve. & the jumper selector is more reliable than the earlier finger switch.
Another view
Fresly renovated Control panel looks like this now, Only the motor drivers are connected to BOB.
I got paranoid with heat, hence remove the drivers's casing & mount it directly on the external Heat Sink
This is how it look from outside.
My IR thermometer says the heat sink is 34C, the panel is 36C, the driver boards are around 40C, the transformer remains 50C.
I'm comfortable with these figures
Funny thing is the fans are 65C...
Old Wed 17 October 2012, 06:45
Ah Ken,
why remove the drive case - I run my tiny's @ 60V DC and at 5 A all the time with no ventilation and mounted on the steel (painted) surface directly ( with heat sink compound) ( I know its not the best way to do it!)- never bothered about them ever!
work horses every day!
Old Wed 17 October 2012, 07:16
Hi Irfan, The spec sheet did mention that it can work with 65C,
The official reason in doing so are, 1) so near the Equator with 32~40C ambient temperature, 2) paranoid... 3)... free up more real estate... 4) what ever...
The unofficial (real) reasons are, it looks too cool to resist & because I can...
Old Wed 17 October 2012, 09:03
Ken - from the pics looks like you removed the heatsinks - have you still used the insulated heat pads below the mosfets.?
the fets need to be isolated from eachother.
Old Wed 17 October 2012, 22:25
Yes, I bought some isolation pads for the job & applied heat compound.
Old Sat 03 November 2012, 22:40
FINALLY!!!!!
SPARKS!!! THUNDER!!!
WOOOO HOOOOOO!!!!!
Now I can sleep......
http://www.youtube.com/watch?v=u-s7J...ature=youtu.be
Old Sun 04 November 2012, 00:26
rischoof
Just call me: Rik #92
Goirle
congratulations Ken,
It's a huge machine, I can remember the pile of steel in the corner from your workshop. be careful with all those sparks.
Old Sun 04 November 2012, 01:20
Well done Ken - the video was great to watch.
Old Sun 04 November 2012, 02:26
good work ken
Old Sun 04 November 2012, 04:41
Nicely done, félicitation
Old Sun 04 November 2012, 05:20
Ken,
Nicely done - I know the Sparks and fire feeling!
Old Sun 04 November 2012, 13:26
Castone
Just call me: Leo #41
Soddy Daisy , Tn
Great job as always.
Old Sun 04 November 2012, 14:47
Ken , try cutting a little lower. it seems you have dross on the upper edge :P
Its ok when the sparks fly parallel to the plane of sheet
Old Sun 04 November 2012, 23:17
Thanks everyone. Its been a nerve wrecking journey, enjoyed it nevertheless.
Couldn't had completed the machine without Danilo#64 tireless guidance on Plasma operation, THC controller, Mach3 THC functions from & Antony#77 on the THC introduction & Anil on the BOB & Drivers trouble shooting.
Danilo, I suspected that too. Still learning the THC & the parameters...
I just inspected the nozzle & it is worn out only after less than 30 minutes of cutting... must be the result of all the wrong settings...
One thing I learnt about the recommended cutting parameters table which came with the operation manual... They are a big pile of crap!!!
The manual stated for 3mm MS plate, when using 60Amp, the feed should be 5060mm/min, cut height 3.8mm & piercing height 4.1mm but after some fiddling, the actual feed speed should be 2200~2400mm/min & cut height is about 2mm... TOTALLY OUT OF EXPECTATION!!!!
Old Mon 05 November 2012, 03:05
I take back this comment, the recommandation is fairly accurate. The error is due to bad cutting height setting... My bad...
Old Mon 05 November 2012, 10:07
Ken... in three weeks you'll be cutting like a pro (me) hehe
Old Mon 05 November 2012, 12:19
Congrats !!! Nice Machine !!!
What torch are you using?
I love post 112 .... "I'd like to thank my ...." just like the awards shows and racing here in the states.
Old Mon 05 November 2012, 22:39
Thank you thank you... I'll like to thank.... {applause} {Clap clap clap}
Jokes aside, I genuinely appreciate all the help
Mike, That is a Thermal Dynamics A80 Plasma power source with SL100 machine torch.
Old Wed 07 November 2012, 03:37
southernduckie
Just call me: Andrew (Duckie)
new south wales
Congratulations Ken
It looks as though your control cabinet is on the large size too don't be shy post up the size LOL looks like a great build, the way you felt sorting out your wiring is probably the same as I felt for most of my build
Hope it brings much happiness to your life.
Old Wed 07 November 2012, 04:01
I have to laugh at how the wheel turns......
When we built the first MechMate (maybe 8 years ago?) everyone tried to build the smallest control cabinet (and had the smallest cellphone). They shook their heads at our "big" control box (without air holes). Today there seems to be a competition for the biggest box (and the biggest cellphone)
Old Wed 07 November 2012, 05:19
LOL!!! BIG IS BEAUTIFUL!!!
My boxes are 400(W) x 500(H) x 200 deep. 40 liters each... one for the electronics & the other for the PC. Not as big as I wish... each panel cost about a ready-made PC box, the next size up is nearly double the price...
Tiny in comparison to Duckie‘s double panel 500x600x300 each...
Like I said in my 1st built, a penal this size is TINY in comparison to the actual MM’s actual foot print. What is the good in saving that 10~20 liter ?? & squeezing a PC mother-board in it??? My hand & fingers are just too big for such endeavor...
Gerald, I've seen people actually shouting into 10.4" iPad (as phone) against their favorite side cheek walking on the street.... I can tell they have problem holding it single handed....
Old Wed 07 November 2012, 07:03
Is that what that box is..
Though it was a towel drier for Ken's new swimming pool .
Plasma Cutter Ron Petersen 50. Toolheads 38 Wed 30 March 2011 14:10
Plasma in Florida Jimmystractor Introduce yourself and start planning 16 Sat 19 March 2011 00:54
Building a plasma table - Utah, USA MikeGyver Construction started, but not cutting yet 4 Fri 28 January 2011 06:01
Plasma Cutting....anyone doing this?? Mitch_1 50. Toolheads 1 Mon 09 November 2009 17:26
Converting Base Table For Plasma Cutting rkrecak 10. Base Table 3 Tue 18 December 2007 11:55
