Old Tue 03 April 2012, 20:34
parrulho
Just call me: Paulo #108
willemstad
Netherlands Antilles
First Cuts #108 - Willemstad,Netherlands
Oi galera!
I'm reading this forum for around 2 years, dreaming and been happy as other builders get running machines... During that time I have build an workshop where the mechmate will be the king of that space, getting tools that will be essencials and have collected almost all parts (from Metalhead, thanks). Now it's my time...
Here I'm, bald and no beard
I'm a portuguese living in Curacao, Netherland Antilles. Have worked, long time ago, from 1986 to 1996, in Portugal, with a CNC in textil industry, cutting tissue. It was from a French company, Lectra Systems... Now, thanks to Gerald I will have one for me
Thanks Gerald, Metalhead and all community.
No more cutting tissues, it will cut principally wood, official it will cut art to display on wife's art business and cut some boat parts for myself in the middle
Only need to finish that canoe to get space... My main concern is weld (I'm practicing) and no problems in electronics, I hope...
Old Tue 03 April 2012, 22:46
Welcome Paulo! Looks like you are off to a good start.
Old Wed 04 April 2012, 02:30
Axel1966
Just call me: Axel
Paris
France
Yes indeed !
Congratulations for your new workshop, it looks great !
Old Wed 04 April 2012, 11:14
bolingerbe
Just call me: Bryan #54
Clinton(Tennessee)
Welcome Paulo. The welding is not bad, and you will have a lot of good advice along the way. Good to see your progress and look forward to seeing you build.
Old Sat 07 April 2012, 11:07
Metalsmith
Just call me: Metalsmith
Jacksonville, Fl
A man after my heart....
a wood strip boat builder....is that cedar...people are so amazed at how lite they can be.....have built one in 42 years, but getting the itch !
Why so much steel ....that will be a big machine....taht is hefty stuff !
I am a welder..... I may be wrong but I don't feel that they need to be welded solid ....they don't when building skyscrapers.... I will use a 3/4" on the corners and 1", every 3 or 4 inches.....If you dont want the side beams to warp , don't weld across the top or bottom...wrap around the corners and skip-weld down the sides...pick up a structural welding book !
Old Sun 08 April 2012, 19:51
parrulho
willemstad
Thank you Metalsmith for your advices. Machine size will be for 4' x 8' boards. I'll follow the plans except for legs (will use square tube 70x70x3 and instead of round tube will use square tube 50x20x3)... I don't want to invent anything and legs do not interfere with functions of other parts. In the pile of steel you can see some that I'm using for small security fences. it's just to fell the welding on my hands before the real thing.
I like cedar strip boats and I have plans to build, but this one is marine plywood... build cheap to sell cheap.
Old Mon 10 December 2012, 00:30
parrulho
willemstad
Official start of my machine
hello people, greetings from Curacao.
Ok. My canoe is stored for now and got room for Mechmate... finally. On 27Nov2012 I started to cut X and Y rails. have started with confidence. no problems to cut it down to 2.8cm... then, I'm able to advice: do not start to cut the 45 angles before you are sure and confirm that the rails are top flat. I started to cut angles right away and the result was 26mm height on Y rails and 28 on X rails... thanks God I did not loose nothing... but a little frustrated.
Also use a scrap piece of wood as a base and avoid to use the 4 bolts as a base to get the rail flat. it's ok to cut but not enough to get it really flat.. it's a good help.
When on 45 angles use good very hard steel on bolts used to control height. It needs one complete turn to get the measurements. put mark on the bolt where you start. use the hexagone form as a reference. use grit 36 to on first two passes then grit 60 on 3rd and 4th and finish with grit 80 on 5th and last 6th. It served me well. Hope it will help new people.
Regards and never tired to say thanks to Gerald.
paulo
Old Fri 04 January 2013, 22:32
parrulho
willemstad
base table welded
Not nice welds but they are strong. I'm happy with it
Old Mon 28 January 2013, 10:23
parrulho
willemstad
gantry is done
After battling to get the cross members square and both the same size (lack of right tools) gantry is done, squared and true. Next Y car...
Old Mon 28 January 2013, 10:32
Axel1966
Just call me: Axel
Paris
France
Hi,
Nice work !
Are the casters permanent ?
Old Mon 28 January 2013, 10:40
parrulho
willemstad
It's temporary, when it's full painted and inside the shop it will be removed and normal feet will be mounted.
Old Tue 29 January 2013, 04:14
Very good work, I see your design allows for material storage. Nice!
Tom
Old Wed 30 January 2013, 19:21
parrulho
willemstad
having hard time setting y car before weld.. fixing one side get the other off...
Old Thu 31 January 2013, 07:27
...that looks familiar.
