Thread Tools |
#91
Same as Alibre Solidworks joint Mecsoft for cam plugin .It is the same cam as Rhinocam
http://www.visualmillforsolidworks.com/ |
#92
Artcam all in one solution?
So check my thinking here please, Buy artcam this covers all my design needs then get Mach 3 to run the machine.. No other software needed at this point correct?
#93
Mojo,
I don't think that Artcam is a all-in-one solution for everybody. The software you need depends on your actual needs. May be you can explain first what your needs are? |
#94
Well the question wasn't really about wether artcam is the right software from a design aspect, but wether or not that's all I need in regards to taking a design from a program (artcam) to the machine (Mach 3) to final product. Do I need anything to translate from artcam to Mach 3? Do I need something else for say tool path (I believe artcam does tool path) thank
#95
Artcam can generate toolpath out of vectors or relief and with postprocessor which it has you can export it as gcode for Mach3.
#96
Thak you
#97
Mojo,
in that case, Artcam can generate the G-Code for you... |
#98
However, depending on what you're doing, you may be spending 10 times more than you need to by going with ArtCAM.
#99
Ger, just about everyone I know has been offered a free illegal copy of ArtCAM somewhere along the line and I suspect this is the reason that we have so many newbie questions about ArtCAM. Folk want to know if it is worthwhile investing the time for the learning curve assuming that they are not actually going to be spending any dollars.
#100
If you get a software package for free, you have to think about if you invest your time learning it, what are you going to do 5 years down stream when you want to upgrade and the package cost even more. I think it is important to buy your CAM software and that is what makes the Vectric products good. They are very capable and are reasonable priced.
#101
...I can just say, I like the feeling of owning my software and being able to call the manufacturer for support when I need it.
#102
Sean the only thing I hate about that is if there is a dongle involved you have to look after it like gold don`t lose it or get it stollen then you are as one can say f...
#103
Hennie, I have felt that pain!
Couldn't agree more. |
#104
I have downloaded rhinoceros 4 evaluation and I must say I think I might just get the licence.I have designed my go-kart suspention and modefied the body with it and it is only two weeks that I have been playing with it.Quite easy to work with.
#105
Hennie,
If you purchase Rhino4, then get the RhinoCAM & 4th axis module(if you need it) - you can pretty much tool anything you want. Works exceptionally well. |
#107
Hi all.
I have no background with CAD and i am trying to decide for a software. It is for my waterjet project. ( CAM software to use will be Sheetcam) Is there a suggestion for a friendly and tested 2D CAD software. Thanks |
#108
#109
http://www.turbocad.com/TurboCAD/Tur...6/Default.aspx
TurboCad for drafting. This version is almost identical to AutoCad Lite Affordable Well Tested Well supported Then for converting to 2d cut profiles...... http://www.vectric.com/WebSite/Vectr.../c2d_index.htm Affordable Well Tested Well supported Last edited by smreish; Sun 13 May 2012 at 11:32.. |
#110
+1 for Vectric products, It's brilliant ! Intuitive with a good preview abilities.
I tested Aspire (which contains Cut2D features, and more). Cut2D doesn't have a lot of features, but it's a nice and affordable software. Cut2D does well what's meant to do. |
#111
Hi Sean.
I read some days ago about 2D CUT, and understud it is a CAM software Does it have CAD capabilities. ?? Thanks |
#112
Hi Axel.
Just to read your comment. What about 2D CUT CAD capabilities. ?? |
#113
Hi Danilo.
I downloaded draftsight this morning. Thanks |
#114
Guillermo,
The links were for 2 solutions: Cad = TurboCAD CAM = Cut2D or any of the Vectric products |
#115
Ok Seam
Let me take a look. Thanks |
#116
Àxel and Sean
Downloded the 2D Cut trial version and you are right. It is a very friendly software and it alone have the drawing capabilities needed for the job. Thanks |
