Old Sun 25 December 2011, 23:55
Check your table OFFSET. It needs to be a bit longer on one side to compensate for the rouer / spindle to reach each edge.
Old Thu 05 January 2012, 05:47
marko cro
Just call me: Marko #107
Dakovo
Croatia
Hello again,
I was wondering what thickness of the cable should I use for drivers? I have a several options, but dont want to overkill it.
What should be the profile of the cables.
About offset, did you mean the offset of the spindle? Here is the pic which could help.
I think I should move it more towards the end.
Old Thu 05 January 2012, 08:14
baseball43v3r
Just call me: John #96
Glendora (California)
Marko, notice how the router does not sit in the center of the y-car. The table offset means that one end of the table needs more clearance than the other (ie the beams need to be longer) to be able to reach the end of your cutting area.
As to your answer on cable thickness I believe this thread holds the answers. http://mechmate.com/forums/showthread.php?t=2
but its usually around 18 AWG. (i think)
Old Thu 05 January 2012, 08:26
aniljangra
Just call me: Anil #44
Delhi
I made that mistake and later had to weld small pieces of beams to the ends thankfully I did not cut the rails to exact length of beams before I noticed the mistake.
Old Thu 05 January 2012, 13:45
You can use 4 core shielded, 1.0mm2 - 0.75mm2 per core for motors.
For the spindle 1.5-2.0mm2 should be sufficient
Old Tue 21 February 2012, 05:49
marko cro
Dakovo
Croatia
Finally all the parts are here.
Just waiting to my shoulder to get better and welding will begin.
Old Tue 06 March 2012, 15:42
Axel1966
Just call me: Axel
Paris
France
Very Nice 3D views ! I wish mine looks as good as yours.
Pre-mounting in 3D helps me a lot in the understanding of the MM pinciples.
I wish you the best for your build !
Old Wed 07 March 2012, 03:05
marko cro
Dakovo
Croatia
Thank you,
And it really does help a lot when you have something build in 3d, its much easier to understand where and how things go and connect.
With SW, i can determine the weight, very accurate measures so it can fit perfectly to the workshop.
Old Sun 18 March 2012, 12:02
marko cro
Dakovo
Croatia
Drilling has started, and some new parts arrived.
design
Cant beat the real look.
Old Sun 18 March 2012, 14:54
Axel1966
Just call me: Axel
Paris
France
Is there any benefit to use anti-vibrations feets instead of 100% metal ones ?
Old Sun 18 March 2012, 15:29
marko cro
Dakovo
Croatia
Dont know, but there is an option to add rubber bottom on these feets. If the vibrations turns out to be a problem.
Old Sun 18 March 2012, 21:31
Most people use them because they look sexy. Firm contact to the floor would be better in terms of cut quality. However, they reduce vibrations transmitted to the floor and reduce noise.
Old Mon 19 March 2012, 02:45
Axel1966
Just call me: Axel
Paris
France
Good ! The cutting quality is the main goal, so I'll save money with simple feets,
which are 4 times cheaper. Thanks.
Old Mon 19 March 2012, 04:23
marko cro
Dakovo
Croatia
Gerald, I have a question in private for you, but cant send you message.
Can we get in contact in any other way than this?
Old Thu 29 March 2012, 17:15
marko cro
Dakovo
Croatia
This is planning side ladder and fixing it up.
Below is my 1st weld done on that ladder. My experience in welding has reached for about 3-4 days, 1-2 hours per day. So I am pretty proud on that weld.
Rest of the welding is in the same or similar quality
image upload
upload images
Old Fri 30 March 2012, 18:25
TechGladiator
Just call me: Miguel #94
Randolph, NJ
Good Job there Marko. Starting to take shape.!!
Old Sat 31 March 2012, 07:26
Very nice work!!
Old Sat 31 March 2012, 08:41
bolingerbe
Just call me: Bryan #54
Clinton(Tennessee)
Good job.
Old Sun 01 April 2012, 04:51
marko cro
Dakovo
Croatia
I was wondering where is my thread
Thank you all,
Today all the front and side ladder will be finished, then moving on to the assembly it with trestle.
Will post more pics at the end of the day.
Old Sun 01 April 2012, 13:03
Axel1966
Just call me: Axel
Paris
France
Well(d) done !
You have some nice tools to clamp tubes squared.
Old Sun 01 April 2012, 15:14
marko cro
Dakovo
Croatia
That tool made my life much easier. Regreted tho for not buying 8 of them
Here are some pics from today work done. I have put it together just to get perspective. And it looks massive.
After working its important to clean the work area, coz my workshop is a bit small
Resting proudly at work being done
Old Wed 11 April 2012, 10:51
marko cro
Dakovo
Croatia
DIY aluminium control box. To build it, I had to make a tin knocker/bender, which is made from MM parts. Proof of concept, and it works.
Control box needs back enforcement in the back panel with some 150x150x15 aluminum plates. Heating wont be an issue here .
Holes and ventilation will be drilled additionally. But so far, a decent box.
Old Wed 11 April 2012, 10:56
WTI
Just call me: James
Detroit (Michigan)
I think it would have been cool to put a piece of tempered glass in the face of your door.
Old Wed 11 April 2012, 11:02
marko cro
Dakovo
Croatia
Yes, tempered glass for a spindle controller, and a hole for a digital thermometer.
Also, for buttons, and E switch.
Thanks for noticing
Old Wed 11 April 2012, 11:35
Pajka
Just call me: Pajka
Skopje
Macedonia
Great work marko!
Old Wed 11 April 2012, 21:13
Nice box.
With the VFD in such close proximity to the motor drivers, I hope you have good grounding lay up later.
Old Thu 12 April 2012, 14:24
IN-WondeR
Just call me: Kim
Randers
Denmark
There's no problem in having a VFD that close to the drives.
My old machine was also mounted close to the drives, I had no noise what so ever from the VFD..
My new machine has 15cm more distance to the drives, and again, absolutely no problems with noise.
Old Thu 12 April 2012, 16:13
marko cro
Dakovo
Croatia
Not sure will I have noise, but I was thinking of making additional box for spindle control, with air flow connected IN and OUT to outside of the workshop, due the dust accumulation.
In the calibration phase, I shall see if there will be noise.
Also, I am looking for a good plan for a spindle mount, which should be made of aluminum.
EDIT: I am looking for cutting aluminum, how does a MM act in engraving and cutting aluminium.
Does my spindle speed @ 24000 RPM is 2 much to cut it. Would be the Z-car too light for a aluminium, and should I fill it with sand .
Old Thu 12 April 2012, 20:53
Marko,
Many have successfully cut aluminum on a regular basis. One machine, a 8' x 21' machine was built to cut primarily alum sheet for a boat manufacturing business here in the US.
Old Fri 13 April 2012, 09:25
marko cro
Dakovo
Croatia
Hi Sean, Thank you for your post. The plan was to work with aluminium and wood, and some softer materials, and lately, i was starting to doubt the MM can work on aluminium.
I saw some videos and I think I will be fine in that area.
First Project Completed! #106 - NL Canada cleyte MechMates already cutting 48 Tue 23 May 2017 22:42
Not a MechMate but it is cool sailfl Miscellaneous / General / Whatever / Catchall 10 Thu 06 May 2010 15:59
Free Software and other cool stuff seaboardironworks Graphics & CAD 0 Sun 25 April 2010 08:29
On to other Cool Projects #43 - Arad, Romania Claudiu MechMates already cutting 205 Thu 25 February 2010 00:07
Cool front panel joint WTI Miscellaneous / General / Whatever / Catchall 0 Sat 07 June 2008 16:53
