Old Thu 24 May 2012, 07:49
paul60
Just call me: woodguy
st george
Barbados
Smooth stepper
am courious what advantage i will get using a smooth stepper unit from warp9 tech design
I am using mach3
gecko g203
pmdx-122 breakout board. stepper motor 9412ktg-a6497 Oriental Motor
thanks Paul
Old Thu 24 May 2012, 10:04
We have 4 MechMates, some with smoothsteppers, some without. We can't tell the difference without opeing the cabinets to look inside.
Old Thu 24 May 2012, 12:27
paul60
st george
Barbados
ok thanks
Old Thu 24 May 2012, 17:17
The SmoothStepper is the equivalent of using two parallel ports. When used with two PMDX-122 boards or one PMDX-126 board, you will have additional I/O compared to using a single PMDX-122 board.
Many of the newer mother boards do not have a parallel port on-board. The SmoothStepper uses USB instead of Parallel Port connections, so you won't have to add a PCI Parallel Port.
The SmootStepper can handle faster speeds than the Parallel Port (according to the documentation). That may be an advantage if you use a gearbox or belt-drive that requires more than 45,000 pulses per second.
The SmoothStepper costs a lot more than two PCI parallel port cards, so, weigh the advantages of that single card against buying two $10 cards.
Old Fri 25 May 2012, 01:20
Mike, I hear that there is now a version of the Smoothstepper that runs off the Ethernet port . . .
See http://www.mechmate.com/forums/showt...6867#post56867
Old Fri 25 May 2012, 07:35
shaper
Just call me: Jed
Perth, WA
Gerald/Mike
The ESS is definitely out there, Ross is running one with success and I was, sadly mine sustained a failure (unexplained) within the internal power supply on the board and is subsequently being replaced, this aside it seams like a nice solution despite the cost, one of the attractions for me is that it allows the controller machine to be housed relatively remotely (by parrallel cable standards) as well as to control 2 BoB's with a minimum of cabling (can do three but for the moment 2 is enough for me). The documentation that is available for it is pretty basic and leaves, at least for me, a few questions unanswered (but it works).
Just a few thoughts
Old Fri 19 December 2014, 21:46
chopper
Just call me: chopper
Big Lake Minnesota
I know this thread is old but I wanted to add that I installed a new computer
in my control box this past week with a smooth stepper ethernet board.
I have tuned it as described in the instructions and my experience is it is a definite improvement, the machine runs quieter, smoother, and I am getting noticeably better cuts, I also upgraded to the latest version of mach 3,
it was definitely worth the time and expense to do the upgrade, and with the new pc it also is 15 to 20 degrees cooler in the control box as well
( I have the mother board power supply hard drive mounted inside my control box) I think the key is to spend the time to set the proper frequency on the axes and main com freq.
//chopper
Old Sun 21 December 2014, 06:22
Chopper I see you're still lurking in the underground I've been thinking of going to a ESS too but wanted to wait until something warranted the cost. Thanks for sharing.
Old Sun 21 December 2014, 08:59
Chopper what did it all cost you?
Old Sun 21 December 2014, 18:13
chopper
Big Lake Minnesota
Nils,
the smooth stepper was 180.00 and the new pc was 180.00
so about 400.00 I bought the parts for the pc from new egg mother board processor and power supply, I had a hard drive and the memory on hand as well as a copy of win 7, the rest was time and a little reading.
//chopper
Old Mon 29 December 2014, 16:42
I am torn between the ESS and the CSMIO/IP.
Old Mon 29 December 2014, 20:15
ger21
Just call me: Ger
Detroit, MI
I've not used either, but from what I've read, the CSMIO/IP-S is a far superior product. The price reflects it, though, at close to 4x the price of an ESS.
My next machine will be using the CSMIO/IP-S.
Old Mon 29 December 2014, 20:22
The CSMIO leads in my opinion because of the 24 DC standard. But the ESS is less money and would add onto my existing hardware. That is where I get torn apart at. Hard to sell used electronic equipment even in good condition. Which would be my only option to be able to purchase.
Old Mon 29 December 2014, 20:39
ger21
Just call me: Ger
Detroit, MI
In addition to the 24V, you also get homing to an index signal (with servos).
It's expandable to 192 Inputs/ 96 Outputs (more money)
No breakout boards needed.
Supposedly much better plugin support.
I read that Warp9 is adding a programmer, so hopefully they'll get better in that department.
Old Tue 30 December 2014, 17:25
Cheaper 4 Axis CSMIO IP-M 4 now supports motor slaving but only "basic"
probably without gantry squaring as they say
basic - in CSMIO/IP-M - fundamental slave axis function support without gantry geometry correction.
I just installed one CSMIO IPS 6, configured in seconds and performs flawless. Will see how it will keep up with Hypertherm HD4400 plasma cutter
