Old Tue 28 February 2012, 09:00
Ross, don't you just love the freedom to put pipes through the table of a self-built table? Guys with Multicams, Thermwoods, etc must feel so restricted!
Old Tue 28 February 2012, 17:40
Sean - Thanks for the generous comments.
Gerald - You bet - the ability to pass the pipes through the support board was a big plus in terms of the mounting options.
Initially I wasn't keen to drill the through holes but as the design process went on, it became increasingly obvious that was the best way to go.
Old Tue 28 February 2012, 19:21
TechGladiator
Just call me: Miguel #94
Randolph, NJ
Ross;
You didn't void the warranty with those holes? .
That is some nice work!.. You have given me an idea as to how to hod down a mold that I am about to make..
Every time I look at your thread I just shake my head as to what you are going to come up with next ..
Miguel
Old Wed 29 February 2012, 18:36
That is a sweet design !!
Old Sat 03 March 2012, 05:24
Breaking Things
Broken Stepper
I used Locktite 609 to ensure my pinions did not slip on the motor shafts.
Even my friend the hammer was no match for how well the shaft and pinion were bound together.
The only way they were going to part was to use a good dose of the map gas flame and by that time I already had a stepper that was seized.
Lesson learned.
Clogged carbide burr.
My shaping exploits continued today, I got one side of a board done then suddenly the carbide burr filled with glue as it cut the wooden stringer.
My substandard test surfboard blanks were also glued up with substandard glue. Upon a retrospective inspection of the glue line it never was going to turn out well.
Another lesson learned.
Solutions
Broken stepper - Avoid using with my friend the hammer and buy two new ones as replacements.
Clogged burr - soak overnight in Acetone.
So my machine lays idle until the replacement stepper arrives.
I had previously ordered a "replacement" stepper from a supplier but they sent whatever they had rather than what they should !!
Old Sat 03 March 2012, 07:39
bozona1
Just call me: don
New Brunswick
Sorry to hear that Ross. Once you have a machine it is very hard to imagine having it down. Hope you get your stepper and have it going again soon. I have a question about securing pinions. Why not use 3mm or 1/8" spring pins. That's what I do and never have a problem with slipping. Of course don't hammer it in but gently squeeze in with vise grips or large pliers. Works well for me.
Don
Old Sat 03 March 2012, 10:43
You are of course going to open the stepper and change the bearing?! Nothing to loose....you might be surprised and gain a working stepper again.
Old Sat 03 March 2012, 13:51
WTI
Just call me: James
Detroit (Michigan)
Mariss from Geckodrive says you can dissasemble square steppers, but not round ones - because you lose 60% of the torque by disturbing the magnetic field.
Old Sun 04 March 2012, 01:50
Is Mariss at last agreeing that the newer steppers can be opened?
Hey, you might even find that your round stepper has rare earth magnets. Give it a shot. Ther's nothing to loose.
Old Sun 04 March 2012, 01:59
You just should not remove the rotor from the case they say, it might be safe to remove the front plate and change the bearing.
Try it! we want pictures from the inside
just found this... blast from the past
http://www.talkshopbot.com/forum/sho...6&postcount=38
Old Sun 04 March 2012, 03:50
Hi Guys
Sorry for the late reply, been away - surfing of course.
Keeping in mind I was the bloke with the hammer in the first place, as you all rightly point out I have nothing to loose.
Danilo thanks for the link to the pics.
We shall see what transpires
Old Mon 05 March 2012, 01:04
Motionking 34HS9801 Disassembled
Hi All
Pulled the motor apart and the bearings were good.
I feel the issue is with the position of the top bearing on the central shaft and might play some more to see if I can fix it.
After the stepper failed to easily fix up, returned to my spare and made it fit, so now my machine is up and working again.
Cleaned the machine up a bit too as the C car pinion and the Z slide were all packed with compressed foam.
The C car pinion required a carbide point to pick out all the rock hard foam.
A brass brush would not look at it even after a soaking in solvent.
Anyway the pics you were asking for provide a nice insight into the internals of a stepper motor, and it was very easy to disassemble as well.
All the magnets, bearing seats and the windings are clearly visible for others to examine.
Old Mon 05 March 2012, 01:21
Ross, looked back over a couple of your machine photos and noticed that you left the end of the motors open . . . . dust could have gotten to those "shielded" bearings. I would buy a pair of "sealed" bearings (rubber seals) and fit them to the rotor before going any further. I have a good feeling this motor is going to run fine again.
Old Mon 05 March 2012, 01:58
Found it - Thanks Gerald
Pulled it apart again as it only takes about 2 minutes.
Re-seated the bearings but it remained still bound.
I put the top bearing cup assay over the bearings, spun them and immediately found the problem.
The top bearing turns smoothly but has lots of wobble in it and that was causing the magnets of the armature and stator to bind due to the strong magnetic pull.
Your words and the advise of others was ringing in my ears as I was vacuuming foam out of the bottom of the C car motor the other day.
I put some masking tape over the hole mid cut after that but pulled it off later.
I will put a more permanent fix in place.
Old Mon 05 March 2012, 16:46
Also found the magnets had moved up the shaft from the impact
There were some locating marks scribed into the center shaft that gave the movement away.
Old Mon 05 March 2012, 21:12
My high hopes for the survival of that motor are starting to fade
but we are learning stuff
Old Mon 05 March 2012, 21:14
TechGladiator
Randolph, NJ
@Gerald: Well, I always wondered what the inside of one looked like.. and now thanks to Ross I know..
