Old Sat 11 October 2008, 13:07
G I was assuming that since I will be using a spindle control card, the E stop would pulse from mach and stop the spindle.
Thus I can use a lower amp'd contactor and save some cash,
however i will go the regular way and power the vfd from the contactor - just to be double sure.
RGDS
Irfan
Old Sat 11 October 2008, 13:12
Also then, a false pulse (error pulse) from Mach could also start the spindle by mistake . . . . .
You cannot trust Mach to have the final decision on whether the spindle runs or not. The spindle is probably the most dangerous part of your machine.
Old Sat 11 October 2008, 13:25
Yes Sir, I am surely going your way
Old Sat 07 August 2010, 09:32
tomasptacek
Just call me: Tom
Prague
Czech Republic
Mounting of G203V
Hi all, is it big problem to mout G203V on the same metal plate as the rest of components in control box (see picture) ? As i can see almost all of you mount them on separate alu plate. Thaks Tomas
Old Sat 07 August 2010, 09:50
Tom,
The reason for mounting separate is not a physical space issue, but a thermal issue. The separate plate allows for the drives to heatsink and cool. The additional plate allows for better area contact from surrounding air, thus cooling the devices.
The Gecko's run fairly cool, so you may be okay.
I reread g203v manual and it doesn't have specific heatsink requirements, but cooler is better.
BTW, nice transformer....did you make that yourself?
Old Sat 07 August 2010, 10:11
tomasptacek
Just call me: Tom
Prague
Czech Republic
Sean, thanks for reply. I made top of transformer today morning. I plug it in and measure 33,7 VDC on capacitors. I expected 35VDC and I am not sure if it is enough for my Oriental Motors.
Have a nice day
Tom
Old Sat 07 August 2010, 10:26
did you check your main supply voltage? it is perfectly acceptable to have a +/-10% fluctuation.
In real life, nothing is smack on... especially in engineering stuff...
Old Sun 08 August 2010, 09:34
33,7 ( you should be fine )
Old Wed 02 May 2012, 16:03
Guillermo
Just call me: Guillermo
Puerto Ordaz
Venezuela
Hi all.
I am planing the join of this alu pieces for building the drivers heat sink.
They are 2 mm thick
Any coments ???
Old Wed 02 May 2012, 22:29
Not sure how that will make a proper heatsink.
Old Thu 03 May 2012, 03:22
Axel1966
Just call me: Axel
Paris
France
I agree. Through, real heat dissipators are realy cheap.
Old Thu 03 May 2012, 11:26
Guillermo
Puerto Ordaz
Venezuela
Ok, in next days il make a test and feed back
Old Thu 03 May 2012, 14:56
Axel1966
Just call me: Axel
Paris
France
If you don't weld them, you must fix them tight and use some heat conductor fluid,
like those used in computer CPU/fan mount.
But I still believe the "wings" are not thin and long enough to produce the expected result.
Old Fri 04 May 2012, 00:22
Modern drives have very little wasted heat. The stories about big heatsinks for drives come from 10 years ago.
Old Fri 04 May 2012, 23:08
Guillermo
Puerto Ordaz
Venezuela
Hi all.
After reading and reading, I have not found information about
the drivers fan specs and its wiring diagram.
Can someone help me with this and a suggested fan model.
Old Sat 05 May 2012, 03:03
See:
first posts on MechMate DIY Control box full spec screened spindle 3phase
and
Cooling fans
For a cooling system that works. It has no fins on the heatsink. The drives are cool all the time.
Old Sat 05 May 2012, 07:33
Guillermo
Puerto Ordaz
Venezuela
Ok, now i am clear about heat sink and fan
Thanks Heath, Axel and Gerald.
Hope see all you in next questions.
Old Sun 07 April 2013, 06:17
Hardouin
Just call me: Hardouin
Douarnenez
France
VFD mount
Hello !
I am planning to build my control box.
I would like to know if I can put the VFD inside or is it better to put it in a separate box ?
Also, I am looking for a VFD and can you tell me what "HP" means in VFD specifications.
Thank you !
Hardouin
Old Sun 07 April 2013, 08:18
I think it is better to put the VFD outside the controller box. Keep the line noise that the VFD and Spindle wire is generating away from the controller box.
Old Sun 07 April 2013, 18:50
Outside if you can. It just takes one more noisy thing away from the others.
Control box cases/enclosures (only the outer, empty box part) vadeem 70. Control Systems 32 Mon 27 September 2010 15:58
New MechMate painted, with experimental control box - Atibaia, Brazil zetacnc MechMates already cutting 48 Tue 13 July 2010 01:37
Low Cost DIY Spindle Motor Rad Racer 50. Toolheads 9 Sun 05 July 2009 09:56
CandCNC.com control box components and full box solution Gerald D 70. Control Systems 7 Wed 22 August 2007 13:47
Bob CampBell's control box components and full box solution Gerald_D 70. Control Systems 7 Sat 18 August 2007 19:38
