Old Tue 03 April 2012, 09:14
explo10
Just call me: explo10 #97
hennuyères
Belgium
This is the Z is in, after having edited 2 times in place despite the bearings bolts eccentrics .. I expected the air cylinder to continue, soon establishing engines
Old Tue 03 April 2012, 16:22
Axel1966
Just call me: Axel
Paris
France
Great !
Old Mon 09 April 2012, 12:05
explo10
hennuyères
Belgium
A few hours this weekend, some modifications to fit the bearings but everything is assembled and looks perfect. strongly that it works!
Old Sat 14 April 2012, 19:18
Axel1966
Just call me: Axel
Paris
France
Nice work !
Old Sun 15 April 2012, 01:24
wow those are BIG motors.
Old Sun 15 April 2012, 04:40
Axel1966
Just call me: Axel
Paris
France
Yep, I noticed them.
There's a link on page 1, 7.5A ; 1232 oz.in Nema34 ; 5kg
If I'm not wrong...
Old Sun 15 April 2012, 07:01
the bigger the lazier. Lets see them move the machine 20m/min.
http://www.mechmate.com/forums/showthread.php?t=255
Old Sun 15 April 2012, 08:08
Some guys are using those big motors and they get acceptable cutting results.
Old Sun 15 April 2012, 23:07
Those motors are HUGE!
Old Sun 06 May 2012, 13:12
explo10
hennuyères
Belgium
Hello,
Not much progress at the moment, the cables are ordered and the chains too .. meanwhile I studied a little mach3 bought in French. To get my DXF, I will use in gcodes CAMBAM. So I have something to do after work!
explo
Old Sun 06 May 2012, 15:42
bolingerbe
Just call me: Bryan #54
Clinton(Tennessee)
Your machine is looking good. Good luck on the software. I would keep my operation simple at first. As you start learning the machine you can go more advance in Mach or maybe add attachments “Indexer etc”. Look forward to seeing you up and running.
Old Sat 12 May 2012, 11:31
explo10
hennuyères
Belgium
Some progress, but I lack a meter of chain and 10 meters of cable ... I order for the week is coming ...
Old Thu 17 May 2012, 02:13
explo10
hennuyères
Belgium
mechanically complete, go to connections ...
Old Thu 17 May 2012, 05:48
explo10
hennuyères
Belgium
Old Thu 17 May 2012, 08:24
WOW!!! Dedicated driver/motor power supply!
SMPS as well!!!
You must be rich!
Old Thu 17 May 2012, 09:51
As you can read in some threads, each driver having its own power supply is not really recommended. Using multiple PSU the currents generated back from one motor and don't get to the psu because they are consumed by rest of the drives, or something like that .
If it works for you it's fine, if you run into problems, search the forum there are couple of threads about it.
Old Thu 17 May 2012, 13:44
explo10
hennuyères
Belgium
it's part of the engine kit I bought in China, + - $ 600 complete kit. I hope I will have no problem! But it is true that if there is a return engine, the driver can cash this bug ...
Old Sat 19 May 2012, 12:08
explo10
hennuyères
Belgium
First signs of life!
http://www.youtube.com/watch?v=KEcVHp8ffic
Old Sat 19 May 2012, 12:28
Well done!
Old Sat 19 May 2012, 15:01
Excellent Work!
Old Sat 19 May 2012, 17:31
Those motors seem to do just fine direct drive, mount up a router and cut start cutting
Old Sat 19 May 2012, 18:13
bolingerbe
Clinton(Tennessee)
Get some lables on it, mount a router/spindle and lets see some dust. Ur number is close.
Old Sun 20 May 2012, 06:06
explo10
hennuyères
Belgium
I have a doubt about my settings, what would you put these engines to 3.5 A set up like this on the driver? Module 1, 20 teeth in live ... to have a normal speed without excess?
As everyone in different settings, from reading too much information I now have doubts
impulsion dir 1 ? impulsion pas 1?
Like that?
Old Sun 20 May 2012, 08:49
The 3.5a settings that you see elsewhere in the forum are usually for smaller motors than are in your kit. You should use the settings that Longs recommends for that power supply / driver / motor combination. Based on how large those motors appear to be, I would expect something in the 7 to 8 amp range.
If you experience too much heating of the motors, you can reduce the amperage. Or, you could raise the amperage step by step until you are happy with the performance.
Last edited by bradm; Sun 20 May 2012 at 08:51.. Reason: Weird double posting glitch from a single click
Old Sun 20 May 2012, 09:28
My suggestions for settings:
SW1: OFF
2: OFF
3: ON
4: ON
5:OFF
6:ON
7:ON
8:OFF
Always check if motors getting too hot.
Old Sun 20 May 2012, 11:13
3.5Amp is what is specified for that motor, its a high inductance low current.
you should be pretty safe with the next setting 4.2peak 3.0rms and could possibly use 4.9peak 3.5rms
sw4 is for idle current, I use it in off= half , and have no problems
Gecko recommends leaving Impulsion pas and dir to 0, its the timing for step and dir signals, as the drives can read inputs fast you can leave 0
Old Sun 20 May 2012, 11:42
explo10
hennuyères
Belgium
ok I'll try that tomorrow, thank you
Old Sun 20 May 2012, 12:03
If SW4 is for idle current, then I agree to set it OFF.
Old Sat 02 June 2012, 14:33
explo10
hennuyères
Belgium
Thumbs up
It's gone! It works!
http://www.youtube.com/watch?v=eRmTH...hannel&list=UL
Old Sat 02 June 2012, 14:38
it's great! but did you intentionally put the Z axis facing the rear as it may have impact on working dimensions, the table is offset to one side.
New here - Hofstade Belgium BIBIP Introduce yourself and start planning 5 Sat 16 April 2016 14:38
And another MM will be built in Belgium bramvh Introduce yourself and start planning 9 Fri 15 April 2016 15:01
Mechmate Plasma Cutter - Lipik, Croatia Brain Construction started, but not cutting yet 101 Tue 09 October 2012 10:15
Plasma Cutter Ron Petersen 50. Toolheads 38 Wed 30 March 2011 14:10
True cost of a plasma cutter jeep534 50. Toolheads 3 Fri 13 June 2008 00:44
