Old Sun 24 June 2012, 16:38
Mr Ron
Just call me: Mr Ron
Vancleave, Ms
Using a chain for a rack
Using a chain is a common means of moving a trolley along a rail. The chain is tack welded to an overhead I-beam and a sprocket that is inside the trolley engages the chain. As the sprocket is turned, either by power or manually, it traverses the chain in rack fashion. My question is; can a chain be used in place of a rack for the rack and pinion drive? Racks are very expensive.
Old Sun 24 June 2012, 17:01
Quadro
Just call me: Anthony #77
South Australia
Mr Ron,
It has been done and wasn't very sucessful. See this build #62.
Old Mon 25 June 2012, 09:09
Zouave
Just call me: Eric #115
Sacramento, CA
In comparison to the rest of the build, I think the rack is one of the less expensive and more important parts.
It really isn't much off a savings to go with a chain, and your performance will suffer.
Cable Chain Not Laying Flat Zouave 60. Wiring & Cable Management 17 Sun 31 October 2021 17:13
Cable chain ("E-chain") - sizes and sources Gerald D 60. Wiring & Cable Management 73 Tue 02 October 2012 14:59
Updated to Rack and Pinion from Chain Drive #62 - Fort Wayne, IN USA scot MechMates already cutting 99 Sun 22 May 2011 13:11
Alternatives to expensive cable chain Kobus_Joubert 60. Wiring & Cable Management 7 Wed 16 July 2008 07:21
Cable chain - E-Chain sizes & sources Evan Curtis Archives 33 Sat 10 November 2007 12:27