Old Mon 05 March 2012, 22:53
She's Dead Jim
No surprise really but in the end I nearly got it to turn smoothly but it would catch every so often.
Pulled it completely apart once their was nothing to loose so here are two pics for you all.
The Shaft
14mm ends with 17 mm centers for the bearings.
Note the ridge down the middle of the shaft - that is how i picked up the magnets had moved.
The Other Bits
The "magnets" are made up of packs of washers, shims and the magnets themselves.
Note the pattern in the of the magnet pairs on the right, they alternate.
We all learned something I suppose but I also learned the price of a new replacement stepper.
Old Mon 05 March 2012, 23:51
Very interesting Ross! I wonder how the magnets are supposed to transmit their torque to the shaft. There is no obvious keyway or spline .....were they very tight?
The shaft apparently has to be non-magnetic and so stainless steel is used. This is soft and easily damaged. It has a nasty habit of welding itself to steel under high friction. That groove might have been intentional - could it be the locking method? If there was welding when you pushed the the parts off the shaft, then that line would have gone all the way to the end. I suspect that the line is made before assembly. Are there more lines around the shaft?
Sorry for the curiosity at your expense
Old Tue 06 March 2012, 00:35
Hi Gerald
Happy to share.
All the fits were very loose, a light tap on with the hammer while I held it in my hand was enough to remove the magnets.
The bearings also came off fairly easily too, but not as loose as the magnets.
Stainless steel shaft is consistent as it was very shiny steel.
The shaft had 4 grooves in it, however the centers of all the magnets are perfectly round.
I was thinking the grooves might be there to locate (but not lock in) the magnet pack somehow as I saw the line once the magnet pack had slipped upwards.
I think my final problem may have been related to the alignment of all the packs.
Initially I was able to twist the upper and lower packs relative to each other and then they locked up again (maybe not in the right place).
Old Tue 06 March 2012, 19:06
WTI
Just call me: James
Detroit (Michigan)
I'm completely missing how the magnets are locked to the shaft.
Were they bound with Loc-Tite at some point?
Old Tue 06 March 2012, 19:14
Hi James
Friction fit as their is no evidence of any retaining fluids.
Old Tue 06 March 2012, 19:33
bozona1
Just call me: don
New Brunswick
Thanks Ross
Very nicely documented dissection.
I worked in motors in another life and that is the typical method of assembly for any rotor. The splines are the only thing holding everything together. It's one thing to slide the disks and magnets off the end but a totally different thing if you were to try rotating everything on the shaft when newly pressed. The magnetic field actually stops everything from sliding on the shaft.
Don
Old Tue 20 March 2012, 05:25
Improvements to Vacuum Sealing
My vacuum cups worked well enough to fully hold down a shaped surfboard on its cut side but I have chased some further incremental improvements.
Quite lazily I had been not regulating the pressure through the vacuum venturi.
I introduced a second regulator on the inlet side of the venturi and dropped the delivery pressure to the rated pressure of 80 PSI.
After a few tests on compressor cycle times, the lower pressure wasted much less air.
Been on the hunt for some self adhesive closed cell foam sheets for a while now and found it right under my nose at a local store.
The 3mm EVA foam is great for vacuum puck seals but I realised that it could further reduce leakage between my vacuum cups and the shaped surfboard foam.
The Seals and Foam
Sharpened Pipe Cutting Dyes
Cup Seals in Place (not stuck down)
The compressor has now gone from busy to cruising.
I have also valved up the two sets of cups for separate control at each end of the table.
Alignment of the surfboard blank should be much easier now.
Last night I got to talk with CNC royality, a trail blazer in the CNC surfboard shaping world who has commissioned 60 plus shaping machines.
Lovely guy and immediately commented on the good practical design of Gerald's Mechmate.
He enjoys minimalist design and in his words "less things to go wrong".
You have to admit that's pretty good advice and parallels the Mechmate design philosophy nicely.
Regrds
Old Tue 20 March 2012, 10:58
...Less is more - most of the time.
Old Sun 25 March 2012, 01:17
SS-02 Ethernet SmoothStepper Question
I have just tried to swap in a P4 3GHz Del as a machine controller and it is not going to work with my collection of PCI parallel port cards (no onboard port).
Horrid pulsing in the drivertest.exe, so thinking about a move over to another port when I saw an Ethernet SS is out.
Has anyone used one yet or heard anything I might like to know.
Send a PM if your not willing to shout out loud your experiences.
http://www.warp9td.com/
Old Mon 26 March 2012, 06:24
No news is good news.
Have ordered the Ethernet Smoothstepper as reviews elsewhere seem to indicate any loss of communications issues have vanished in the Ethernet SS.
Crash test dummy.. hope not
Old Mon 26 March 2012, 07:57
Travish
Just call me: Travis #75
Wa
Go for it Ross!
I have the USB SS and am happy with it even though it is sensitive. The ESS is the way to go. You'll do fine with the swap. I have been running the SS for over a year and works really well. I will eventually move up to the ESS as well.
Good luck on your swap. Greg is good help over there at Warp.
Cheers.
Old Mon 26 March 2012, 08:07
Thanks Travis that sounds like a tick for the new Smoothstepper then.
May I ask as to how it improved or changed the way your CNC machine runs.
Principally I am after easy controller swap outs and maybe use laptops into the future.
Despite this I remain curious about some of the other aspects of using a motion controller.
Old Mon 26 March 2012, 08:08
I know folks here are using the Smooth Stepper. Did you order the cables needed to attach it to your BOB?
Missed the Ethernet part of the statement !!
I am interested to see how this works. Time to do some reading .....