Old Thu 07 February 2013, 22:38
parrulho
willemstad
gantry and Y car complete and painted
I was worrying too much with Y car. Have removed all the clamps and started welding-control-adjust, weld next and repeat until it completes...at the end it was OK. Next: drill and mount rails and start rolling.....
Old Mon 25 February 2013, 08:37
parrulho
willemstad
Hello happy people,
I'm looking for a reason why the proximity switch does not match the 20mm hole on rails. they are offset... Have searched the forum for it but it's taking me long time (what is not normal, let say...) any help is welcome.
regards,
Paulo
Old Mon 25 February 2013, 09:37
Paulo,
The 20mm hole in the rail is the TARGET for the proximity switches. The switches are optional. The offset insert for the 20mm hole is for the ability to adjust the TARGET hole in the rail after installation.
The proximity sensor is reverse logic. It is always active and sense the metal below it to detect a derail or other "jump the track" scenario. The hole is so the sensor does NOT see the rail and thus, act like a limit switch.
The proximity sensors are dual function.
Drawing # 10 20 246/247 show the drill details of the hole.
The thread that covers this is:
http://www.mechmate.com/forums/showthread.php?t=584
Old Mon 25 February 2013, 10:47
parrulho
willemstad
Thank you Sean,
When I said "the proximity switch do not match the 20mm hole" was mean: the center of the proximity switch, when mounted on the stop block, do not match the center of the 20mm hole. they do not share the same center, there are a offset of around 8 or 10mm (I can't verify it right now). Is it done to be able to fine adjust the target? Sorry I can't explain it better in english
Old Mon 25 February 2013, 11:20
cleyte
Just call me: Clayton #106
Bishop's Falls, Newfoundland
In my case, a few washers behind the stop block was enough to produce alignment.
Old Mon 25 February 2013, 13:13
Oh, my misunderstanding.
Just add a few washers between the proximity block and side of gantry steel to "push" the sensor towards center line of the table until centered. Be careful not add to many to cause the hard stop bracket to miss the end stop adjustable stop blocks.
Old Mon 25 February 2013, 13:18
I don't think the prox switch is your biggest problem . . . . . . your pinion gears probably won't reach the racks either . . . . .
Old Mon 25 February 2013, 14:30
parrulho
willemstad
At the moment I'm far away from my table to check but my table is very accurate on measures. In my head the center of the proximity switch offset from target is the way it was planed, with a purpose... if the centers must be coincident, I need to further investigate where my error is. By the way the 20mm target hole is not drilled yet, I stopped when have reached that point... Thank you all.
Old Mon 25 February 2013, 19:31
parrulho
willemstad
Man, what a shame I would be very tired two days ago... the offset was not 8 or 10 but 5mm. I have marked and punched the center hole target by the plan and then rolled the gantry against the stop block and with a pen marker trough the proxy hole I marked the supposed center... the pen marker was tilted and gave me a bigger difference... after some adjust the real offset is 3mm. "storm in a tea coup" will never happen again.
I'll move 1mm the center hole target and use washers, as advised...
Old Wed 27 February 2013, 14:20
parrulho
willemstad
I can't buy from McMaster, they do not sell outside USA. It turns very difficult to get some parts (in a small island as Curacao). Today I get a beautiful Z plate: 1/4x10x18 not sure if it is hardened or not. The ends are yellow painted... is it a code?
Still needed are racks/pinions and tape to get all parts with me.
Old Thu 28 February 2013, 07:36
Yes it is a paint code!
See the link here for reference.
http://www.southerntoolsteel.com/color-codes.html
Old Mon 18 March 2013, 20:27
parrulho
willemstad
it rolls very smooth... man, I'm falling in love with that machine!!!
Old Tue 19 March 2013, 06:15
Paulo….not to worry being transparent over your emotions…..
Many here will raise a hand as follower / part of some who deliberately say this : I’m in love with this machine…..but I’m married to my wife ^_^ !!
Although, in my specific case…..i ‘m no longer with her…..but still with my BB
Old Mon 08 April 2013, 13:57
parrulho
willemstad
http://www.lightobject.com/22KW-2400...20V-P714.aspx#
Anyone knows that spindle? is it the same chinese spindle at sale on ebay with a different cover? no plastics on that one...
Old Wed 10 April 2013, 18:20
its the same one, no plastic on any of the water cooled spindles
Old Wed 10 April 2013, 23:12
parrulho
willemstad
Thanks Danilo. I was thinking allbblack partes was plastic..
It Aint Finished Yet -The Netherlands Hans Construction started, but not cutting yet 31 Thu 27 April 2017 21:34
Planning a new build in Edam - The Netherlands Polder48 Introduce yourself and start planning 9 Sun 02 August 2009 06:56
My first cuts bbreaker The Show Room 2 Mon 23 June 2008 00:06
TimCooijmans his CNC - Netherlands timcooijmans Construction started, but not cutting yet 8 Thu 05 June 2008 07:19
